Question about Zenith B25A24Z 25" TV
Zenith tv While the tv was being moved, it was accidentally dropped on its screen. It works but the picture is at a slight diagonal. What can be done?
    An expert who has answered 500 questions.
  • 556 Answers
Due to shifting your yoke coil might have turned. if you are not tech person get it done by tech. good luck.
Posted on Oct 07, 2007
What would cause a GE 60GW948 have a very snowy, and now No picture screen
when you say gone out---no light on screen or brightness or what? The snowy picture can be got around in most cases.
Jun 14, 2012 | GE 31GT660 TV
Good sound but scrolling picture with diagonal lines. Zero quality.
Check the vertical synchronisation section. Either the set lose vertical synchronisation signals, or the vertical oscillator is oscillating out of frequency. The work is a skilled one, and you must have through knoledge in electronics to follow.
May 14, 2012 | Zenith Televison & Video
My zenith D52WLCD has a blue haze going diagonally
This a Normal Intensive Use Defects, this a Screen Burnout. Sorry
Oct 31, 2009 | Zenith Televison & Video
I have Diagonal lines moving across the screen.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Sep 15, 2009 | Toshiba 51H83 51" Rear Projection...
Sony 65" Rear Projection loses picture, then gets diagonal lines
This is common problem on this tv, picture tube is bad. Blue and green is more % bad.
Thank you
Aug 07, 2009 | Hitachi 51F59 51" HDTV Projection...
Converge off a little and screen has green tint
If you have the remote, go to the setup screen and move the picture. Converge has nothing to do with where the picture sits but, where the red, blue & green dots land. All you should see are pure white dots. There should be absolutely NO color ghost anywhere on the screen. If so, you need a bar / dot generator to set the convergence to center the dots.
Jan 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Video noise at bottom of screen
Try adjusting the tracking on your VCR. This symptom would typically be caused by a slight tracking error in your VCR or video heads that need to be cleaned. Your Zenith TV may be a little more sensitive to video synchronization problems than your other TV is.
If VCR tracking adjustments have no effect on the symptom, then the problem could be in the TV, but I'll need more details to assist you with troubleshooting. For example, how do you connect the VCR to the TV?
Jan 27, 2008 | Zenith B27A11Z 27" TV
Diagonal lines across picture
do you have a dvd or vcr hooked up to this? Is it hooked up with the a/v cables (yellow, red and white). double check the cable hookup make sure audio cord is not in the video jack, from what you are saying this will do that if it is. Also there is a capacitor on the main board believe it to be C3412 which intermittenly gives horz. lines but haven't had a audio tone with that.
Nov 29, 2007 | Zenith B25A76R 25" TV
Zenith B25A24Z 25" TV Logo
74 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
