2002 Chevrolet Corvette Logo
Posted on May 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My wipers just stoped working in my 2002 corvette. i checked the fuse and its fine. The washer fliud pumps and sprays but wipers dont move and make no noise...? Any help
Steeler Ed
Level 2:
  • Expert 130 Answers
  • Posted on May 04, 2009
Steeler Ed
Expert
Level 2:
Answers
130
Questions
0
Helped
90216
Points
544
Sounds like the wiper motor is shot. You can check for electric voltage at the motor using a meter to make sure it is getting power first.
Anonymous
Level 3:
President:
  • Master 957 Answers
Anonymous
Master
Level 3:
President:
Answers
957
Questions
0
Helped
490551
Points
3205
May need to replace the wiper motor. The weak point on them is the circuit board, which is part of the assembly.
1helpful
WINDSHEILD FLIUD WONT COME OUT ON 1989 BMW 7
open your hood and get close to your washer fluid reservoir and make someone pull washer switch for you if you dont hear any reaction from you fluid pump locates around reservoir means you need to replace that little pump if you hear pump is working but dont spray check clugged spray nozzles or leak some where between reservoir to nozzles inspect lines and check washer system fuse!
17helpful
4answers
My 2004 Ford Expedition will not spray windshield wiper when the button is pushed. The wipers do turn on, but no spray. Would this be caused by a fuse (the wipers do turn on) or is the motor bad?
Can you hear the washer pump running when you operate the washer switch? The washer pump is in the bottom (side) of the washer fluid reservoir. You should hear it running. If not, you can disconnect the wire connector at the pump and use a test light to check to see if there is power and ground at the connector when you operate the switch. If there is power and ground, replace the washer pump motor. If there is no power or ground, you most likely have a bad washer control switch. (You have to replace the entire Multifunction Switch)
If you can hear the pump running, check for washer fluid pouring on the ground. If this is the case, you have a broken hose between the washer pump and the jets that spray on your windshield.
Also note that there is no way possible that your problem could be CAUSED by a fuse!
For more information on this subject, please review this article: Where's The Fuse?
I have a 2008 Grand Prix. Windshield washer is
follow the hoses to the hood or wiper arm (i dont know where your spray nozzles are)and disconnect hem and press the spray button. if it sprays your nozzles are plugged, if not its your pump motor.
My wiper pump is not working on my 2002 Jeep Liberty. I think its my pump fus beause the wipers work fine. Any ideas?
sounds like a bad pump, the fuse for the washers is the same as the wipers, check connection at pump and make sure washer fluid is not frozen if all checks ok. then replace the pump. hope this helps.
1helpful
2002 intrepid wipers
well check to hear if you hear the wiper motor working if you do look at the arm take the end cap off loosen the bolt if you here the motor running/tighten them bak up if you do not here the motor check fuse under the dash and inthe engine compartment and replace fuse or fuses/ please rate my response thank you very much
2helpful
Windshield sprayer won't work
when you turn on the sprayer you should hear a pump motor running, try this with the engine off and key on so u can hear better. if u dont hear the pump then check the fuse if its ok then u will need a new windshield washer pump. if the pump is running when u activate it check for a leak in the lines. if you hold the washer button down long enough and the pump is running then you will see washerfluid leaking from somewhare. have hood raised when doing this so you can see better.
2answers
Sprayer system doesn't work.
u washer pump motor went out i suggest taking it to a dealer
1 Inspect Fuse Corroded, burned, or shorted fuse may be interupting power source. grey_line.gif 2 Inspect Windshield Wiper Switch Faulty wiper switch or circuit. grey_line.gif 3 Inspect Wiper Motor Worn or faulty wiper motor.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
