Question about HP Business Notebook NX9110 Notebook
No light is on but fans on
I have nx9110 notebook and it was turning off by it self during my work from previous 6 days. But at this time when it turned off and as I turned on to go into its BIOS when I press its del key it again turned off and when I turned it on again it gave me no display its power light and hard disk activity light turned on but after few moments all of its lights turned off but fans were working and they were on. Now the problem is that there is nothing on its LCD no picture is available on it and no light is on even its power button light is remains off as I turned it on and its fans starts working. Some times when I turn it On Caps Lock light and Num lock lights starts blinking simultaneously and after few seconds they turned off. please help me in this problem. I need my notebook display back.
I changed the CPU but it did not work. Would you please help me resolve the issue?
Posted on Dec 24, 2007
    Novelist:
  • 188 Answers
I would bet your system has been overheating - that's why it kept shutting off. Now it may have overheated and killed your CPU or mainboard. These laptops require quite a bit of disassembly to get at the CPU. You will probably have to take it to a repair shop for further work.
Posted on Dec 21, 2007
Self adjusting in wall timer
Timer is not known.
Copy following links to identify timer and download manual
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/ST01C-program.html
In the manual, you will see directions for resetting timer.
If resetting does not work, then review timer programming carefully to make sure there are no conflicts in the programming such as overlapping days, or inconsistent am-pm, etc
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 13, 2012 | Intermatic & Self-Adjusting Wall Switch...
How do i work my webcam? I have a emachines E627
It will work if you will be using yahoo messenger or skype and etc. The webcam will automatically turn on if your on video call or video chat online! Have a nice day!
Jan 10, 2011 | Acer eMachines 520-2890 Notebook
Mic and side buttons on my compaq nx9110 dont work!
visit my website for all ur sound related problems...
www.sureshayyar.110mb.com
go to support page in there...
all the best
Dec 25, 2009 | HP Compaq nx9110 Notebook
When I turn the laptop on it powers up but there is a black screen. It's a compaq nx9110
Shut it down. Take the battery out. Unplug it. Leave the battery out then turn the computer back on. If you still have a black screen there is a hardware problem. If you have an external monitor connect it to the laptop and switch to show on external monitor. If you can see externaly then problem is cable or screen problem. If you can't see external picture then problem is most likely a chip on the motherboard. Video chip problem common on hp and compaq laptops.
Nov 07, 2009 | HP Compaq nx9110 Notebook
Batery hang problem
batteries have a charge memory in the, when you purchase a new battery the best thing to do is to fully drain the battery before charging it up, this will tell the battery that it needs full charge, if you charge the battery before this it will only charge the battery to a certain percentage.
what you need to do now is find a way to fully discharge the batteries
kind regards
Dec 23, 2008 | HP Compaq Business NX9110 Notebook
HP compaq nx9110 BIOS battery/hd not detected
Hi there , if the main battery is removed the cmos battery will go flat , if its a small pcb mounted 1 you can short the contacts for a short time , if the cdrom is working it mains the 5volt supply is ok and you should be able to hear the hard drive spin up unless there is damage to the pins on the hdd or the adaptor or hdd is mounted wrong .
Aug 10, 2008 | HP Compaq Business NX9110 Notebook
Where is the CMOS location in nx9110 hp
F10 is the correct button to press when booting.
Dec 24, 2007 | HP Business Notebook NX9110 Notebook
Compaq NX9110 problem
Is the system set to hibernate? If so I would disable that function. Is it exactly 30 minutes or just a rough guess? Also check and see if there is an issue with StandBy.
Nov 18, 2007 | HP Compaq Business NX9110 Notebook
No Lights On But Fans On
I would start by using only 1 stick of RAM this sounds like symptom of a failing ram card or occasionally ram socket. The RAM is on the bottom of the laptop under the middle panel.
If you have 2 chips try each chip individually in each socket.
If it was turning itself off it was probably overheating - i see the fans gets clogged on this series all the time. You may want to blow it out with a can of compressed air.
Let us know if you need more help.
Oct 11, 2007 | HP Business Notebook NX9110 Notebook
Laptop screen flips
First of all i would suggest that you connect the computer to another screen. If the problem persists it means that the screen card has gone and needs to be replaced.
Feb 21, 2006 | HP Business Notebook NX9110 Notebook
HP Business Notebook NX9110 Notebook Logo
113 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
