Question about Symbol PDT6842-NIS632EU Portable Data Terminal
Ls 9100 Hi, I have two used ls9100's and synapse/usb cable and 25-11497-01 cables. the scanner scans/beeps but doesn't put code into computer program/ I am using a eMac with OS 10.4. My other scanners will work??? other brands. But this "new to me" Symbol won't. I downloaded the Ls 9100 manuel but think it was before usb and synapse cableing.
    Problem Solver:
  • 13 Answers
Here at Legacy Global we can help. Call me at 1-847-750-9231.
Posted on Sep 09, 2008
    Problem Solver:
  • 5 Answers
The first thing you need to do is set the LS9100 to know it's connected to a synapse cable. Scan the "set all defaults" barcode and then the "set synpase host" barcode. Once you have done this you can program the unit for the specific synpase cable your purchase, such as USB, PS/2, etc.
Posted on Apr 18, 2008
SOURCE:
Symbol LS 9100 does not transmit data
after scanning the defaults barcode you just scan the "Enable LS 9100 Communication" on this manual on the link above.https://docs.symbol.com/manuals/1536503c.pdf
May 11, 2010 | Symbol LS9100 Hands Free
Symbol Scanner LS4071-I1us
transltor and data comparison failed?
Jul 27, 2009 | Symbol LS 4071 Handheld
Symbol HotShot LS2106 sounds like it's scanning, however, no data/information is displayed once scanned. Connecting to Windows XP with a USB converted to PS2 cable. Are there reset bar codes available that...
The LS2106 did not support laptop mode so the PS/2 wedge needs to have a PS/2 keyboard attached to the cable. If that does not work I would suggest trying to find a 25-31617-01 Synapse adapter cable and STI85-0200 USB Synapse cable. This would allow you to connect the scanner right to the USB port and it should work without any extra programming. I believe the cost of the two cables (if you have to purchase them new) is almost as much as a new LS1203 scanner with USB cable. At least with the new scanner you would get a three year warranty.
Jul 03, 2009 | Symbol Hotshot LS2106 Handheld
Have a look at the HOST setting in your defaults. I set one of these to default and had the same result. I'm guessing it's because the HOST is blank on Default settings.
Feb 07, 2009 | Symbol LS9100 Hands Free
LS 1004 Symbol Barcode Scanner
The host type are the Interafces which are supported by the scanner directly (no adapter needed). And the Synapse adapter can even an old scanner connect to new interfaces like USB.
As you state you have the adapter for keyboard wedge. You would just need to download the Reference Guide for the "Synapse Smart Cable" at support.symbol.com a configure it acccording to your connection parameters.
Mar 13, 2008 | Symbol Spark LS 1004
Locked Metrologic MS9520-37 (keyboard wedge) after unintentional programming
You programmed it for usb interface, but the scanner is keyboard wedge. Try pointing the scanner at the "recall defaults" barcode in the manual as you plug the scanner back in.
Feb 12, 2008 | Metrologic Instruments Voyager MS9520...
Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
Jan 03, 2008 | Symbol LS 4000i Handheld
Symbol LS-9100-4008A
Hi I'm trying to find keyboard wedge Configuration to re-program my scanner
It's a symbol LS-9100-400BA and connections if you can fax to 1-956-546-8752
Aug 28, 2007 | Symbol LS9100 Hands Free
Symbol PDT6842-NIS632EU Portable Data Terminal Logo
282 people viewed this question
Top Symbol Computers & Internet Experts
Ekse
Vish Iyer
Vish Iyer
Thomas F. Schneider
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
