Question about Samsung (P80G5200CK) 100 Pack 52x CD-R Storage Media
Does not copy large files
My system is a p3 with 256mb ram i have recently started using the combo drive it reads all movie file cd's and dvd's but when i try to copy files of more than 200mb my system restarts and when i try to install some big softwares or games it restarts what should i do
  • nishjm02 Oct 13, 2007
    the error was found to be
     kernel_data_inpage error
     stop:0*0000007A(0*0C03E49D8,0*C0000000E,0*F9276000,0*0B003B860)
    Scholar:
  • 116 Answers
Sounds suspicsouly like a memory problem. When you allocate bad memory it will reboot your pc :)
Few things to check. First disable auto restarts on windows crashes. Do the following. (Assuming windows XP)
Right click My Computer
go to Properties
Click the Advanced tab
Click Settings for "Startup and Recovery"
Under "System Failure" Uncheck Restart
Now copy the files again and report back with the error code you get. IT will be something like 'yad yada yada 0x0000024'
You may want to also download memtest86, burn that to a cd and restart your pc. It will tell you if your memory is bad. Just look for red lines that say bad :)
Posted on Oct 10, 2007
SOURCE:
I have dell inspiron 6000 my combo drive is not recognizing dvd format movies although it is supporting cd formate
Hi Fazi1814,
If you're issue is that the dvd drive could not read the cd at all then you might want to try deleting upper and lower filters from registry editor. This files from windows sometimes cause an issue to your drive/
Here are the steps on how to locate and delete them:
1. Open Registry Editor - go to Start then type regedit on start search box then enter
If you get any notification just click continue
2. Once window is open, Look for the following subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10
To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. On the right pane, select upper and lower filter, right click then delete.
4. Click Yes when prompted
5. Exit registry editor and restart the computer
If your issue is that the drive reads the disk but it does not play the movie. This could be an issue with the movie format. Not all movie format can be played by the windows media player. In this case you need to have either of the following: (but I suggest you get both)
1. K-Lite Codec Pack 7.10 (Full) (to be able to read almost all types of movie and music format)
2. VLC Media Player 1.1.8 (can read any kind of format without installing any codec but still recommended to have codecs installed)
You can try downloading this two software from www.filehippo.com.
Hope this works!
Thank you for using Fixya,
avf110686
Apr 05, 2011 | Dell Inspiron 6000 8x DVD/CDRW Combo Drive...
I can't get my cd's I recorded on my sony dvd player
Check file extensions of files on your recorded cd's. Add file extension to Roxio, Windows Media player and check your drive settings.
Apr 22, 2009 | Sony DRU840A DVD-RAM Burner
Dvd writer does not burn on raw file system cds
What OS are you using? I doubt it is the burner. I have the same model burner and it burns everything I try to burn just fine. It works on both my XP SP2 installation and the OS X86 Leopard 10.5.5 installation. I have burned video, data and bootable OS DVDs and CDs in both operating systems.
It may just be Nero. You could try Alcohol 120% or Ultra ISO.
Dec 27, 2008 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
My SONY DVD RW ROM is not reading any DVD
Installing a third-party image editor or viewer applications may sometimes hijack the image file associations. In such circumstances, you could use this utility to repair the file associations (following image file types) to Windows XP defaults.
Click on Download utility and Click on RUN and then once again RUN
Check All the files and then click on Repair Associations
Download Utility
For the CD DVD Issue
Step 1: Unplug any cables that are connected loadTOCNode(3, 'moreinformation'); a. Unplug any cables that are connected to the video outputs of the computer. b. Try to read the disc again. c. If you still experience problems with the disc, go to step 2.
Step 2: Update the DVD driver loadTOCNode(3, 'moreinformation'); a. Contact the manufacturer of the DVD Drive to obtain an updated driver for the DVD drive, and then follow the manufacturer’s instructions to install the driver. b. Try to read the disc again. c. If you still experience problems with the disc, go to step 3.
Step 3: Obtain a hardware-based DVD decoder or software-based DVD decoder loadTOCNode(3, 'moreinformation'); a. Contact the manufacturer of the DVD Drive to obtain a hardware-based DVD decoder or software-based DVD decoder, and then follow the manufacturer’s instructions to install the decoder.
Note Many video adapters help decode DVD discs. However, the video adapter may not fully decode a DVD movie. b. Try to read the disc again. c. If you still experience problems with the disc, make sure that the sound card in the computer is compatible with the DVD drive.
Note Hardware and software decoders usually need a sound card to play back DVD movies. d. Try to read the disc again. e. If you still experience problems with the disc, contact the manufacturer to obtain a new disc. .
Remove Duplicate Drives loadTOCNode(2, 'moreinformation'); Remove any duplicate CD-ROM or DVD drives being loaded by Windows. To do this: 1. Click Start, point to Settings, and then click Control Panel. 2. Double-click System. 3. On the Device Manager tab, click View Devices By Type. 4. Double-click the CDROM or DVD branch to expand it. 5. Note the properties for each device listed in the branch. To do this: a. Click a device, and then click Properties. b. Click each tab in the device properties dialog box, and then record the device information and settings. c. Click OK. 6. Click OK, and then close Control Panel. 7. Restart Windows in Safe mode. To do this, use the appropriate method for your version of Microsoft Windows.
Aug 12, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Help copy dvd movie
clone dvd is one among the best software to extract movies and games from original dvds
Jul 07, 2008 | Samsung (TSH492ABEBN) CD-RW/DVD-ROM...
HL-DT-ST DVD-RW GWA-4082
ya it ll work... first change the cd to write mode ..hence not able to burn files...
Jun 21, 2008 | LG GWA-4082N DVD RW Dual Layer Burner
Writing to a DVD+RW disc
You need to use DVD software such as Nero that supports DVD-RW. from the app is where you would erase and so on
also make sure your blanks are +RW and not -RW
Jan 10, 2008 | Toshiba Satellite A75-S206 Notebook
Sony DVD RW AW-Q170A Burning Problem Plzzz.....Help me out: i have two drives, 1) Sony DVD RW AW-Q170A 1.70 Ver 2) Sony DVD/CD-RW Combo RYK4 Ver My "Sony DVD RW...
Check that the writable DVDs you are using are compatible (+/-) with your Sony DVD-RAM.
Go to Windows Explorer and check to see if the Sony drive is visible. It may not be connected or the Jumper switch may be set incorrectly.
Check you have drivers installed, take a look in Hardware manager.
Sometimes, it's a little difficult to copy CDs and DVDs when you have more than one burning suite installed - for some reason, they 'just don't get along'. Try uninstalling any suites other than Nero.
Or it may just be that your Sony CD-RW drive is just that, and your DVD-RW drive is just that. So it wouldn't be possible to write DVDs on the CD-RW and CDs on the DVD-RW? Though I would assume Nero would detect that and use your hard-drive as temporary storage.
In Nero SmartStart, have you selected the CD or DVD tab to correspond to the project you're burning?
Jan 07, 2008 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
How do I copy the files to my computer?
• Windows XP After connection is established, simply drag-and-drop files, using Windows the PC. The DVD Camcorder appears as an external DVD-RAM drive in Windows • Windows 98SE, ME, 2000 After connection is established, simply drag-and-drop files, using Windows PC. The DVD Camcorder appears as two external drives such as a removable Explorer. If DVD-RAM disc, the movie files will be copied from the removable If DVD-R disc, the movie files will be copied from the DVD drive.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Samsung (P80G5200CK) 100 Pack 52x CD-R Storage Media Logo
85 people viewed this question
Top Samsung Electronics - Others Experts
 Mike M
Mike M
Harrie
Are you a Samsung Electronics - Other Expert? Answer questions, earn points and help others
