Question about Panasonic sa-ht800V Home Theater Audio System SA-HT800V System
SA-HT800V Home Theater
The unit will not stay on when the woofer cable is plugged in - it blinks on for a second then dies out. What do you think this might be? Thanks, JP
  • 102 Answers
Check that the woofer cable is not shorted.
Posted on Oct 06, 2007
  • Lenaida Byford
    Lenaida Byford Oct 06, 2007
    Sorry too far away to make it tonight!
SOURCE:
Manuel for a Panasonic SA-HT820v
I have a Pansonic SA-HT820V multi disc unit. I must have pushed the wrong button and now the top 4 disc carriers are extended. How do I get them to retract so we can used the disc player again?
Jan 28, 2014 | Panasonic sa-ht800V Home Theater Audio...
RE: SC-HT800V I need a replacement remote control unit. Our system works perfectly, but we need the remote to be able to use the system toit's full potential. Please tell me where I can find one.
There are a number of sites that offer replacement remotes but Panasonic also lists two sites. They are:
Panasonic.newremotecontrol.com
Panasonic-remotes.com
Interesting that someone would build a unit with AM/FM which is only accessable with the remote.
Apr 11, 2011 | Panasonic sa-ht800V Home Theater Audio...
I hooked up the Panasonic sa-ht800V Home Theater Audio System SA-HT800V to an old tv the only hook up is the coaxial cable i turned TV to channel 3 and i get picture from the dvd is the a setting a need to...
Look at Page 12 if your TV only has RF coaxial antenna input...
http://www.retrevo.com/support/Panasonic-SA-HT800-Home-Theater-Systems-manual/id/312bh741/t/2/
Add in the Video cable (included) if the TV has an input for it and you'll be able to manage the SA-HT800 through the TV.
Make all the other necessary selections prescribed in the manual.
Jan 23, 2011 | Panasonic sa-ht800V Home Theater Audio...
Panasonic sa ht800v error code h07
Hi,H07 code is the error code when the spindle motor goes faulty
Aug 13, 2009 | Panasonic sa-ht800V Home Theater Audio...
My receiver for the Panasonic-SA-HT800V is toast
ebay? the speakers can only be used with this model..unless you strip the speaker wire...
May 06, 2008 | Panasonic sa-ht800V Home Theater Audio...
After about 5 min my system turns itself off
hi the problem your having could be one of a couple of things the first to check is that all the speaker wires a fitted correctly and not come out of socket as a speaker wire shorting could give you the problem your having.
The second and most likely problem is going to be a problem with the amp part of the circuit board usually a blown resistor but in your case as the unit comes on for few minutes then the chances are its just a solder joint failing on the board this causing the unit to trip out as a safety measure to stop it setting on fire.
Check the sub woofer cable is fitted properly as this is the usuall problem with you make and model let me know when you have checked all of this ok
Feb 25, 2008 | Panasonic sa-ht800V Home Theater Audio...
How do I solve Panasonic SA-HT800V error code F61?
unplugged a Panasonic HDTV plasma for four minutes, plugged back in and Now the DVD does not work.
How to reset?
Aug 28, 2007 | Panasonic sa-ht800V Home Theater Audio...
111 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
