Question about Toshiba 27AF45 27" TV
Color problem My toshiba is having problems with the color. Many things on the screen are shown in double and the double picutre is highlighted in blue, and I can't seem to get it to go away. Any suggestions?
  • BReich20 Oct 09, 2007
    I don't think it is a degaussing problem. I don't have anything magnetic or any speakers near the tv.
    About 2 weeks ago, I turned the tv on and it had the blue highlights, double picture etc. Last Saturday, it went back to normal for a few hours, but then out of nowhere, when i was still watching, it started doing the highlight/double picture again. My toshiba is about 8 years old. Could it possibly be a color stream problem?
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
I think it seems me is due to degaussing problem. solution 1 do not turn while tv is on. 2 do not keep any thing which has got magnet like speaker or headphone very near to it. if it is so put off tv for 15 minutes& put on it will be ok. good luck.
Posted on Oct 07, 2007
  • manahar modern Oct 09, 2007
    as per your comment now the problem is in color ckt.
    in colur tv there is one delay line ckt.
    it is due to some thing is loose or print break or parts failure in chroma delay line circuit.
    good luck.
The image color on projection is not the same as shown in laptop. There's is no red color.
It could be a broken connection in the computer lead for the red signal, or a fault on the projector that the red panel doesn't work any more.
To diagnose, bring up the projector's on screen display. If there's white in the menus then the problem is the cable. Replace it with a new one. If the menus are affected too then it's a projector problem. This requires the attention of a service engionner.
Aug 20, 2014 | Toshiba Tdp-s25 1080i 720p Hd Dlp...
Color isssues with my television
The problem you having is Called Convergence,Contact me while im online And ill tell you about it ttech
Jul 22, 2007 | Toshiba 57H81 57" Rear Projection...
Screen is showing all black things red
It sounds like your screen might be going bad. Normally there is no setting you need to be doing to adjust colors on your screen. There are some settings when you click Start/Control Panel/Display to look at your display settings, but these normally just control the color around the windows. For example the normal or default color for the strip that is at the top of your internet browser is blue but you can change it. I would say that when you boot your machine if the colors are not what they should be normally during the boot process, then your screen is going bad. You might try Opening a Word Document then type words such as Black, Red, Green, Blue, Yellow, etc. on different lines in the document. Then highlight the word and change the font color to match the word. This might let you see if your colors are true colors or if the screen is bad.
Mar 16, 2012 | HP Compaq nc4200 Notebook
There is too much red in the television
your red convergence circuit is defective and requires attention
Apr 28, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Colors are bleeding together and words appear double struck. The picutre itself sometimes is double. This is an intermitent problelm, comes and goes.
Your convergence ICs are about ready to quit working. Time to replace them. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to correct it and where to get any parts or tools you need. Let me know if you need more help. Thanks for using FixYa and for the great rating.
hardrocko
Apr 02, 2010 | Toshiba 55A60 55" Rear Projection...
48 inch toshiba with color alingment problem
Hello:
Thanks for this forum.
I have a Toshiba 48" rear projection TV which started to show red and green lines on the left side of the screen and have also started affecting the left-hand focus of the image shown on the screen. I have had this TV for 14 years and had a projection adjustment done once before.
Thank you in advance for your assistance.
Ed Alexander
Dec 06, 2008 | Toshiba Televison & Video
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
Toshiba 51h85c rear projection screen is red!!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 14, 2008 | Toshiba 51H84 51" Rear Projection...
Touch Screen Error
RED GUN OK, you need convergence IC's replaced = Toshiba
part # STK392-110T.....................................T.
Nov 14, 2007 | Toshiba 50H82 50" Rear Projection...
Red, green, and blue rectangular "chads" or squares across top of screen
Hi there, this is easy thing to fix. Its LDV cable. This is the Cable which goes from the main board on to the screen. Un plug the cable from the screen side., then push the cable back. Make sure cable sits in .
This will sort all the problems with the picture,i.e colour problem , picutre squring up and many more things.
Regards Sam
Sep 28, 2007 | Toshiba 42HP84 42 in. Plasma HDTV
Toshiba 27AF45 27" TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
