Question about Health & Beauty
Maintenance on the clipper there are 2 red circles with a grove in them one on each side what are these for because I need to do the oiling maintenance and I do not know where to oil as I do not have a manuel or book for this product and I do not want to oil the wrong place and ruin it
  • Anonymous Sep 05, 2008
    needs resetting
  • 62 Answers
The only part of this clipper that needs to be oiled is the blades. To oil the blades hold the clipper with the blades towards the floor. Put a few drops of oil across the blades. Turn the unit on and to get the oil worked into the blades. Turn the unit off and wipe off any excess oil with a soft cloth. The blades should be oiled before and after each use.
Thank you for purchasing Andis.
Posted on Jan 07, 2008
  • 102 Answers
You could oil it all over and you wouldn't ruin it. Remove excess oil with a tissue.
Posted on Oct 06, 2007
My husbands clippers won't cut
Blades are NOT moving HOW TO Fix a broken Hair clipper ...
? 2:42
https://www.youtube.com/watch?v=DX4Xc47F_IE
Mar 29, 2015 - Uploaded by You can Fix It!!!!
... blade fix how to won't cut by adjusting the blade adjusting the play with the motor so ... Blades trimmer trim trimming cut cutting cutter trimmers barber ... dog clippers shear shears shearing shave shaver shaving buzz cut ...
My clippers hum like their working but dont cut - Fixya
www.fixya.com/.../t3222969-clippers_hum_like_working_but_dont_cut
Jul 25, 2008 - my clippers hum like their working but dont cut - Wahl Designer 6 (8355100) question. ... hair clippers repair. Apr 22, 2013 ' Shavers · 1 Answer ...Clippers jam and won't cut when trying to use attachments. Jan 11, 2009 ...
Clipper Maintenance - Rapid Edge
www.rapidedge.com.au/cat/maintclip.html
Clipper won't cut cleanly or easily. Lack of oil and dirty. Sometimes a hair gets caught between the blades. Lubricate and clean your Clippers regularly.
Dec 21, 2015 | Health & Beauty
I have an Oster Golden A-5 one speed that I bought 20 yrs ago. I have lost the manual and need to know if I can oil this unit and if so how? Thanks, Lorrietis
Here how you can oil your A-5 clipper, The button on the side of the clipper is the oiler, depress the button down with a small screw driver and while holding the button down, use Oster clipper oil it will take about 4 to 5 drops of oil. after you are finish wipe clean with paper towel and turn on your clipper, let it run for about 2 minutes. Turn your clipper off and you are done. We hope this will help you Thank You. Manny's Sharpening www.mannyssharpening.com
Apr 20, 2011 | Oster Golden A5 1-Speed Universal Motor...
What are the 2 slot screws on either side of the clipper for? Any maintenance needed in there?
I take it you mean the plastic srews? these are plastic caps behind which are the carbon brushes.
Feb 16, 2011 | Oster Golden A5 2-Speed Universal Motor...
Where do I apply greeze to my clippers
I believe you are referring to oiling the blades unless you are talking about when you take it apart fully and put it back together. For general usage and maintenance:
Oiling of the blades should be carried out at regular intervals during the clipping application. Apply a small quantity of oil on the ends of the blades whilst the trimmer is running. Only use clipper oil or light machine oil of good quality.
This can be found at http://www.provet.com.au/Portals/0/pdf/08OsterClipperCare.pdf on page 3
Nov 25, 2010 | Oster Golden A5 2-Speed Universal Motor...
When I turn it on it chatters The clippers get very hot quickly and I don't know were the grease and oil are used on the clippers. A friend gave me the clippers with no book of directions. help thank you...
OK AS FAR AS OIL YOU CAN OIL THE BLADES, AND ON THE SIDE OF THE CLIPPERS THERE IS A STRAIGHT SLOT TENSION SCREW TURN IT ON AND ADJUST THE SCREW TO THE PROPER SOUND AND FEEL THEN THE MOTOR WILL SLOW DOWN AND NOT GET SO HOT SO QUICK. I HOPE THIS HELPS.
IF THIS DOES HELP CAN YOU RATE MY ANSWER?
(I GUESS IT IS IMPORTANT FOR THIS SITE)
Feb 22, 2010 | Oster Golden A5 2-Speed Universal Motor...
A5 dog clipper or blades may need tune up or
some times the link and gear inside the front part of the clipper wears out and the blades just wont cut. try this, remove the clipper blade on the front of the clipper their is a lever color red grab this part with your 2 fingers and move it side to side if it moves and feel sloppy your gears and link are worn out. you need to replace, also check the hinge for spring tension. if you need help Contact mannyssharpening@yahoo.com
Oster clipper blades get red hot and won't cut.
see this link, its for the A5. The A5 is the animal version of the 76.
http://www.peasridge.co.uk/clipper-advice/clippers-products-oster-a5.shtml
I dont know what model you have, but if you need schematics for YOUR model see this link.
http://www.clipperrepair.com/parts.htm?brand=8
Jan 10, 2009 | Oster 76076-010 Hair Trimmer
Pet clipper maintenance
Your clipper blades should be oiled before and after each use. To oil the blades hold the clipper with the blade toward the ground. Put a dab of oil on each side of the blade where they meet and across the back. Turn the unit on to let the oil distribute. Any excess oil can be wiped with a soft cloth.
Nov 29, 2008 | Health & Beauty
Chevrolet Express 1500 Maintenance 1 & 2
when you do a oil change you need to reset or light will come . to do this you turn on key hit gas pedal 3 times really fast
Oct 19, 2008 | 2007 Chevrolet Express Passenger
Health & Beauty Logo
394 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
