Question about Dacor MCS130 Millennia Electric Single Oven
Exterior surface of oven gets hot when turned off
The exterior surface of our MCS130S wall oven gets very hot when we turn the oven off. There is a fan that runs for a brief period when we turn the oven off, and while the fan is running the exterior surface remains cool. Once the fan stops though the outside of the oven door and the control panel get very hot. Is there a setting that may need adjustment to keep the fan running longer?
  • 1 more comment
  • Vitor Silva Jun 17, 2013
    I have the same problem. I thought it was a seal problem on the door but the rubber its fine.
  • Anonymous Mar 12, 2014
    oven not getting hot when fans on but gets hot when fans of.
  • Anonymous Mar 26, 2014
    The oven will not get hot enough.
  • 102 Answers
What do you mean by very hot? Is it too hot to touch? Hot enough to sizzle when a drop of water is put on it?
Posted on Oct 06, 2007
Free fuse box diagrams
Parts #: W10317343
Substitution: WPW10317343 $145.98 at sears
Parts #: W10354052
Substitution: WPW10354052 $125.92 at sears
Part #: W10317347 front LED board $230 at sears
Many ovens have a bi-metal thermal fuse-also called a thermal limit switch-that protects the oven from overheating. The oven thermal fuse trips when the temperature in the oven gets too hot. After the thermal fuse trips, the oven won't heat. If the thermal fuse trips after the self-cleaning cycle, try resetting the fuse by turning off electricity to the oven, removing the exterior back panel, and pushing the reset button. If the fuse tripped during normal operation, replace it. If the problem persists, the electronic oven control board might require replacement. Reset the thermal fuse after replacing the control board.
Jul 15, 2014 | KitchenAid Ovens
Dacor wall oven model# MCS130S door won't close.
sorry this is a common fault with them you cant fix it i have tryed in the passed
Oct 15, 2012 | Dacor MCS130 Millennia Electric Single...
Eob5630w oven shutting down before set temp isreaced aprox 198c also cooling fan not comingon
The reason the oven is shutting down is because it is overheating due to the cooling fan not working, and a safety thermostat is turning the oven off.
You need to repair or replace the exterior cooling fan.
Jan 05, 2011 | Electrolux EOB5630 Ultrafan Electric...
The electric power to my house was temporarily interrupted, and since it was restored my Modern Maid wall oven has not worked. The timer and griller work, but the wall oven does not. Does the oven need to...
The timer is 110 volt, and the grill may also be . The oven, however, is 220 volt. Suggest you check your main circuit breaker box and reset the breaker set marked "oven" or something similar. This would be the exterior breaker box where power comes into the home.
Nov 14, 2009 | Ovens
I have a 10 year old GE profile dbl wall oven that I love BUT with a new Stainless fridge, cooktop and dishwasher the wall of white oven is a glaring mis-match. The oven doors both have exterior white...
Go to and check out their instant stainless material which is perfect for refacing your existing appliances and getting the stainless look you want without the stainless pricetag.
Contact these guys with any questions you may have.
Oct 18, 2009 | GE Profile JTP56 Electric Double Oven
I have Fridgidaire 30'' wall oven. Tried to bake something but only the broiler will ignite. NOT the oven! AHHHH...I want to cook my meatloaf. Help?
your model says its a 24"
but the hot surface igniter for oven is bad
it should have a seperate one for broiler
check here on fix ya ( hot surface igniter)
Mar 09, 2009 | Frigidare FGB24S5DC Gas Single Oven
I just cleaned by hand by magic chef wall oven and now I can't
Pilotless ignition means that a hot surface ignitor lights the oven burner. It does take a little bit of time to light the burner. Maybe 30 seconds. If you want to make sure it lights take the bottom panel out from the oven and observe the hot surface glow and the burners light. No real danger as the gas valve will only open after the hot surface ignitor has satisfied the gas valve. Let me know how it goes. ken
Jan 02, 2009 | Magic Chef 9122 Gas Single Oven
I have a gas oven whirlpool sf3020ekq2 buners work but oven won't
Sounding like your hot surface ignitor is getting bad. What I would like for you to do is open the oven and take the bottom panel off. This is so you can see the hot surface ignitor. Turn the oven on and look at the hot surface ignitor it is down on the bottom right next to the burner assembly. Does it start to glow and turn cherry red? This ignitor isn't too hard to replace couple of small screws and two wires. Will have to cut the wires so disconnect the unit from the 120 volt plug. Now if it starts to glow and get cherry red hot then the gas valve is sticking and it is the one going bad. That is a little tougher to replace. Turn the gas off at the source and get your wrenches unscrew the gas valve small space so if you want remove the door by just pulling it off the hinges.
If unit is old and you don't like it anyway maybe santa would be good to you and replace the stove oven. The gas valve is about 60 bucks or so and hot surface is about 20 bucks. let me know how it turns out.. ken
Dec 16, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Dacor MCS130 Millennia Electric Single Oven Logo
311 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
Are you a Dacor Oven Expert? Answer questions, earn points and help others
