2002 Buick LeSabre Logo
R
Ron Wilgers Posted on Nov 13, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a wiring diagram for the headlight circuit in a 2002 buick lesabre
James Billet
Level 2:
Sergeant:
  • Expert 272 Answers
  • Posted on Nov 13, 2013
James Billet
Expert
Level 2:
Sergeant:
Answers
272
Questions
Helped
48861
Points
682
You should be able to go to your local library and they should have a manual that will show you this diagram or you can purchase an automotive repair manual from Advance Auto Parts (HAYNES # 19020) Which will give you the wiring diagram. Cost for manual is approx. $ 25. Hope this helps
5 Related Answers
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Apr 15, 2009
SOURCE: lost the manual and need
go to this link and follow the links on the page to get a PDF copy of your owners manual
Anonymous
  • 9 Answers
  • Posted on Aug 31, 2009
SOURCE: 2001 Buick LeSabre. How to remove headlight
the bolts you are looking to remove are located on the top of the light housing. It only takes 2 of them to remove the housing. One is about 6 to 8 inches long, and the other one is much shorter than that. Just unscrew and remove them, and pull the housing straight out.
Testimonial: "Thanks a bunch!"
Patrick Rayome
  • 1757 Answers
  • Posted on Mar 06, 2010
SOURCE: diagram sepentine belt routing 96 buick lesabre
My sincere apologies for the delayed response.
I am personally going back to answer your unanswered questions.
I do not know if you still need this information, but I am going ahead and answering it anyway. You may want to Print the Diagrams for future use.
CLICK
on the following LINK. It has the Belt Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my apologies...
http://www.2carpros.com/car_repair_information/year/1996/make/buick/model/lesabre/1996_buick_lesabre_drive_belt_routing_diagram.htm
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Oct 29, 2010
SOURCE: How many quarts of oil
5 quarts with a filter
jturcotte
Jeffrey Turcotte
  • 8991 Answers
  • Posted on Nov 02, 2010
SOURCE: I need a spark plug
Pick the one below that matches your coil pack orientation. There should also be cylinder numbers on your coil pack.
2002 Buick LeSabre. I need a wiring diagram for the stereo please?
Question edited for clarity.
Question moved to model category.
2000 Buick Lesabre Car Stereo Wire Colors and Locations
the12volt.com https://www.the12volt.com > installbay > stereodetail
2000 Buick Lesabre Stereo Wiring ; Constant 12V+, Orange ; Switched 12V+, Yellow ; Ground, Black/White ; Illumination, Gray/Black ; Dimmer, Brown/White.
1helpful
Is there a free service manual for a 2002 Buick LeSabre Limited?
Yes, there is! The GM Holden Specialty Vehicle Technical Service Manual for the 2002 Buick LeSabre Limited can be downloaded for free from the GM Holden website. This manual covers everything from diagnostics and repair procedures to wiring diagrams and system specifications. It is a valuable resource for anyone who owns or plans to own a 2002 Buick LeSabre Limited.
I have a 2002 Buick LeSabre customized windshield wiper stop working
What's customized ? The wipers ? or is it a Buick LeSabre custom ? Do you know how to test automotive electrical circuits using a voltmeter ? Looking at a wiring diagram to see what all is involved in making the wipers work then testing with a DMM - digital multi-meter . It could be the switch or the motor or a wiring problem ,without testing we'd be guess as to what is wrong .
Free wiring diagrams http://www.bbbind.com/free-tsb/ Enter vehicle info. year , make , model an engine . Under system click on body & accessories ,then under subsystem click on wiper / washer . Click the search button then the blue link.
https://www.youtube.com/watch?v=0KHUxiXn31s
2answers
Where can i find headlights fuse 2000 Buick LeSabre
Check all the fuses, you cant go wrong. Fuse box behind the kick panel.
3answers
Where are the fuses to locate fuse for driver door panel on a 2002 buick lesabre?
PWR WDO - 30amp circuit breaker , DRV -MDL 10amp fuse - both are located in the rear fuse box .
Fuse Block Rear
Under the left side of the rear passenger compartment seat
Fuse box diagram 2001 buick lesabre
On this website you find fuse box diagram and description for Buick LeSabre (2001) http://www.carknowledge.info/buick-lesabre-2000-2002-fuse-box-diagram
1992 Buick LeSabre driver door wiring diagram needed
My 1992 Buick century headlights were not working so I replaced the relay now when I turn the knew switch on it takes a minute to 5 min before lights turn on
Top Buick Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
