Question about Aloha Housewares 83030 1500WT MILK HOUSE HEATER
Dead Oil Filled Radiator
I have had the unit for over a year, and it is now dead. Looks like others have had the same problem with other brands, something about a power switch failure. These are relatively cheap units but I would like to fix it for less than the cost of a replacment if I can. An e-mail to the company has not produced any results to date. Any ideas would be greatly appreciated...
  • 4 more comments
  • loisreal Nov 20, 2007
    I have the lakewood model 7096 and seem to have the same problem as you. the lights on the witches light up but no heat
    [email protected]
  • Anonymous Nov 22, 2007
    same problem here holmes heater model hoh2518 power light lights up but no temp display and controls are unresponsive.and worst of all no heat.
  • Sandy Merrick Dec 03, 2007
    The lights are on but no heat, I hear the thermostat click on and off, but still no heat
  • Anonymous Dec 11, 2007
    I have used the heater for one winter, now it will not turn on.
  • brrrimcold Dec 20, 2007
    I have the same problem with my oil filled heater. A thermostat switch is gone and we cannot find one to fit. We tried calling the company and they said that unit is discontinued (of course). I have tried a number of small appliance repair shops and plumbers in the area, but no one can help. We bought it 3 yrs ago and only used it for a week or two, so it is not worn out by any means. There has to be a thermostat switch on this planet somewhere.
  • Anonymous Dec 25, 2007
    Fahrenheat oil- filled heater worked fine last season for use, 3-5 times. This season used once and it heated beautifully, now there is no heat although it is turned to hightest level. Can't find s# or other manufacture details on heater. Manual is misplaced. Woe is me and I am cold. Cold-one.
    Problem Solver:
  • 17 Answers
DO NOT ATTEMPT TO FIX YOUR HEATER ...THAT IS STUPID AND WILL MORE THAN LIKELY CAUSE A FIRE. SO DONT. Just call the 1-800 number on the back of the unit. The customer rep will tell you what to do from there.
Posted on Feb 20, 2008
I had the unit on today about 15 minutes . The unit almost burned my house down . I have not called or emailed the company yet . It scared my wife and son , luckly I had the guts to unplug the unit and get out the front door .Thank God for the fire extinguisher !!!!! DO NOT TRY TO FIX YOUR UNIT . PLEEEAAASSEEEE!!!!!!!!!!!!!!!
Posted on Jan 09, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
On lakewood radiator that was dead I found problem caused by what I believe is fuse opening. Part is located in white wire which goes from thermostat to common terminal on radiator terminal block. The part is in series with this wire and is covered by a white movable sleeve and is dressed/located under the terminal block.
Posted on Oct 27, 2007
  • 102 Answers
If this is a generic problem then it is most likley the THERMOSTAT. This is the switch on the end of the radiator that regulates the temperature. It is possible to bypass the thermostat so that the radiator is permanantly on.
Posted on Oct 06, 2007
SOURCE:
Oil in water tank
Blown head gasket.
Apr 09, 2015 | 2003 Ford Focus
Tip
Oil Filled Radiator Heater Leaking
<p>A very common and increasing popular source of <b>supplemental heat</b> in the last few years has been the <b>oil filled electric radiator. </b> <br /> <p>These <b>radiator heaters</b> are filled with an oil that circulates through the fins of the heater and is heated by <b>electric heating elements</b>. The result is a steady even type of heat that has a lower surface temperature then many <b>space heaters</b>, making them a great way to get <b>supplement heating</b> into a room when you have pets, small children or combustibles near by.<br /> <p><br /> <br /> <p>One of the big questions that comes up with these <b>oil filled heaters</b> is what to do if they start to leak. The answer is that if the<b> oil heater</b> starts to leak then it is no good anymore and needs to be disposed of. These<b> heaters are filled with oil</b> at the factory and then are sealed tightly. Because of this there is no need to ever <b>refill the heater with oil</b> again. The heaters are sealed with the proper oil inside for the <b>best heating efficiency. </b> <br /> <p><br /> <br /> <p>So what this means is that if you have one of these <b>oil filled radiator heaters, </b>you will never have any <b>maintenance</b> or worries about <b>adding oil to the heater</b>. But if there ever is a leak then the heater is also no good and will need to be throw out and replaced. Very few of these <b>oil filled heat units</b> ever leak, but as is always the case there are always some that do.<br /> <p><br /> <br /> <p>A word of caution about heating efficiency. Always remember that when <b>heating with electricity</b>, the <b>laws of physics</b> always apply. <b>For every 1 KW of electric you will only ever get 3415 BTU's of heat.</b><br /> <p>There is no way to get any more or any less than that, so if anyone tries to tell you that their electric heater is more efficient then the next one they are not telling the truth.<br /> <p><br /> <br /> <p><br /> <br />
on Jan 12, 2011 | Heating & Cooling
Hi Our Delonghi Rapido heater has just started leaking oil, maybe a mL or 2 a day. Can this be repaired?
When a compresser leaks oil it is dead. If this is an air/heat unit you are out of luck. If anything I said does not match the facts of your system disregard my comment.
Jul 18, 2011 | DeLonghi 6507L Oil Filled Radiator Heater
Reposting: I have a lakewood oil filled radiator heater that will NOT turn on. Is there someplace or something I can do to have it fixed?
Depending on its age, you can return it to the place of purchase. Because the cost of repair will almost certainly exceed the cost of replacement, it is not a practical option. If you have a friend who is comfortable with electrical systems, you could try that. There are a few brands of oil filled heater that have recalls. The consumer safety bureau or the manufacturer may have information about a recall on your product. This is a good time of year to purchase a new one as many stores are just starting sales on heating appliances. Farmerbear at FixYa
Oct 23, 2010 | Lakewood Oil-Filled Electric Radiator...
It is completely dead. where can I find the fuse
How do you know that your unit has a fuse? If it does look at it and give me the information off of it and I can probably tell you where to get it.
hardrocko
Feb 05, 2010 | Black & Decker BDOH100 Oil Filled Radiator...
I have an oil filled radiator heater. The brand name on the cover is TouchPoint. It looks like the control and form factor of the DeLonghi brand of oil heaters. The unit was made in China. It was tipped...
I am about to replace the switche on my DeLonghi, but have not received it yet. If you can wait a few days I will post the wiring points here. I'm cold too!
Jan 06, 2010 | DeLonghi Heating & Cooling
Honeywell HZ-709 oil filled radiator heater-all controlls work but no heat produced. Possible reason?? Thanks
There is a bottom element and a top element so the elements could be dead.
More likey, there could be no power coming from the wall - there are switches on the front that need to light up or the thermostat could be set to off.
Dec 07, 2009 | Honeywell HZ-709 Oil Filled Radiator...
Thermal fuse on neutral wire burnt out.
i would not do what you are stating you may have a dead short and create a fire hazard
Apr 11, 2009 | Lakewood 7101 Oil Filled Radiator Heater
Heating & Cooling Logo
176 people viewed this question
Top Aloha Housewares Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
Are you an Aloha Housewares Heating and Cooling Expert? Answer questions, earn points and help others
