Question about HP PSC 1350 All-In-One Thermal Printer
Where can i find my printers toolbox? i want to check the level of my inks.
  • ambee Oct 06, 2007
    ok, i found a way to check it through my HP director, but for some reason, that wont open up? How to fix that?
  • 432 Answers
The ToolBox program needs to be downloaded from the HP website. But if you already installed the program, it should but under the programs menu. http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=306888&lc=en&cc=us&dlc=en&submit.y=9&submit.x=11&lang=en&cc=us
Posted on Oct 06, 2007
SOURCE:
Where do I go to find how much ink has been used
To check the ink levels from the printer control panel
1. Press Setup.
2. Press the down arrow button to highlight Tools, and then press OK.
3. Press the down arrow button to highlight Display Ink Gauge, and then press OK.
The product displays a gauge that shows the estimated ink levels of all cartridges
installed.
4. Press any button to return to the Tools menu.
To check the ink levels from the HP Photosmart Software
1. In the HP Solution Center, click Settings, point to Print Settings, and then click
Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Features tab, and then click the
Printer Services button.
The Printer Toolbox appears.
2. Click the Estimated Ink Level tab.
The estimated ink levels for the ink cartridges appear.
Replace the ink cartridges
Apr 14, 2012 | HP Photosmart C6380 All-In-One InkJet...
How to check ink levels in a HP officejet J4580 printer
Checking ink levels
  1. open HP solution center on the computer desktop screen
  2. click on settings on the bottom
  3. click printer toolbox
  4. click the estimated ink levels tab
or
  1. on the printer control panel,push the wrench button
  2. press the right arrow to go to print report
  3. push OK
  4. select self test
  5. push OK
It will print a page with color bars signifying correct ink levels.If a color bar is blank it means it's empty or depleted and needs to be replaced
Jul 21, 2011 | HP OfficeJet J4580 All-In-One Laser...
I cannot check the level of ink in my hp 5610 model printer
You need the HP Toolbox software: Follow these steps to check the ink levels in the Toolbox . The Toolbox is part of the standard printer software. Depending on the version of Toolbox on your computer, the appearance of the Toolbox features might vary. NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, consider having a replacement cartridge available to avoid possible printing delays. Print quality deteriorates as cartridges run out of ink.
  1. Click Start .
  2. Click Printers and Faxes .
  3. Right-click the icon for your printer and then click Printing Preferences .
  4. Click the Features tab.
  5. Click the Printer Services button. The Toolbox window opens.
  6. Click the Estimated Ink Levels tab. A window opens that indicates the estimated ink level of each cartridge.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 08, 2011 | HP Officejet 5610 All-In-One InkJet...
How do i check the ink levels
To check the ink levels from the control panel
1. Press Setup.
3. Press the down arrow button to highlight Display Ink Gauge, and then press OK. The product displays a gauge that shows the estimated ink levels of all cartridges installed.
1. In the HP Solution Center, click Settings, point to Print Settings, and then click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab, and then click the Printer Services button.
2. Click the Estimated Ink Level tab. The estimated ink levels for the ink cartridges appear.
Dec 08, 2010 | HP Photosmart C6380 All-In-One InkJet...
There is no icon on the taskbar, and I cannot figure out how to check the ink level.
The HP Toolbox can be used to check ink Levels
  1. Right-click the taskbar printer icon .
  2. Click Open HP Deskjet 5550 Series Toolbox .
  3. Click the Estimated Ink Level tab.
  4. Check ink levels (estimate only, actual ink levels may vary)
Sep 23, 2010 | HP DeskJet 5550 InkJet Printer
How do i check ink levels please? HP C6380 printer
  1. Click Start .
  3. Right-click the icon for your printer (c01532298.gif ), and then click Printing Preferences .
Regards
Riztech
Aug 28, 2010 | HP Photosmart C6380 All-In-One InkJet...
How do you check ink levels
Introduction This describes how to check the estimated ink level in the cartridge. NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, keep a replacement ink cartridge available to avoid possible printing delays. Ink cartridges do not need to be replaced until print quality becomes unacceptable. Checking ink levels Perform the following steps to check the estimated ink levels: NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
  1. Open the Printer Toolbox . There are two ways to do this:
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink. Figure 1: Estimated ink levels
Nov 23, 2008 | Office Equipment & Supplies
Ink Level
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.I hope this Solve your issueKhaled
Oct 21, 2008 | HP PSC 1600 InkJet Printer
I have an HP D5360 Printer. Please tell me how to see ink cartridge content levels.
you have to install the software first to see the ink level.If the soft ware is installed then follow the following
Checking ink levels
  1. In the HP Solution Center, click Settings , and then click Printer Toolbox .
    NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box , click the Features tab, and then click Printer Services . The Printer Toolbox appears.
  2. Click the Estimated Ink Level tab. The estimated ink levels for the print cartridges appear.
Apr 03, 2008 | Office Equipment & Supplies
Please tell me how to check ink levels on my HP D5360 Printer.
Checking ink levels
HP PSC 1350 All-In-One Thermal Printer Logo
157 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
