Question about Lite On Lite-On 52x32x52 CD-R/CD-RW IDE Optical CD-ROM Burner Drive: LTR-52327S /SOHR-5238S (Black, OEM) (ODCWLT535IDK) Burner
How can I fix this. (The door won't stay closed)
My cd-rw recently starts to pen and stays open whenever I turn the computer on. If I push this back it keeps open again. If I hold it there I will here the click every few seconds like it is going to open. Any idea what to fix this or is just a garbage?
  • Sarah Emmanuel Oct 10, 2007
    I fix many things by myself though not cd roms. So I wanted the idea of what is wrong and then I would fix by myself. If it is to buy the new parts ..what are those parts etc...Now I know it is fixable  iwill google till I know the problem and fix it
  • 22 Answers
MAKE SURE TO REMOVE ALL POWER CONNECTORS.......you will have to take apart the drive and there will be two cogs one is in the shape of a half moon .Carefully move that cog toward where the face plate of the drive was.It needs to be in the next to last notch. If that doesn't help.then you will probably have to buy a new drive. It helped mine.It is the anti-jam mechanism that causes the drive to pop back open.If it fixed it don't ever close your drive by pushing it,because it may kick it out of line again. You may want to take a clean Q-tip and clean your laser head by gently spinning it on the head, take some caution not to leave any cotton fibers on or near the "eye"(laser head). try to remove dust from the drive.
HOPE this helps.
TweakX
Posted on Dec 26, 2008
  • 38 Answers
The problem can be fixed but probably not at your end. Get it done bya trained technician.
Posted on Oct 08, 2007
SOURCE:
Kenmore dryer model 110.74994300 push start does not stay on
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
Kenmore Whirlpool Dryer Won Start Easy Fix
Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Jul 01, 2014 | Kenmore 62602 Electric Dryer
Hitachi ax-m71 cd door won't stay closed. Unable
if it opens back up when you close it the drawer mechanism is probably out of alignment. Most players have a slot on the bottom of the drawer that a pin must slide in. Look under the drawer and see if there is a pin sticking up that maybe should be in that slot.
Jul 09, 2013 | Audio Players & Recorders
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
The dvd tray on my Sony BDV-E780W won't stay closed. Whenever I turn it on the tray opens and wont close from the remote or device.
Have you checked to see if it is off track? Sometimes when these machines get bumpbed, dropped, or fall they can jump track. You have to take the cover off and inspect to see if it is off track when it closes and opens. It should go all the way back on the track when it closes. Be careful not to shock yourself. If it is on when you do it and your hand touches the metal parts inside you can get seriously burned or shocked.
Dec 01, 2012 | Televison & Video
Cd player door won't open
cd/rw drive has shifted due to unit being bumped, Tray is binding or blocked. Remove the back panel. Remove 4 screws on the bottom holding cd drive. Now you can push the drive slightly back. On the left side of the drive there is a white nylon cam. Push in with a screwdriver and the tray will open so you can manually remove your cd. You should be able to cycle the tray open and closed now. Replace the four screws but cycle several times after tightening each screw. Replace the back.
Aug 30, 2012 | Crosley CR248 Turntable
Dryer won't start; light stays on whether door is open or closed.
Sounds like the door switch is not functioning or shorted......in other words the dryer thinks the door is open so it won't turn on.
Jun 22, 2009 | Dryers
Cd door will not stay shut
There might be some problem in ur CD rom motor that control the tray eject,,so u have to take it to nearest service center..
Dec 09, 2008 | IBM ThinkPad R40 2722 Notebook
Cd tray not staying closed
gently push the cd door back in while pushing the door closed button , untill it closes if it still comes out then the cd laser mechanism is not lifting or something else has happened , then it will need to be tested to determine the exact cause
Oct 16, 2008 | Memorex MKS5001 Shelf System
LG DVD+RW door won´t close
Deliverance
this problem can happen if tray-in sensor not sense. their r a small liver which press tray in sensor automaticly when tray stay inside. liver and sensor location is near emergency exit hole (when u use a pin for emargency exit actually u press this liver then it release try-in sensor). check this liver and its path any pice of cd is their or not. (to check open ur drive cover. to open it at first use emeargency exit hole to open tray then open cover)
Dec 19, 2006 | LG (GSA-4120BK) DVD±RW Burner
Computers & Internet Logo
800 people viewed this question
Top Lite On Computers & Internet Experts
Pierre Laplante
Ekse
Damen Wong
Damen Wong
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
