You may be able to get updated firmware from Alba at the same time, but try to find out what effect it may have before you use it. Some updated firmware removes functions as well as making improvements.
Good luck
Anyhow have a good read of that forum
Was this helpful?
Yes
No
Solution #3
posted on Aug 09, 2005
Putty - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Just remembered...the Datasafe disks that work with this player MAY be the Datasafe Branded (BLUE DYE) ones available from SVP www.blankdiscshop.co.uk . This is just guesswork based on what I've come across. Check it out on the forum.
my dvd alba player just keeps loading and says incorrect disc format. It makes clunking noise. can i...
(More)
my dvd alba player just keeps loading and says incorrect disc format. It makes clunking noise. can i fix it
Hi people, my TV won't play DVDs, it takes a few minutes to display the menu screen from the DVD but...
(More)
Hi people, my TV won't play DVDs, it takes a few minutes to display the menu screen from the DVD but when I press play the screen goes blank with a couple of white lines at the top, then after a few minutes it goes back to the main screen as if no DVD is inserted. Can anyone help solve this problem? Thanks.
The remote control for my TV, and my Sky remote controller, both switch off my Alba DVD73 when I use...
(More)
The remote control for my TV, and my Sky remote controller, both switch off my Alba DVD73 when I use either of them to adjust the sound when watching a DVD!
I'v read the manual and have gone trough both procedures but still the remote will not operate my tv...
(More)
I'v read the manual and have gone trough both procedures but still the remote will not operate my tv why is this as it is suppose to operate any tv. Can you help. Cheers John
I have a Alba DVD 114, maybe 3 years old but I have not use it much. For one reason or other the...
(More)
I have a Alba DVD 114, maybe 3 years old but I have not use it much. For one reason or other the original plug is lost. Now I have put a new plug on it but it does not work. Is neccessary to use a plug of same kind as the originallly one? I live in Reykjavik, Iceland
