Question about Dell Dimension 5100 (D51L1) PC Desktop
Blue screen and on boot up Error auto sensing seconard master HDD Drive 1 not found
I have a Dell Dimension 5100 with a Maxtor 250GB SATA hdd i let it for a few hours and found I had blue screen rebooted and got Error Autu sensing Secondary master HDD Drive 1 not found serial sata sata-2 I go into to set up as directed and then get totally confused as what should sata-2 read as I dont have a second drive? How do I fix I dont have FDD to try boot up externally
  • Anonymous Mar 12, 2014
    Error auto sensing secondary slave hard disk drive
  • Anonymous Mar 14, 2014
    All of a sudden my dell inspiron one 2020 has a blue screen and the words "fixing disk errors. may take oven an hour." It's been 'fixing it' for over 24 hours. What happened to it? Hard booting doesn't change anything and pressing F8 on boot up does not work.
    President:
  • Dell Master
  • 2,022 Answers
Go to the bios setup and set the system bios default and restart. bye
Posted on Oct 09, 2007
SOURCE:
Sata hdd windows dell recovery cd will partition install windows
The system is originally designed to use IDE HDD, make sure the necessary chages for Sata HDD are made in the BIOS, next make sure the Recovery disc is fine without any scratches. You can order a new Windows OEM recovery disc by calling Dell tech support (1-800-624-9896-US) and try installing the OS. The disc will cost you not more than $12.
Nov 15, 2009 | Dell Dimension 4700 PC Desktop
Bios screen freezes at startup
go to bios/set up and check in advanced set up and select the first boot device as HDD 0 or HDD 1 (hard disk 0 or 1) and also you need to see that the hard disk is seen in the bios, save and qite. if it is the same reinstall the operating system
May 23, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Master slave jumper settings on 250gb Maxline Plus II SATA
There are no master/slave settings on SATA drives because each drive has its own cable. The drive order is determined by what SATA port they are plugged into, or by the BIOS configuration.
Mar 16, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Sata HDD set in primary master in Bios
Try considering these:
1. DOS disk doesn't recognize SATA, that's the truth
2. You're going to have a problem if you install OS in your computer (solution: do not select SATA in HDD type but rather IDE)
3. For your SATA HDD to become primary (boot first) try to select your SATA HDD as devic first to boot..
Jan 04, 2009 | Maxtor Hard Drive
ASUS K8V-MX Motherboard with 250GB SATA HDD and 250GB IDE HDD Problem
Hi LP,
I’ am very familiar with ASUS motherboards. I am thinking you have posted two questions or more referring to the,
ASUS K8V-MX board. When you sign into you're FixYa account you than need to click on you're profile. Within you're profiles are the questions you have posted. Click that question to add or see the expert's answer. If you need another question (about the same item) re-post within that same question. You can even copy the link to an older post & past that link into you're next question. (Than I can read you're last question & my responce).
LP you have me all mixed up. I'll answer the question you have posted above. In the future please provide you're old post so I understand better.
There is nothing wrong with IDE 250GB drive or the SATA drive.
The problem you are haveing is setting the correct settings.
The ASUS K8V-MX can support two serial ATA SATA drives. The SATA drive's can only run at 1.0 version. 1.5GB transfer speed & not SATA II, the 3.0GB speed.
How to setup the SATA drive?
Please disconnect any other drives (IDE) & a second SATA drive that may be connected to the system. Except the CDROM drive.
Using you're manual the SATA drive should be connected to SATA1 port. Page 1-24 in you're manual.
Put you're windows CD into you're CD-ROM drive & boot the PC. You will see, Press any key to boot from CD... (press any key on your keyboard). Windows will start to install. Durring installation of windows the system will restart. You will again see, Press any key to boot from CD... (DO Nothing)!
Just allow windows to conintue on its own. Windows will continue to install it's self. This will happed once again, & again do nothing. Windows will finish installing it's self.
After windows has finished, load the ASUS CD into you're CD-ROM drive & install it's driver software. Restart the PC.
You must register windows. Do so.
Than update windows through windows update service. (This will take some time to complete). (Do not install service pack 3).
If you have an IDE drive 250GB in size & you installed windows on it. You must erase the drive or it will conflict with you're new installation on the SATA drive. To do this, look on the IDE drive & you will find a large white sticker. Printed on there is instructions of how to set the drive pin. Set the drive up as a slave drive. (This is only temporary).
Power off the PC & unplug the power cord. Connect the 250 IDE drive's power cable & data cable. Plug in the power cord to the PC & turn on the PC. Windows will load. Right click once on the start button & slide up to & left click on Explorer.
Find the 250 IDE drive, it should be drive letter D or E. Right click the proper drive letter & format the drive.
( Do Not format, Local_Drive C:\ ). Once the format is complete, power down the PC by clicking on the start button & click turn off the computer. Once off, unplug the power cord. Change the pin on the 250GB IDE drive to Master with a slave. Take the 40GB drive & change it's pin so the 40GB drive is a slave.
Connect the 250GB drive to the end of the IDE data cable & connect the 40GB drive to the next connector of the same IDE data cable. Re-check all power cables & data cables for good connections before closing the case. Plug the power cord in & power up the PC. Everything should run just fine.
Setting the pin for you're IDE drive's can be very confusing. Click on the link below. This will give you an idea of how to set you're pin for a master drive, master with a slave drive. If you post the name ST****** of you're two drives I can post the correct pin locations from Seagate's web site.
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
Have more questions about this post?
Mike
May 21, 2008 | ASUS K8V-MX Motherboard
Dell Dimension 5000
you problem is most likely that your bios is out of date. download the latest bios updates for your motherboard and then when you install windows format you HDD with the ntfs system (using the long formatt system not the quick format). Then you should install the bios update. then your mboard shoud no longer have the problem of recognising your large capacity HDD. thanks
May 18, 2008 | Computers & Internet
Maxtor diamondmax plus 9 6y080l0
If you have you primary HDD set on Cable select, and the secondary HDD is set on anything other then Cable select (with the jumper settings on the back of the HDD) then there will be an error.. Also, if you primary is set to master/slave and the same for the secondary, it will cause problems.
Another thought, if one of your drives is SATA and the other IDE, if the IDE is set to master, there may be an issue as SATA HDD's will try to post as the master drive
Mar 24, 2008 | Maxtor Hard Drive
Computer won't festart
you can do a clean install. put in your windows xp cd and boot from the cd. follow the installation wizard. ask if you have any issues
Jan 06, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
902 people viewed this question
Ekse
Clive
Clive
