Question about Canon PIXMA iP90 Mobile Printer
New printer and after set up won't print
After taking all the protection covers off the appropriate things when it prints no ink is coming onto the paper. Have searched for any stray masking tape but none there. Why won't it print?
    Novelist:
  • 77 Answers
If you have not missed any CLEAR plastic film on cartridge seals or head assembly, and have the printer cartridges installed correctly (make sure there is a snap and then no "wiggle" afterwards) then you perhaps failed to clean the heads? New cartridges/heads must be "cleaned" or "deep cleaned" sometimes several times, before ink begins to penetrate the dry orifices. They are nearly microscopic, so this can take several tries. And cold weather can drastically increase the "wait" (hours needed for printer to be left alone, let ink flow down into dry/new heads). The latter requires patience, a commodity rare in "new purchases", I know, but "new toy anxiety" does not alter "physics".
Posted on Dec 12, 2007
SOURCE:
My printer told me to replace the black cartridge, which I did. It still continue to say the black cartridge needs replacing even though there is a brand new one in there. How can I resolve?
This usually happens for two reasons. The first is that many people often forget to remove the protective plastic off of the circuit contacts on the bottom of the cartridge. These circuits allow the printer to communicate with the cartridge so that it can detect ink levels and such. The second reason is a less obvious one, and probably constitutes the most common cause for your particular problem. Over the life of a cartridge, repeated use causes minute amounts of ink to leak out. This ink can collect on the print head (what makes contact with the circuit board part). The ink on the print head will then sometimes form a coat on the part of the printer that makes contact with the cartridge. If this happens, the printer will be unable to communicate with the cartridge--meaning it won't be able to detect that a new cartridge has been installed.
To clean the print head, remove the ink cartridge and set it aside. In the print cartridge carriage (the part of the printer where you insert the cartridge), find the area where the printer contacts the cartridge circuitry. Gently clean it with a damp cloth. Use a clean area of the cloth with each wipe so that you don't wipe the ink back onto the contact. If you have trouble getting the ink off, spray some windex onto the cloth (NOT INTO THE PRINTER). When ink no longer transfers onto the cloth, allow 5 minutes or so for any dampness to evaporate off the printer. Reinstall the cartridge and cross your fingers.
Hopefully this will help you out. Ink on the print head is usually the problem in cases such as this. If you found this solution helpful, please leave a positive rating!
Aug 19, 2011 | Kodak ESP 5 Printer
My Dad bought new ink cartridges ( black and color) and installed them in the printer and it is not registering that they are installed. What are some things I should check for and how can I fix this????
After installing new ink cartridges in your Dell all-in-one 926 printer, you may receive an error message telling you the print does not recognize the new cartridges. Refilled or third-party cartridges, which Dell does not recommend using with the 926, often trigger the error message. You may also receive this error after you have been using the same ink cartridges for some time. Whether the cartridges are new or not, the error can be caused by a number of sources. Following the steps below should clear up print cartridge problem.
  • 1
    Open the Dell 926's front cover with the power on and wait for the cartridge carriage to come to a stop. Remove the ink cartridges by pressing on the tabs at the top of each cartridge. Check the cartridges to make sure you have removed all of the blue protective plastic film. Look for the "Dell" logo stamped into the cartridges' lids to ensure they are genuine cartridges.
  • 2
    Clean the shiny metal portions of the ink cartridges with a damp microfiber cloth. Allow each cartridge to dry completely.
  • 3
    Clean out any paper, staples or other debris that you may be able to see, then reinsert the cartridges into their appropriate slots. Put the black ink cartridge into the left slot and the color cartridge into the right slot. Make sure both click back into place.
  • 4
    Close the Dell 926's front cover and turn off the printer. Unplug the power cord and USB cable from the printer for five seconds, then reconnect them.
  • If your Dell 926 fails to recognize the print cartridges after following the above instructions,
    take it to a repair shop for servicing.
    Good Luck and Happy Printing
    Jan 26, 2011 | Dell 926 All-In-One InkJet Printer
    My canon pixma ip1300 is showing service error 5100, not printing and yellow light blinks five times thanks in advance..........
    Solution: Install the print head and ink tanks correctly iP3000 / i560
    Seat the print head Below is the procedure for seating the print head and ink tanks:
    1. Power on the printer.
    2. Open the paper output tray and top cover.
      Note: Gently open the paper output tray while holding it.
    3. After confirming that the print head holder has moved to the center, open the inner cover.
    4. Remove the orange tape securing the print head lock lever, and raise the print head lock lever.
      Note: If the top cover is left open for more than 10 minutes, the print head holder will move to the right. If this occurs, close the top cover once and then re-open it.
    5. Remove the print head from its package and remove the orange protective cap.
      <1> Electrical Contacts and Print Head Face's Nozzle Area
      <2> Ink Supply Filters
      Note: To avoid any damage, do not touch the print head face's nozzle area, electrical contacts, and ink supply filters. After removing the protective cap, set the print head into the print head holder immediately. Do not re-attach the protective cap after it has been removed.
    6. Set the print head into the print head holder, and lower the print head lock lever until a click sound is made.
      Next, install the ink tanks.
    7. Remove the cyan ink tank (BCI-6C) from its package. Pull the orange tape in the direction of the arrow to remove the wrap film completely.
      Note: Remove the orange tape completely. If the orange tape is not completely removed, it may interfere with printing.
      <1> Removed correctly
      <2> Removed incorrectly
    8. Hold the ink tank as shown in the image below. Twist the orange protective cap in the direction of the arrow, and remove it.
      Note: Remove the protective cap while holding it, so that fingers will not be stained by the ink.
    9. Insert the ink tank into the slot at the right end, and push down on the PUSH mark on top of the ink tank until a click sound is made. Install the other ink tanks in the same manner.
    10. Close the inner cover and top cover.
      Note: Check that each ink tank is installed in the correct position:
      Properly installed:
      Improperly installed:
      <Left Image> The M ink tank is not fully seated.
      <Right Image> All ink tanks are not fully seated.
    Dec 03, 2010 | Canon PIXMA iP1300 Printer
    My printer is not printing out any black ink onto paper. Only the color is printing out onto paper. I put two brand new cartridges in for the black ink and color ink, and it says that the ink levels are...
    You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It’s best to do this each time you install a new cartridge. for more information….... http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
    Sep 03, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
    Cant figure out how to put in the ink cartridges
    Procedure for replacing Cartridge
    When FIne Cartridges run out of ink, replace them. using the following steps.
    *Important
    Handling Fine Cartridges
    -Once the protective tape is removed, do not touch the electrical contacts or Print Head Nozzles on a FINE Cartridge. The printer may not print out properly if you touch it.
    -To maintain optimal printing quality, we recommendthe use of specified Canon brand FINE Cartridges.
    Refilling is not recommended.
    -Once you remove a FINE Cartridge, replace it immediately. Do not leave the printer with the FINE Cartridge removed.
    -Replace empty cartridges with new ones. If you insert FINE Cartidges that has been removed once, the printer may not print properly due to some reasons such as clogging of the nozzles. Furthermore, with such cartridges, tlhe Low ink warning may not be displayed properly.
    -Once a FINE cartridge is installed, do not remove it from the printer and leave it out in the open. This will cause the FINE Cartridge to dry out., and the printer may not operate properly when it is reinstalled. To maintain optimal print quality, use a FINE Cartridge within 6 months of first use.
    -Color ink may be consumed even when printing a black and white document or when black and white printing is specified.
    Color ink is also consumed in Print Head Cleaning and Print Head Deep Cleaning, which may be necessary to maintain the printer's performance.
    1) Make sure that the printer is on, and then open the Front Cover.
    The FINE cartridge Holder move to the left.
    Cautuion : * Do not hold the FINE cartridge Holder to stop or move it.
    * Do not touch the metallic parts inside the printer.
    Important : If the Front Cover is left open for more than 10 minutes, the FINE Cartridge Holder moves to the right. Close and reopen the Front Cover to return the holder to the left.
    2) Remove the empty FINE Cartridge.
    a) Push down the FINE Cartridge.
    b) Remove the FINE Cartridge.
    Important: - Handle FINE Cartridge carefully to avoid staining your clothes or surrounding area.
    -Discard empty FINE Cartridges according to the local laws and regulations regarding disposal of consumables.
    3) Prepare the replacement cartridge.
    a) Unpack a new FINE Cartridge and remove the orange protective tape. gently.
    Important : - Handle FINE cartridge carefully to avoid staining your clothes or surrounding area.
    - do not re-attach the protective tape once you have removed. Discard it according to the locals laws and regulations regarding disposal of consumables.
    -once the protective tape is removed , to not touch the electrical contacts or Print Head Nozzles on a fine cartridge. The printer may not print out properly if you touch it.
    -Be careful not to stain your clothes and hands with the ink on the removed protective tape/
    4) Install the FINE Cartridges.
    a) Insert a new FINE Cartridge all the way into the appropriate slot. The Black FINE Cartridge should be installed into the left slot and the Color FINE Cartrige should be into the right slot.
    b) Push up the FINE Cartridges until it clicks into the place.
    Important : The printer cannot be used unless both the FINE Cartridges are installed.
    5) Close the Front Cover.
    Hope this helps. Please rate my response.
    Thanks,
    Have a good day.
    Nov 26, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
    Replaced the magenta cartrage. arror check Ink
    The Error "Check INK U140"
    Causes : Possible causes are as follows :
    * The ink tank may not be installed properly (The lamp on the ink tank is off).
    Install the appropriate ink tank.
    * The ink tank not be compatible with this machine. (The lamp on the ink tank is off).
    Install the appropriate Ink tank.
    The machine will not print of the wrong type of ink tank is used or if it is installed incorrectly.
    Be sure to install the ink tanks in the proper order. The proper arrangement from the left to right is Black - (CLI-8BK), Black -(PGI-5BK), Yellow - (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
    Replacing Tanks
    1) Ensure that the machine is on.
    2) Raise the Scanning Unit (Printer Cover) until it stops.
    The Paper Output tray will open automatically and the Print Holder moves to the center.
    Impoprtant : If the Scanning Unit (PRinter Cover) is left open for more than 10 minutes, The Print Head Holder moves to the right. Close and reopen the Scanning Unit(Printer Cover) to return the Print Head Holder to the center.
    3) OPen the Inner Cover.
    4) Press the Open button to open the Paper Output tray if it does not open automatically and remove the ink tank whoe lamp is flashing red fast. Do not touch the Print Head Lock Lvever. Remove only the ink tank.
    Important : * Handle the ink tanks carefully to avoid staining clothing or the surrounding area.
    * Discard empty ink tanks according to the locakl laws and regulations regarding disposal of consumables.
    Note : Be sure to replace ink tanks one by one when replacing more than one ink tank.
    5) Prepare a replacement tank.
    a) Remove the new tank ink from its packaging, then pull the orange tape so that the protective film does not remain on air hole. Then remove the film.
    b) Remove the orange protective cap from the bottom of the ink tank and discard it.
    6) Install the ink .
    a) Install the ink tank into the Print Head.
    b) Press on the Push button on the ink tank until the ink tank snaps firmly into place.
    c) Ensure that the ink tank clicks into place and then its lamp lights red.
    Important : Make sure to install all the ink tanks to enable printing. The machine cannot be used unless all the ink tanks are installed.
    7) Close the Inner Cover.
    Note: Ensure that the Inner Cover is closed, Printing will not occur if the Inner Cover is open.
    Hope this help. PLease rate my response.
    Thanks
    have a good day.
    Nov 23, 2009 | Canon PIXMA MP530 All-In-One InkJet...
    My epson stylus c84 prints, but there's no ink on the paper
    This might sound stupid, but did you remove the plastic film that covers the head?
    Try this, if still nothing happens, go through your printer settings and run a "Cleaning" cycle on it.
    Aug 28, 2009 | Epson Stylus C84 InkJet Printer
    Can't find ink storage
    look at this
    Details Issue: How do I replace or insert an ink tank?
    Solution: Install the Print Head and Ink Tanks - MP620 / MP620B
    1. Open the Paper Output Tray (A), then lift the Scanning Unit (Cover) (B) until it locks into place.
      The Scanning Unit (Cover) (B) is fixed automatically.
      The Print Head Holder (C) comes out. (This is where you install the Print Head.)
      Note : Close the Document Cover (D) and lift it with the Scanning Unit (Cover).
    2. Raise the Print Head Lock Lever (E).
      i_expl.gifCaution : Firmly raise the Print Head Lock Lever until it stops. (The Print Head Lock Lever may feel heavy.)
      i_note_e.gif Note : If the Print Head Holder does not move, make sure that the machine is turned on.
    3. Remove the Print Head from the silver package.
      i_expl.gifCaution : There may be some transparent or light blue ink on the inside of the bag the Print Head comes in, or the inside of the protective cap - this has no effect on print quality. Be careful not to get ink on yourself when handling these items. Be careful not to stain your hands.
    4. Remove and discard the orange protective cap.
    5. Tilt the Print Head and set it in place. Lower the Print Head Lock Lever (E) completely.
      i_expl.gifCaution : Do not knock the Print Head against the sides of the Holder.
      Be sure to install it in a well-lit environment.
      Pinch the Print Head Lock Lever firmly and lower it gently.
      Once you have installed the Print Head, do not remove it unnecessarily.
    Install the Ink Tanks
    1. Pull the orange tape (1) in the direction of the arrow to peel off the protective film and remove the film (2) completely.
    2. While pressing down with your left thumb, twist off the orange protective cap (A) located on the bottom of the ink tank.
      i_expl.gifCaution : Do not hold the sides of the ink tank; ink may splash.
    3. Install the Ink Tank
      Press the PUSH mark on the ink tank until it clicks into place.
      Make sure the Ink lamp lights red.
      i_expl.gifCaution :Be sure to install it in a well-lit environment
      i_important.gif Important : Match the labels when installing.
    4. Install all the other ink tanks in the same way.
      Install all the ink tanks.
      i_expl.gifCaution :Once you have installed the ink tanks, do not remove them unnecessarily.
      i_important_e.gif Important : Make sure all the Ink lamp lights red.
    5. Close the Scanning Unit (Cover) (B).
    Mark
    Apr 16, 2009 | Canon PIXMA MP620 All-In-One InkJet...
    Doesn't print!
    u sure litte thing on new ink is off platci cover that protects them download the latest driver ok from kodak website try it again thx nick
    Jun 16, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
    Print page comes out blank
    If the cartridges are old too this may be a problem. When ink gets old it can clog the cartridges. If they are old replace them with new ones. If they are new ones did you peel the protective covering off before you inserted the cartridges? Hopes this helps
    Sep 16, 2007 | HP DeskJet 952c InkJet Printer
    Canon PIXMA iP90 Mobile Printer Logo
    50 people viewed this question
    Clive
    Clive
    old marine
    old marine
    Ekse
