Question about Philips GoGear HDD6330 MP3 Player
Nery Guzman my Phillips GoGear HDD 6330 is not registred for my pc, and isn´t start normaly.
  • 8,596 Answers
You can register with Philips. Make sure you have Windows XP and WMP 10, or else you will have to do the following:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 11, 2008
SOURCE:
How to remove Genuine Microsoft Software
Register your MS Office with the valid registration key found on/in the original software box
Mar 12, 2011 | Microsoft Office Professional 2007 Full...
My philips HDD 6330 will not switch on. I have tried charging for a few hours both via the PC and the adapter. The normal charging process does not show on screen i.e. the 2 computers. I have tried the...
you may need to unlock the player. look in the user manual to find out how to do this. to connect the device to the computer you may need to instal the hardware to the computer. to do this go to control panel and swich to clasic view if it is not already than go to add hardware and follow the onscreen instrucions. hope this helps, solver214!
Oct 19, 2009 | Philips GoGear HDD6330 MP3 Player
Need download phillips gogear 4gb software
i need downnload phillips gogear 4gb software to add hardware
Dec 30, 2008 | Philips GOGEAR SA6045 MP3 Player
Mp3 player
please help my player to work again
Jun 05, 2008 | Philips GoGear HDD6330 MP3 Player
Shows "this device cannot start" when i plug in the device
My advice to you would be to go get a new media player that isn't a phillips product. The headache that the hdd 1630 caused me almost made me go insane. I spent countless hours on the phone with tech support. They even sent me a new 1630 that I had for 2 months when the same problems happened again.
This thing is nothing but a expensive paper weight.
Mar 28, 2008 | Philips HDD1630 MP3 Player
Phillips HDD120/05
Repair the GoGear - warning: this will delete all files from your player.
-Tha Mp3 Doctor
Feb 10, 2008 | Philips HDD120 MP3 Player
Philips HDD 6330/17, doesnt play music..
The rule for this device is first reset (hold power on/off and volume + simultaneously and continuosly while the player is turned on; reset works when the power turns off), and then Repair if that fails. The problem with Repair is that it deletes every file from the GoGear. Here are better instructions for repair than the manufacturer's:
1) Open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website
2) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
3) Disconnect the GoGear from the computer and turn the GoGear off (if you haven't done so already) - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new.
-Tha Mp3 Doctor
Jan 11, 2008 | Philips GoGear HDD6330 MP3 Player
Device manager
my philipsgogearsa5125/37 it won't let me hear any songs and pictures
Jan 02, 2008 | Philips GoGear HDD6330 MP3 Player
PC won't recognize can it be forced into disk mode, how?
Get the latest version of the software first (from the Philips website), then:
-Tha Mp3 Doctor
Dec 11, 2007 | Philips GoGear HDD6330 MP3 Player
Philips GoGear HDD6330 MP3 Player Logo
85 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
