Question about GE JBP70SKSS Stainless Steel Electric Kitchen Range
Ge profile JCS966SD1SS, Electric Kitchen Range,
HI, the clock doesn't work but timer ok. The oven doesn't work at 300 and more. Thank You
  • 7 Answers
SOURCE: GE Profile Spectra XL 44 gas oven
If you can smell the gas when you turn on the oven, it may be on a separate igniter that has gone bad. I would check this first. If you are not getting gas to the oven, there is possibly an issue with the supply line.
Posted on Sep 28, 2007
the dr
  • 447 Answers
SOURCE: GE JSP69 Electric Kitchen Range Controller Problem
Yes replace the EOC (electronic oven control) after you verify that the board is getting power (no burned wires, no loose connectors) there usually is not a loose wire and the clock has failed. www3.sears.com for parts i can help with parts lookup and sourcing if needed will need complete model #
Posted on Oct 07, 2007
  • 7 Answers
SOURCE: Frigidaire electric range
is there voltage going to the erc (electronic range control)?
Posted on Feb 09, 2008
  • 15 Answers
SOURCE: GE Profile Gas Range, serial at235522p, model JGBP79WEW1WW
If this is a newer range, the instructions to recalibrate should be in the manual that came with the stove
Posted on Oct 07, 2008
SOURCE: GE Spectra range
I just moved into a new apartment and my stove wasn't working properly. After reading the very helpful information posted by kd3ke, I decided to turn off the breaker to my stove, take off the back covering, and check out what was back there. I was experiencing the same problem as posted.... the burner light, oven light and clock were all working however, the burners did not get hot nor did the oven. After taking off the back panel, the cord did have just as he stated, a black, white, and red wire however the plug attatching to the stove did not have cordinating colors. It was just a grey cord with 3 copper wire heads. It seemed to me that the cord was twisted and therefore everything was backwards. Since I was relying on his post, that would explain why the stove still did have some power, just not all, because the voltagages were wrong. I flipped the three cord wires, reconnected them to the stove and then plugged it in and turned on the breaker... everything works now!!! :) I don't know if this will help anyone else since it may not be the same problem if your stove was working properly previously, but it fixed the problem for me since I had just moved in.
Posted on May 24, 2009
Oven wont work everything else is fine
As your oven is electric there is a heating element in the oven, have a look in the oven to find it and check the little plug in caps on the end to make sure they are not loose. If they,re ok check the switch on the front panel sometimes the knob comes loose on the spindle if that's all ok it may be the switch has failed. Good luck.
Jun 16, 2014 | GE Profile JGSP44 Dual Fuel (Electric and...
Purchased GE Profile dual fuel range 6 months ago. Clock has always run fast and today the entire touchpad control went dead. The oven light works as does the gas burners. I am not sure if I inadvertly...
Unplug the unit and wait 2 FULL MINUTES before plugging it back in. That will reset the circuit board and you should be good to go. If it doesn't work, my bad!!!!!!
-AGK
Apr 17, 2011 | GE Profile JGSP44 Dual Fuel (Electric and...
The control panel does not work at all for our oven, the time is displayed, but the oven will not turn on. The range works fine. I think I need to reset the control panel? for model GE Profile J2B918SELSS
If there is no reset on the control panel, which there normally isn't, you will probably have to get a new one if you wish to use auto. function in the future. If you don't require auto. function it is a simple procedure to by-pass the timer so the oven will work. With the timer by-passed the clock will still function.
Feb 11, 2011 | General Electric J2B918SELSS Stainless...
KENMORE ELECTRIC RANGE 95032. EVERYTHING WORKS BUT OVEN DOES NOT HEAT.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 25, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
Oven doesn't work - broiler, clock timer does
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Jun 05, 2010 | GE Profile Spectra JGBP79 Gas Kitchen...
GE XL44 Gas Range JGBC15GER2. Can't see clock on stove; very dim. Do I need to replace the clock/timer?
yes it is called a electronic oven control go to ap wagner.com and enter the model number and you can get priceing
Oct 18, 2009 | Whirlpool GR460 Electric Kitchen Range
Oven showing f7 on lower oven
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning . F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
It looks like you have a function button pad stuck or a bad clock.
Unstick button or replace electronic range control. you can get the required parts at www.repairclinic.com thanks.
Jul 11, 2009 | GE Profile JB968 Electric Kitchen Range
Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE Profile Gas Range with a double oven. The bottom oven takes 20 minutes to warm up to 300 degrees. Is this normal? I was told the bottom oven is electric, which I haven't used electric in years,...
my oven does the same thing. i do not believe that the oven is electric though. the only electric part on my oven is the control board. if the oven was electric it should heat up much sooner than that,
Apr 14, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Sep 25, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
GE JBP70SKSS Stainless Steel Electric Kitchen Range Logo
93 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
