Question about Epson Stylus Photo R1800 InkJet Printer
Epson stylus photo r1800
I can't turn off my printer by powering off. i'll turn off if i unplug. it started with a paper jam; but the paper got taken out and all the red flashing lights are not longer flashing. I called epson technical support and they told me it is a hardware problem (after a series of test, like pressing on the ink button or the paper button). they recommend i find a service person to fix or buy a new printer--both of which i don't really want to do....but is there anything else i can do to find out and if i can fix teh problem myself? i.e replace a part? if i go the service person route, what should i expect in terms of cost? thanks, adrienne
    Novelist:
    Champion:
  • 382 Answers
Return it to them. If it is under warranty, they should replace it.
Posted on Oct 23, 2007
Epson R1800 won't start up
Unplug the power cable from printer while the printer is powered on.
Press and hold OK and HELP buttons while plugging in the power cord.
Wait for the screen to go black or blank before releasing the keys.
Just turn on the printer and configure your printer new
If you need any technical help on printer then you can reach at here
Mar 06, 2013 | Epson Stylus Photo R1800 InkJet Printer
I have an Epson stylus photo R1800 and will not feed paper?
The paper pick up fingers and rollers get smooth and polished with use and then slide on the paper. Clean the rollers and pick mechanisms with isopropyl alcohol to rejuvenate them and restore their grip on the paper. Do this as far along the paper path as you can get, using Q Tips where necessary and turn the rollers to clean their whole surfaces.
Mar 26, 2011 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus R1800 refuses to accept art paper through the single sheet feeder at the rear When loading the paper the unit will pull it into the correct location and then on print command it backs the...
First check to see if there any any bits of paper stuck by checking the front and the rear feeder.
Also consult your manual to see if it accepts that thickness of paper.
It can be found here:
http://files.support.epson.com/pdf/r1800_/r1800_ug.pdf
The steps in the manual to clear a jam are on page 89 and types of accepted paper are on page 11.
Hope this helps.
Mar 20, 2011 | Epson Stylus Photo R1800 InkJet Printer
Epson R1800: printing 13x19" velvet paper. hand feeding into rear of printer. keeps saying eror, or paper jam or ... then finally just spits the paper through and out.
why print velvet paper? the problem is the velvet would be too thick and it would jam the print heads because when they run over the paper it would pull the velvet and it would get jammed i don`t think you should print velvet
May 16, 2010 | Epson Stylus Photo R1800 InkJet Printer
R1800 printer turns on only when I hold the power
first, turn off the printer. unplug it from the power source. while its off, open the printer cover, so you could have an access to the inside of the printer, check for any obstruction, paper jam or any foreign object. if you found anything, take it out, if not, still turn on the printer after checking.dont forget to plug it in the power source, if the issue persists, call epson to get a replacement printer if the product is still 1 yr. from the date of purchase, if it is more than a year, most probably, thats out of warranty,
Feb 15, 2010 | Epson Stylus Photo R1800 InkJet Printer
When I press print on the computer, the Epson R1800 just sends the paper through the printer without printing on the paper.
It may have taken care of itself. Problem occurred when I was using letter sized sheets. Switched to 11x17 sheets and after running a couple of these through the printer, it started to print again.
Sep 08, 2009 | Epson Stylus Photo R1800 InkJet Printer
TOP RED LIGHT FLASHING. PAPER STUCK PART WAY INTO FEEDER. HOW DO I FREE THE PAPER? PRINTER STOPPED MID JOB BECAUSE INK NEEDED REPLACING. THE INK HAS BEEN REPLACED
I know by human nature that the situation was taken care of but if not
.Press abort or cancel printjob
Worst case turn off the printer and with a constant tug remove the paper MAKE SURE POWER OFF THE PRINTER...
Aug 11, 2009 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
78 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
