Question about Maytag Performa PAV2200
My washing machine does the wash but does not drain the water
Hotpoint Aquarius 1200 I have checked the plastic pipes and there is noting suck. If i shake the plastic pip that goes into the sink then I could here the water drain away. It seems like the washing machine needs to be reset.
  • 209 Answers
Re: My washing machine does the wash but does not drain...
Check the pump for it running, if it does not run check for electrical continuity with a meter, there should be a circuit between the connectors, remove the 2 wires to test, if no circuit replace the pump with a new one and reconnect the wires etc if the pump is working than double check for blockages, in all the pipes and the pump body itself hope i have been of help
Posted on Oct 07, 2007
0 characters
3 Points
Please help the washer fills up and turns the
Seems like a blockage or maybe pump worn out. Fill machine and take grey outlet pipe on rear of machine. Place this pipe as low as possible into a bowl. If water flows free from this pipe then your pipes are not blocked and most likely you will need to change your pump. Before you try this just put machine onto spin and ensure this will work when machine is almost empty
Mar 12, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Wf310 hotpoint aquarius washing machine wont spin or drain
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Feb 23, 2010 | Hotpoint Aquarius WD63 Front Load...
Water goes in then straight out of the waste pipe
The waste pipe is probably too low, this is letting the water syphon out.
Try lifting the outlet pipe higher up, this should solve the prob.
There is a line on the back of the washer, which incates the min hieght for drain outlet.
Please rate my solution.
Nov 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius 1200 wont empty and I cannot find the filter to try and clean it out
HI. the filter is mounted on the drain pump housing. You will need to disassemble the unit to access the filter. Here are some other areas i would check, also.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
NOTE-If the hoses filter,and pump check out ok, this will confirm that there is a serious issue within the actual control sector(Timer module or control board). It should be replaced i this case.
Oct 25, 2009 | Hotpoint Washing Machines
Hotpoint Aquarius 1200 Washer Dryer not drying.
Hi, I think the problem you have is with the cold water inlet valve? When your machine dries it uses a small amount of water at high pressure through a restricter fitted in the water inlet valve. These break down letting in to much water which cannot evaporate quick enough for it to pump out causing the washing to become wetter than after the wash/spin cycle. The only way of solving this is to replace th tree way water inlet valve. But make sure that the pump is working ok first and that there is nothing in the sump hose trap which is located underneath the washing machine out the bottom of the tub.
Good luck.................
Dec 28, 2008 | Hotpoint Washing Machines
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Don't forget to rate!
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius 1200 WD62 (Tumble drying issue).
no the steam from the dryer part comes out of outlet tube the same tube were the water comes out hotpoint washer/dryers use a condensing chamber which allows the steam to cool down a pass through it as water does and through the outlet pipe
Aug 14, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Washing Machines Logo
Top Maytag Washing Machines Experts
Richard Roth
Richard Roth
Al Clark
Todd Marr
Todd Marr
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
