Question about Canon ZR400 Mini DV Digital Camcorder
Canon ZR200 Love my camcorder - BUT I am having a problem with it; - 5 Horizontal lines appear in my movies. - Tried an old cassete that I know works and the same lines appear. - I cleaned it with a mini DV head cleaner but still the horizontal lines appear. - Can you help? Thank you!
  • watsonfamily Oct 16, 2008
    gray horizontal lines are showing up on my display when I play back. They don't appear on the screen when I am recording. Help...
Hey,
I just started to have the same problem, 5 grey lines and intermittent audio. I the settings and i tried different tapes and No Joy. Then I tried to record onto an old tapes to see if the new recording would do it and the camera showed me a strange icon for exposure. I set the exposure back to 'Easy' and Viola, I recorded and the playback is now clean. Even old tapes play OK now...
The settings must have gotten wacked somehow. I glad it worked out, good luck.
Posted on Oct 13, 2007
I still have 5 horizontal lines across my screen is there anything else I could do
Posted on Oct 04, 2008
Thank you so much Ted S. I was just about to send my ZR400 in for repair with this same exact problem when I found your post. It worked perfectly. I cant thank you enough. Thank you!!!!
Posted on Mar 21, 2008
SOURCE:
Can I hook up to the DW 100 Canon burner with my ZR200 to burn mini tapes on DVD?
No. The Canon USA web site says the Canon DW-100 has a USB terminal and works with "USB 2.0 Hi-Speed (with compatible Canon camcorders only)." In other words, the Canon DW-100 burner works only with Canon's USB 2.0 camcorders. I have a Canon ZR200. The ZR200 has Firewire 400 digital video output, not USB 2.0 output. The USB port on the ZR200 is ONLY for still images. Video will not and cannot be output through the USB port on the ZR200. (Page 121 in the ZR200 manual mentions using the USB port on your camcorder for transferring still JPEG images to your computer.) You need a DVD burner with "DV Input" (also called Firewire 400 or IEEE 1394) to hook up your camcorder to burn Mini-DV tapes onto DVD. The Sony VRDMC10 Stand Alone DVD Recorder/Player has DV Input. The ZR200 camcorder did not come with a Firewire cable, but you can buy one at any electronics store or at a cheaper price online. Make sure that you get the right kind of Firewire cable, 4-pin to 4-pin or 4-pin to 6-pin, whatever the DVD burner you choose requires. (Your ZR200 has a 4-pin DV port on the camera's end.) USB 2.0 Hi-Speed (with compatible Canon camcorders only)
Mar 15, 2011 | Canon ZR200 Mini DV Digital Camcorder
Why does my ZR200 have horizontal bands on playback
Try setting back to Exposure to EASY and it should work fine.
Let me know if this does not fix the issue.
Thank you for contacting FixYa
Nov 18, 2010 | Canon ZR200 Mini DV Digital Camcorder
Horizontal grey lines on tape playback
please state the age of your devices. It can help a great lot in solving your problems. The lines that you get aren't continuous, are they? They appear to be going up and down, are different sizes and shift as the tape plays, yes? well, this is simple. You need to clean your recording head.
Sep 23, 2009 | Canon ZR200 Mini DV Digital Camcorder
Grey Lines across video display
Same thing is happening to mine, it's not the minidv because i tried that one on a diffrent camera and it works fine. It's got to be a setting or something. If anyone can figure it out, that would be great.
Sep 01, 2009 | Canon ZR200 Mini DV Digital Camcorder
Canon NTSC zr200 Mini DV and lost the software to convert the files
download Canon software from here
http://software.canon-europe.com/
May 28, 2009 | Canon ZR200 Mini DV Digital Camcorder
Canon zr200
The heads are dirty, purchase a soft head cleaning tape and run it for 25 secs.
Dec 26, 2008 | Canon ZR-950 Mini DV Camcorder
XP will not recignize my ZR200 as a valid input device
On your computer, go to <start><my computer>. Right click on My computer and select "properties". Select "hardware" and then "device manager". On the drop down menu, select the hub in question and be sure it is not "disabled". Also be sure that the power options on this hub "never expire", as Windows default sets a given time for this....accordianman
May 18, 2008 | Canon ZR200 Mini DV Digital Camcorder
Transfer video into dvd on computer
Well what i did was i got a ati video card that had built in video inputs (and it also had a tunner) plugged the camcorder up to it and recored what was on the camcorder on to the pc (ati came with a utility that made this possible). after the movie was on the PC i recored it to dvd with nero. I think you could also use movie maker that comes with windows xp
Dec 05, 2007 | Canon ZR200 Mini DV Digital Camcorder
Canon ZR400 Mini DV Digital Camcorder Logo
699 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
