Question about Refrigerators
How to hook up Ice & Water dispenser on freezer door
We have lost the manual for our side by side Moffat fridge model # mrsc20kwxfwh and have moved it. We are now trying to re-hook up the ice & water dispenser but are not sure how to hook up to the water
How is the Drive Blade installed so it locks on the augur?
Posted on Jan 15, 2008
How do you turn off the ice maker if the water line is not connected? on the back of the fridge, it says to make sure ice maker is turned off so it doesn't run when water line is not connected. i do not have a manual and cannot find the ice maker off/on switch anywhere!
Thanks!
Posted on Dec 26, 2007
  • 473 Answers
The water valve is on the back of the refrigerator. The water line connects directly to that valve. If there is no line available then you will need to run one from a cold water line in the plumbing using a drill type (1/4") saddle valve on that pipe. Hope this helps. If you need more instruction let me know!
Posted on Oct 06, 2007
Model #WSF26C2EXY02. Why is ice maker not making ice?
When the ice-tray is full it pushes 'UP' a lever that shuts the water supply off. When you move the lever down all goes back to normal.
Oct 14, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice tastes bad
If It were me I would change the filter in the fridge, that always worked on mine.
Dec 03, 2013 | LG LRFD22850 Bottom Freezer Refrigerator...
Water underneath the freezer section
Please check for the water passage beneath the freezer. There will be a small pipe and there is a possibility that that pipe path is blocked with ice or dirt.
Mar 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
We have a Hotpoint side by side fridge. It always makes
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Dec 05, 2009 | Refrigerators
User manual whirlpoolfridge freezer 20rid3 sf i have lost user manual
Call Whirlpool. The number should be on model tag inside freshfood. Either upper right or upper left.
Sep 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker & water dispenser won't work
I recently found out that the water supply lines are coiled up inside behind the frige on the refrigerator side moving the unit will cause those coiled up lines to shift to the freezer side of the unit, causing a freeze up,take the cardboard lower back off and move those lines further away from the freezer side of the unit, as one of those coiled up lines are to chill the water for the dispenser and the other is supply for the icemaker, this should fix your problem, becareful not to move them too far away from the freezer side as they are meant to chill the water for the dispenser
Jan 16, 2009 | Frigidaire FRS266ZDSB Side by Side...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Refrigerators Logo
1,184 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
