Question about Kenmore 22622 Top Load Washer
Washing machine spin cycle
I have a Kenmore washer that is about 4 1/2 yrs. old. I don't use it hard as there is just husband and me. For the past few months, a couple of loads per week, it does not competeley spin the clothes dry enough. It makes no weird sounds. I will have to run the spin cycle a second time in order to get the clothes spun out enough to dry in the dryer. Did I just get a lemon that is on its way out or can we fix this??
  • 209 Answers
If a second spin dries the clothes as it should then i would be looking for blockages in the pipes that either go to the pump from the drum, or go from the pump to the outlet connector on the wall or sink, hope i have been of some help, if so please rate me, thank you
Posted on Oct 07, 2007
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
Sep 6, 2013 - Uploaded by
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from
Nov 05, 2015 | Kenmore Washing Machines
Kenmore washer
You can check the belt. It's posible to be worn out.
All the best !
Oct 02, 2017 | Kenmore Washing Machines
My Kenmore he front load washer stopped at the rinse and spin cycle. I don't know the model but it only a few years old. It made a load noise before stopping. I attempted to get it going again wit
Kenmore front loader. stopped at rinse. First ck to see if you washer works at different settings if so its very possible its your timmer or what called the wig wag or solonoid this switches the machine to spin & rinse. A basic service call should resolve your problem.
Jan 30, 2012 | Washing Machines
Washer doesn't spin ; model 3200 bosch; 4 yrs. old; other cycles work
Although all brands are different in design, the basic concept is the same. When a machine won't spin, there are several things to consider:
  • Is the belt broken? Loose?
  • Does the lid switch click when closing? (see video below)
  • Does the spin solenoid engage? (1984 and before)
  • Drive coupling worn out? (on some newer Whirlpool & Kenmore top loaders)
  • Clutch worn out?
  • Current to motor? (Use voltmeter to check)
Dec 03, 2009 | Bosch WFMC 3200 Front Load Washer
Tub not working in spin cycle
Replace the brake/clutch on the transmission.
You can DIY.
May 25, 2009 | Kenmore 24922 Top Load Washer
Kenmore washing machine will not drain
Replace the timer.
This is a neutral drain machine. If there is no natural pause in the timer at the end of the rinse cycle the timer is bad.
Mar 13, 2009 | Kenmore Washing Machines
Washing machine will not spin
Hello,I know that no one likes bad news but it sounds like the transmission has gone faulty.Be sure to check the warranty if it's within 5 or 6 yrs. old.Hope this helps.
Dec 29, 2008 | Kenmore 22622 Top Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Kenmore 80 series model no. 110.26842691
Your agitator may be fine but how is your washer behaving is it trying to perform two acctions at one time like spinning and agitating at one time the tarnmission may be locked up
Jan 21, 2008 | Kenmore 24032\24036 Top Load Washer
chances are the pump may have something in it or the drain line is kinked a little front loader machines have a clean out on the pump that you can get to buy taking the lower front panel loaders you have to pull access cover in the rear and pull hose off and check for blockage also check belt tension and quality of belt
Dec 16, 2007 | Maytag MAV7600 Top Load Washer
Kenmore 22622 Top Load Washer Logo
126 people viewed this question
Sal De
 Brian Main
Brian Main
