Can't Get solid sound out of Solid State Amp! Tried Everything!
I just moved, and when I plugged my amp in, in makes a crinkely decaying sound when i play. The reverb isn't coming thru either. When you used to turn it off, you would get a crinkely decaying sound before the signal cut out completly, now it's that same sound all the time. *steps i took to fix it* - changed the fuses, no change. -made sure speakers not problem, re ran them, lined it out thru out and headphone, no help. -unscrewed and removed amp part, checked all connections for loose sauder, no change. Help!!!!! thanks!
Try to run a patch cord from the effects In to the effects out (possibly labeled graphics in & out).If this solves the crackling, the problem is the input jack normally closed connection.
Posted on Oct 17, 2007
  • 4 Answers
A PROBLEM LIKE THAT SOUNDS MORE TO ME LIKE THE MAIN CULPRIT WOULD BE YOUR POWER SUPPLY WHOSE MAIN FUNCTION IS TO KEEP THE AMPLIFIER FULLY OPERATIONAL. SEEING THAT U SEEM NOT OT BE ANY TECHNICAL GURU, ELECTRONICALLY, I WOULD SUGGEST THAT U REFER THE PROBLEM TO LCAL QUALIFIED AGENTS.
Posted on Oct 09, 2007
Playing bar chord at A 5th fret fine move to 7th fret amp gets loud and pops. normal gain at 3 to 4 volume dwn wont do it
Sorry I remember now this is a solid state amplifier,
try electronics spray contact cleaner in the pots of the amp, you will need to unplug and remove the chassis of the amp to do this, there are little notches on the pots, that's where you want to spray, and work the nob back and forth completely, do this to all volume, treb, bass, etc... I know this will fix your problem because I have done this about 100 times servicing amplifiers, the way a solid state circuit works if the pots are dirty the circuit doesn't complete properly causing volume issues, really hope this helps?
Mar 04, 2015 | AMP Music
Reset instructions for a wls2f320 main breaker
Turn off all other breakers. And try reset again.
3-phase solid state breaker from Siemens
Contact siemens:
http://www.siemens.com/entry/cc/en/
Unfortunately the Siemens site does not show results for WLSF320, but has results for solid state circuit breaker:
http://www.siemens.com/corp/apps/search/en/index.php?q=solid+state+circuit+breaker&lang=&site=siemens_c_ww&lr=lang_en&as_filetype=&client=siemens_f_ww
Otherwise I cannot find .pdf file to help more.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 09, 2013 | Electrical Supplies
I have a small crate rx15 solid state amp. The
This is likely a power supply failure OR the amp chip is bad, It is probablly in the TDA family such as a TDA2050
May 15, 2010 | Music
Amp doesn't do anything.
If you hear a pop when you turn it on and the squeak when turning off most of your amp is probably working.Depending on whether it is a tube or solid state amp there are several things to consider some being as simple as a deadLED or bulb in the pilot light and a defective input jack to as complicated as a dead power supply to the preamp circuitry. If you are not familiar with safety procedures and electronic trouble shooting and have no test equipment and the schematic you might be better off having it serviced. Here is a link to a troubleshooting guide:http://www.geofex.com/ampdbug/ampdebug.htm A lot of the info can be applied to solid state amps. Hope this helps.
Jan 19, 2010 | Music
No sound from speaker, but works with external speaker plugged in
It sounds to me like you have blown the internal speaker.
Jun 17, 2009 | Music
Fender Stage 100 dsp, solid state amp volume (or power) problem
The Deluxe may have more efficient speakers....which would cause it to sound louder. Also, the EQ settings could play a part in this. If the EQ's aren't set the same there could be a noticeable difference in sound.....usually the mids can have quite an effect on overall amp volume....
May 31, 2009 | HHB Radius 50 Tube Amplifier
Crate RFX65 solid state guitar amp has power but no sound
Hikonartist87
Sounds like the amp has developed a problem. If you had it LOUD then you may have popped a speaker or an output stage. You say it still makes the plugging in noise, what happens when you touch the end of the jack lead whilst plugged into the amp. do you get a burst of clean hum?
regards
robotek
Jul 06, 2008 | Audio Players & Recorders
Shows to be stuck in Standby.
hold down the enter button and the advanced surround button for 5 seconds or so and the amp will restart, the display will come up and hopefully it will be ok. its often caused by using speakers under 8 ohms, or damaged speaker cables etc
Mar 20, 2007 | Pioneer VSX-D712 Receiver
My amp light is on but no sound from speaker
If the amp light is one and the protector light wasent on then I bet you blew your speaker??? take an ohm meter, measure each speaker with nit disconnected from the amp.. If they all measure what there suppose to( like 4 to 8 ohms) then the amp blew out and unless you have training on solid state electronic repair, you should seek a pro to fix the amp for ya.. Good Luck
Jun 28, 2006 | MTX 6001 Car Audio Amplifier
59 people viewed this question
 Grubhead
Grubhead
