We found a little water in the refrigerator this morning so we did
what you said. There was a lot of lint behind the cover but the
tube seem to be clear. We cleaned out all the lint and blew through the tube to make sure it was clear. Now I guess we wait
and see if that did anything although I don't see how we accomplished anything. What do you think?
We want to thank you for all the help we recieved. It's a pretty
good idea that it's a frost problem. We did find a little frost on
the vegetable bins when we found the puddle. We feel sure that
we can solve the problem now. Again thank you so much.
Just wanted to follow up on your refrigerator problem and see what you found out.
Thanks/Mike
That narrows down the possibilities of what is wrong then. Clean out your defrost drain. It is probably partially clogged causing the defrost tray in the freezer to overflow into the air duct going into the refrigerator. Pull the fridge out and remove the back cover. You should see a rubber or plastic tube from the cabinet going to a pan underneath. Make sure there is no scum built up in the end of the tube. Post back with the model number if you need further help so I can give more detailed instructions.
If you could blow through the tube, then it was probably ok. The underlying problem still almost has to be defrost water not going where it is supposed to, or humidity condensing on a cold surface somewhere. Are you noticing moisture or frost in the freezer more than you used to? Check your door seals for any air leaks. If it is very old, you may have a rusted out drip tray under the evaporator core. Alot of the older refrigerators used coated tin for them instead of aluminum like they do now. If you have the model number I can look it up and see if I can find out if there have been any service bullitins put out about your problem.
Thanks/mike
