Question about RCA P52939 52" Rear Projection Television
RCA P52753AT tv will not turn on
I have an RCA big screen tv that at first only the remote would not work, but the tv worked. One day the tv shut off (by itsself) and would not turn back on. I replaced the fuse by the power source and the tv turned on again, the remote even partially worked until the search function was pressed. Little screens, like picture in picture began popping up and after approx. 5 seconds I saw flashing lights w/in the tv and it shut down. The tv will not turn on, although it does make a little click when the button is pushed. the remote does not work either.
  • 2 more comments
  • Anonymous Nov 09, 2007
    when i turn the RCA television on it turns itself off
  • mrudella Dec 16, 2007
    Have similar problem on a P52835LV. TV will not turn on. When unplugged then replugged in, it sometimes comes on. It usually makes a big pop noise when replugged in. When it does come on it works fine until shut off, then same thing. Will not come on at all now. Only used occasionally in rec room. Any ideas?
  • Anonymous Aug 17, 2008
    model p52753at power button glows green for a couple of seconds when pushed manually or with remote. goes out after couple of seconds and tv wont turn on
  • littleham491 Mar 19, 2009
    I press the on button and the thing button glows green and ticks like a bomb and then stops
The High Voltage splitter needs to be replaced
Posted on Apr 05, 2008
When i turn on the tv i hear nothing but a popping noise what do i need to do
Posted on Nov 14, 2007
My Volume and Channel button won't work and so I have bout 2 remotes, neither of them have worked, one is the RCR311BR remote which has been noted to work for this tv. What else can I do
I have a 2000 model RCA P52923 and I had the same problem occur a couple of days ago. The sound hasn't worked for a couple of years, but the TV is connected to an RCA surround sound to resolve that issue. Most recently, while watching TV, it began to start scanning channels by itself. I shut it off and unplugged it for a couple of days, but each time that I turn it on, it begins to immediately start scanning each channel. Neither the remote, nor the channel buttons on the set are able to stop the scanning, and neither of them will perform any functions, including turning the set on and off.
Any advice would be greatly appreciated.
Mar 11, 2011 | RCA P52926 52" Rear Projection Television
Rca model# d52w135d screen won't turn on
Are you saying that the screen goes black after the DVD player stops working?
Jan 10, 2008 | RCA D52W135D 52 in. TV/DVD Combo
Big screen stop coming on
Replace the CP150 and CP114 capacitors. You can get the caps at the following link under the RCA parts category.
http://servicemanuals.vstore.ca/
Jun 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" Projection TV P52753AT
On my 52 projection TV P52753AT I found that one of the Kine Sockets burned so it is just a matter of replacing it if I can find one or rebuilding it. And yes that will give it the clicking sound when you turn the TV on. I'm just glad I am a computer tech and I enjoy doing this kind of thing for a living.
Thanks
Wesley B Wilhite
Jan 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA big screen tv shuts off and comes on by itself.
on top of the fuse it sounds like the power supplie is going bad
Dec 03, 2008 | RCA P61310 TV
RCA MODEK D52W17 Cant Get Any Remotes To Work This TV
The remote receiver in the TV is failed. It is possible that a TV repair shop might be able to fix the problem for you
Jun 18, 2008 | RCA HD52W58 52" TV
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Rca projection tv model # p52753at
it has circuit broken .short call tech.
May 05, 2008 | RCA HD52W56 52" Rear Projection HDTV
Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Jan 25, 2008 | RCA HD56W58 56" TV
RCA P52939 52" Rear Projection Television Logo
1,242 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
