Vivitar Series One 28-300mm f/4.0-6.3 Auto Focus for Canon AF Logo
Posted on May 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can not auto focus this lens on my Nikon D60 I tried to do it as the write up but I need a manual or info Vivitar Series 1 28-300mm f/4.0-6.3
Benny Freeman
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 165 Answers
  • Posted on May 04, 2009
Benny Freeman
Expert
Level 2:
Cheetah:
Answers
165
Questions
0
Helped
77945
Points
302
First check if you lens is compatible with the camera.
is your camera a digital or film camera?
this lense is designed for a film camera and is discontinued
Will an auto focus Vivitar Series 1 100-400mm work on a nikon d80
Vivitar Series 1 lenses were available with a variety of lens mounts for different camera makes. If the lens has a Nikon mount then it will work on a Nikon D80. If it has some other mount then it will not fit.
1helpful
I have been given a vivitar 70-210 series 1 lens 1:3.5 with a Canon AE1 would the lens work with a DSLR Nikon D3100 - would I need to buy an adaptor ?
No, and no.
The lens will not work on a Nikon camera.
Nikon cameras are deeper than Canon cameras. Even if a Canon lens fit onto a Nikon body, it would not focus at infinity. In order to enable a Canon lens to focus at infinity on a Nikon body, a lens adapter would have to have a negative thickness.
I just purchased my d60 camera, unfortunately I bought it on craigslist, it came with a nikkor 50mm lense, I wanted a auto focus lense to take some sports pictures, I took it to shutterbug camera shop and...
That's odd that Shutterbug camera shop couldn't tell you everything you needed to know about that camera. I looked it up in a PDF manual because the new "small frame" cameras require different lenses as is the case here Autofocus with this camera is only supported by AF-S and AF-I lenses the lens is equipped with the autofocus motor other types of lenses will not autofocus.
The "kit" lens for this camera is the AF-S DX Zoom Nikkor 18-55 F3.5/5.6G VR.
Now if Shutterbug camera shop mounted an AF-S lens and the camera didn't autofocus then they are right in saying it's broke. I just find it strange they couldn't tell you that straight up. You need to install an AF-S lens and try it, again they may have put the wrong type on it and of course it won't work.
I take it that you don't have the camera manual?
If not go into Google search Type in Nikon D60 PDF manual and click search fifth one down on the first page is what you need click on it and download your "new" manual
Here is the link I used
http://www.google.com/#hl=en&sugexp=ldymls&xhr=t&q=Nikon+D60+Digital+PDF+manual&cp=28&pf=p&sclient=psy&aq=f&aqi=&aql=&oq=Nikon+D60+Digital+PDF+manual&pbx=1&fp=64f84e119f52b91a
See if that helps, personally I think you just need the correct lens.
1helpful
2answers
4helpful
2answers
Nikon auto focus lens not working, only in manual
What camera body? This lens doesn't have an internal focusing motor and thus will not autofocus on the D40/D40x/D60/D5000/D3000.
1helpful
I have that same problem but i own nikon D60 what settings do
M (Manual).
You won't get autofocus, nor will you get any metering. It's completely manual.
3answers
My Nikon D60 wont auto focus on any of my lenses. Could it be a problem with the body?
The d60 needs Auto focus lenses(Ones with motors inside the lense) it doesn`t autofocus on other lenses. this was done to reduce the price of the camera body
Hope this helps
Lens for Nikon D60
I will try to help you, but please understand that my experience is with Nikon film cameras. Assuming that the D60 works in a manner similar to a Nikon 35 mm body and that Sigma macro lens work like Nikon macro lens, you should be able to determine the usable subject to lens distance by experimentation. First, make sure the lens is in the macro mode. To do this you must set the auto-focus mode control to the manual focus mode (see your manual). On Nikon lenses, you must first set the focus ring to infinity, then move slider switch, which has two positions marked; "normal" and "macro., to the macro position. You should now be able to rotate the focus ring to the macro range. Use the zoom ring to zoom in and out and focus with the focus ring. The the range over which the lens to subject to lens distance will yield an in focus image will be rather limited and in the range of an inch or so to 6 or 8 inches.
Dec 09, 2008 • Cameras
Auto focus on 55mm lens not working on d 60 nikon
Since Nikon doesn't have a 55mm lens in its current lineup, I'm going to assume it's a rather old lens (though probably newer than my 55mm). As such, it won't have an internal focusing motor, and thus will not autofocus on the D60. The D60 requires lenses designated AF-S in order to autofocus.
3helpful
4answers
Tamron 28-300mm Model 185D Auto Zoom on Nikon d40
Autofocus function on the D40 only supports lenses with the
AF-S feature, which have an autofocus motor built into the lens,
instead of using an autofocus motor drive built into the camera.
The Tamron lens you have, does not have a built in motor and
the autofocus function relies on the motor drive in the camera.
It will not work with the D40 or D60, but it will work with other
Nikon digital SLRs, such as the D80. Need to get an AF-S
type lens or upgrade to different Nikon digital SLR. Unless
you do this, you will have to manually focus the Tamron lens.
All of the Nikon DX (for digital) series lenses are also AF-S
type, so they will work with the D40, which is designed as
an entry level digital SLR, therefore it is intended primarily
for use with DX lenses, which are typically sold in a kit with
the D40. Most common one is Nikkor 18-55mm DX AF-S.
Other Nikon AF-S lenses made for film cameras (FX type)
will also work with the D40, but these tend to be expensive
professional models. DX series lenses tend to be more
affordable. You might consider the 18-200mm DX AF-S
as an alternative to the Tamron, but these are not cheap.
Top Vivitar Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
