Question about NetGear SC101 (SC101500) 250 GB Network Storage Server
Netgear SC101 Firmwere failed upload
Hiya guys 'n Gals I have a problem with my netgear Sc101 storage unit. this is what i have tried already! The program pops up with a message saying" an old sc101 firmwere is dectected the new SCM version does not work propilly with the old firmwere you must update the firmwere by autoupdate or go to the advanced controls config menu i click OK NOW! CLICKING skip for checking updates(not recomended) next Confirmation Message pops up if i want to skip checking click yes Now selecting advanced configration NEXT now the next window i''m not sure about it displays information about my ip address It says" found infomation on the centrel hard discs only my ip to the router is displaying 192.168.101 Press next anyway I bet i doing something wrong Arn''t I Now selected firmwere update pressing next it wants me to log in Admin - password admin next Confirm pops up password is correct you can continue press next now the computer window pops up to find the firmwere selecting firmwere on my desktop sc101_firmware_4_22_13.bin press ok now the Storage Central Manager Utility says" Updating firmwere do not stop the process then - firmwere upload failed Can any one help! please
Re: netgear SC101 Firmwere failed upload
Check your password, when i first did it I used what i thought was my password and the password check passed but i couldn't do a manual or automatic update. I retried with the system default password and the automatic update worked.
Posted on Nov 02, 2007
0 characters
3 Points
Look For Down loading Manual
Here is a link to the support website. Here you can get the Data Sheet, Hardware and Software Manuals, and the Installation Guide.
Welcome to the new NETGEAR Download Center
Dec 10, 2015 | NetGear ReadyNAS 312 RN31200-100NAS...
REST / Delete user / firmware update errors
Log in to your NETGEAR router by browsing to
Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
If you cannot log into your router:
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults.
however, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection.
Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and Clicking Apply.
If there is a small hole in the front or back of the router push a hair pin in to reset to factory settings.
Mar 29, 2014 | NetGear Stora MS2110 (MS2110-100PES) 1000...
Hi, few days ago I bought a Netgear NAS 2110 and connected it to my Netgear WNDR3700 router. I installed RAIDar utility and followed the instructions. Everything seemed to work alright. From my laptop I...
If it's new it's probably doing some housekeeping. The drives need to be formatted and then the RAID arrays need to be sorted.
On installing my server, it took days to complete, however, that was with existing data on the drive.
It might not be letting you switch off because it's busy and doing so would mess up what it's trying to perform.
If you don't want to wait to find out if all is OK, go into the configuratio utility and set just one drive up. This will show if it's working as a unit. If all is fine, install the remaining drives, maybe one at a time.
Dec 30, 2010 | NetGear ReadyNAS Duo RND2110 NAS server...
Volume 'DataVolume' doesn't exist
This is a problem with the HD's, which if you check via the browser, then advanced/storage will show the drives as good but unassigned. Only course of action is to try and totally reboot the unit to default which will lose all your data:-( but If this fails you will need a RMA from WD.
Feb 08, 2010 | Western Digital Sharespace 4000 GB...
I have a Netgear rnd2110 with 2 1TB disks - when copy large amounts of data to NAS drive - the system crashes with a "blue screen"
Hi, Please upgrade the RAIDar Software for NAS. You may download the same from the below link:
If the issue persists then please log a compalint with official NETGEAR support site at
Jan 05, 2010 | NetGear READYNAS DUO RND2110 1000 GB...
How to setup PLDT DSL with Netgear DGN2000
Hi, Follow the below steps to configure the router:
1. Connect the cable/phone line coming from Internet Service Provider to the WAN port of the router(isolated port).
2. Connect the computer to the router using any one of the 4 available ports.
3. Open the browser(Internet Explorer or Mozilla Firefox).
4. Access the router (usually
5. Login to the router (Username = admin Password = password unless you have changed it).
6. Click 'setup wizard'(at the top of list) from left menu.
7. Select yes and click next.
8. It should give you a "PPPoE Detected" and then click next.
9. Enter the login and Password of ISP click apply.
10. Once the settings are updated click on 'router Status' and click on 'connection status' button(at the bottom of the page).
11. Click on connect button.
12. Connecting to server should show 'connected'.
13. If you receive 'CHAP authentication failed', close the 'connection status' window and click on 'Basic settings'. Check the login and password for ISP and apply the setting again.
14. Open up another browser window and try to access internet.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Oct 09, 2009 | NetGear Network Storage Systems
I have a ReadyNas NV+ , I can't access
Try using the RAIDar utility again to see if all is working. Can be downloaded from downloads on You may need to call Netgear for support.
Mar 23, 2009 | Infrant Technologies ReadyNAS NV+...
Repeated hard disk failure and slow internal webserver
I have a simular problem with my DS207+. My second (sic!) volume failed especially when copying a lot.
But as I was using RAID1, I just repaired it and lived with it for the next months.
But now I want to have "Basic" drives.
I found this:
I will try and get hold of those cables.
If your third disk is failing again, it seems like a cable issue as well.
Oct 21, 2008 | Synology Disk Station DS207+ (DS207PLUS)...
on the myspace control panel click photos, then upload photos, then an applet called photo upload 1.03 appears, use that guy, press browse and choose the pic, press next three times and the rest will be explained by myspace itself
warning, you may need to have java installed
Dec 02, 2007 | Anthology Solutions Yellow Machine P400...
Western Digital NetCenter crashed
Umm... it sounds bad. If you can't get the unit to power back on after your performed the firmware update, it may have power failed during the update... and "bricked" it. Try a different power source and see if you can get it to at least power up. If it won't, there is probably no way of recovering it. I'd suggest contacting Western Digital to see if they have a recovery process for a firmware failure. Is it still within the warranty period?
Jul 29, 2007 | Western Digital NetCenter WDXE3200JBN 320...
NetGear SC101 (SC101500) 250 GB Network Storage Server Logo
550 people viewed this question
Top NetGear Network Storage Systems Experts
Chris Hunt
Brian Sullivan
Brian Sullivan
Are you a NetGear Network Storage System Expert? Answer questions, earn points and help others
