Question about Tower Aloha Breeze Fan
Fan will not oscillate anymore. it makes a clicking noise like it's stuck
    Top Expert:
  • 12,223 Answers
Follow this steps and fix it. God bless you
f the fan doesn't work at all, make sure power is on at the outlet, then test the power cord . Test the motor and replace it if it is faulty. Clean and test the speed-control switch and service it if it is faulty . If the fan works on only some speeds, clean and test the speed-control switch .
If an oscillating fan doesn't move from side to side, check the clutch knob, then the gear assembly. If the gear assembly is faulty, you can service it (see below).
If the fan blades turn slowly, check the blades for a loose hub and tighten if needed. If the fan shaft is noisy or dry, lubricate it.
Posted on Nov 14, 2013
SOURCE:
Comfort zone tower fan won't oscillate
Remove bottom and check if gear is stripped or very dirty so can't turn.
Dec 14, 2013 | Comfort Zone 30 In Oscillating Tower Fan -...
Rattle
Usually it's the fan or fan motor, or the rotating motor making the noise. Usually you can pull it off or clean it...AND the bearings, which could be crudded up.
Dec 04, 2013 | Comfort Zone Cz488 Ceramic Oscillating...
Lasko 4920 won't oscillate...
Buy a new fan or do without the oscillation untIl it breaks worse, thenndiscard or pay a lot to have a new part made. Lasko will nOt and doesn't stock the replacement Teflon partial gear that wears out. Planned obsolescence!!! Buy a Honeywell or more reputable fan with a better warranty Hint: they don't exist anymore!! Caveat Emptor!!!!! THERE ARE NO MORE BUSINESS ETHICS IN AMERICA!!!!!!
Sep 12, 2010 | Lasko High Velocity Space-Saving Blower...
Oscillating table fan makes banging noise when rotating
mcdevito75 here, Sounds like that oscillating swtich is either a little loose or could use a drop or 2 of 3 in 1 oil. Try to twist offf the oscillating swatch button and see if you can tighten it or put a drop of oil on it.
Jul 24, 2010 | Holmes Products Holmes HASF1304S-UC 12",...
Fan makes a whining noise as though it is struggling to turn
Check the bushings for alignment and lubrication. Dried accumulated dirt makes the rotor stuck and hard to turn. If this is the case, remove the oscillation gear assembly at the back of the motor. Lubricate the front and rear bushings while manually turning the fan to loosen it. Do it until the fan smoothly spins. You can use engine oil as lubricant or even cooking oil but don't let it flood the motor assembly.
If the fan smoothly spins when manually turned but still makes a whining noise when plugged and switched on, align the bushings.until desired result is obtained.
Note: These procedures are based on my actual experience and makes a perfect result. Extra effort is the only investment.
Aug 20, 2009 | Schaefer Outfitters Dryers
I own two Marvin Floor / Box Electric Fans. It's
its extremely simple... when it does that put your hand on the oscollator cover and hold it with light pressure for a couple seconds then let go. it should work
Jul 10, 2009 | Marvin Dryers
Fan makes clicking noise when oscillating
inside the motor there is a nylon gear that is broken. the oscillation operates off a gear connected to the motor drive.
Aug 27, 2007 | WeatherWorks CH-1850SFW Riviera Stand...
Tower Aloha Breeze Fan Logo
673 people viewed this question
Top Tower Dryers Experts
Jay Finke
Jay Finke
Jason Smith
Jason Smith
Are you a Tower Dryer Expert? Answer questions, earn points and help others
