Question about Yamaha RX-V2400 Receiver
Rx-V2400 Shut Down
I Turn On My receiver, And it Clicks and Then Shuts back down.
  • klewless Dec 07, 2007
    My receiver exhibits the same problem - I turn it on, then it clicks, and turns off. Currently, there is nothing attached to the unit and it's still keeps turning itself off. Is this something that I dare try to repair myself?
  • fQM3 Jan 30, 2008
    I have the same problem that just appeared recently. I moved my system down to my basement where it is much cooler when the heat is off. Same thing - I turn it on then it turns itself off.
    However, when I turn on the heat and let the room temperature come up to about 65 degrees, the unit will turn on and will stay on.
    I checked the manual for operating temperatures but did not find any reference to this.
    Any suggestions?
    Thanks in advance for your help.
My rx-v2400 also shuts off soon after turning it on. Problem started 3 months ago. I've checked speaker connections, sent the unit to be repaired (3x), tried to get help from Yamaha. Bottom line...after $350 in repairs and endless frustrations, I've decided to buy a new receiver (not Yamaha).
Posted on Feb 17, 2008
Any suggestions?
Posted on Jan 30, 2008
    Problem Solver:
  • 12 Answers
Hi Seems like you have a shorted output channel, remove all your speaker connections and try again, if the problem persist, good chances are that you need to replace a couple of power transistors, let me know if you need more help, I've fixed some Yamaha amplifiers with this problem Good Luck Miguel
Posted on Oct 06, 2007
  • 1 more comment
  • Miguel Soto Feb 08, 2008
    Hi
    Replacing the power transistors requires some skills so you don´t damaged the PCB, I suggest touse a desolder wick and small suction pump.
    To detect which transistor are damaged you can use your meter, set it to ohms and connect the black lead to ground and the red to the leads of the transistors, power transistors are kind of big and are fastened to the heat sink, if you find one transistor shorted, usually the next one that belongs to the same channel is shorted too, and you must check for other transistors shorted and some resistors burned, there is also a zener (5.1v)diode that can be shorted. and other component that for sure you must replace is the 0.22 ohm 5W resistor it tend to open.
    By experience I check all the transistors specially the small one that is located between the two big ones and replace this one with SAME number, otherwise your receiver won´t works.
    I hope this information helps.
  • Miguel Soto Feb 15, 2008
    Hi
    For the temperature problem you can check the resistors located near to the speaker post PCB, you will find some ceramic capacitors too, check them. I have found some of this components with a low impedance, that causes a draw of current from the power transistor just like if you were playing music at very high volume,
    Hope this help
    Miguel
  • Mozes Mislit
    Mozes Mislit Jan 28, 2013
    at what value of Ohm do u set multimetar ? how much value must be across zener diode ?
I have a yamaha, natural Sound Av receiver RX-V483, every time that i start the unit it will shut down after 5 seconds. thank you very much
It indicates an output load problem, dis-connect the speaker wires from the back of receiver. Next power on and turn the volume right down, if the unit runs, check for shorts in the speaker wires and speakers. But if it still shuts down "with speakers and wires dis-connected" one or more of the audio output ic's is shorted and will need a professional to assess the item.
Feb 02, 2011 | Yamaha RX-V463 Receiver
Receiver smoked, sizzeled and then quit
Throw on a couple of shrimp it and let us know when they're ready. You need a pro to look inside it.
Mar 19, 2010 | Yamaha RX-V2400 Receiver
Yamaha RX-V800 shuts down when any control button is pressed
What if you DON'T use the remote? Does it shut down when just using it?
If SO, you have a bigger problem.
If NOT, it sounds like the remote is hosed - sending a code to shut off.
Do you have another remote of any brand that you could set to do something simple, like change volume? Don't train it from the original, though, or it would do the same thing.
Feb 13, 2010 | Yamaha RX-V800 Receiver
120v plug in's on the back of my rx-v2400 will not send power to my mono block amps.
those are fused internally and made to power small items.the unswitched are constant power and the switched goes on and off with the power on the reciever.you have hooked it up to something that draws way to much power and more than likely blew the fuses.check the back by the sockets,they are rarely over 250 watts max.
Jun 12, 2009 | Yamaha RX-V2400 Receiver
System shuts off when the volume is moderate to high, now the system shut off and will not turn back on.
unplug the reciever for at least 15 minutes. then replug in all of your speakers making sure there is no bare wire showing. if the reciever doesnt ower on replace the fuse inside(make sure unplugged from wall)
May 17, 2009 | Yamaha RX-V661 Receiver
Yamaha RX V2400 keeps shutting off
When it shuts off, does it display anything on the front like "ck speakers" you could have a shorted wire or bad speaker. Sounds more likely than a bad receiver. Yamaha is pretty bulletproof in "self preservation" circuitry! about the only thing that takes them out is lightning and major power surges. I have been selling and installing Yamaha receivers since 1995 and have only ever seen one with a problem that was unrelated to power. and I've done hundreds. If your not using HDMI, and the Video portion of the receiver, I would definately keep the unit $ 1500.00 is no cheap receiver. Try disconnecting the speakers, then turn on the unit with a source connected like cable/sat/fios on then crank the vol and let it set, if it cuts out, yes you've got a problem internally, however, I would stronly suggest metering all of the speakers and wires for shorts. There is an internal fuse as well right near the power cord, you have to pop the top to get to it, If you have a multimeter check the fuse with resistance tone. If you get tone, you have a good fuse if not If you need to replace it. They can be found at Radio Shack etc. If the fuse is OK, chances are you've got bad transistor(s) and needs to go to service. Repair should be under 200, well worth it. If you have further questions, post a comment and I will get back to you ASAP. Hope this helps
Apr 21, 2009 | Yamaha RX-V2600 Receiver
Yamaha RX-V2400
Get another receiver! I had the same problem and had the power supply replaced $250 and after 3 months it started doing the same thing.  I just purchased a Pinoeer Elite VSX 90TXV.
Jun 04, 2007 | Yamaha RX-V2600 Receiver
Yamaha AV Receiver RX V2400 - Shuts off
yamaha receivers protect themselfs when the power transistors at the output section are shorted, I just posted what you can look for this failure.
Feb 13, 2007 | Yamaha RX-V2400 Receiver
Yamaha RX-V2400 Receiver Logo
612 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
CHP6PH1
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
