Question about GE JBP80 Electric Kitchen Range
F4 code when preheating oven
I tried to preheat my GE JBP80 oven and after about a minute it started to beep continuously and F4 showed on the display. This continues to happen. I cannot use the oven.
  • 1 more comment
  • Anonymous Mar 23, 2014
    I think that 20 minutes is a long time for my oven to preheat. Is this normal or is there a possible problem?
  • Anonymous Mar 27, 2014
    We have a MODEL#MEF352BGWD and the timer will start to randomly beep for no reason plus it will not preheat and lastly it will also randomly start to preheat. I am thinking the circuit board behind the panel is out?
    It starts to preheat on its own and beeps constantly. plus it will start self cleaning randomly??
That code means "Shorted Oven Sensor". You can find out more about this by removing the bottom drawer, pull it out til it stops, lift it up and pull it all the way out. Now lay down on the floor and look under the oven to the left side. You will see a service info card there. Pull it out, open it up and have a read.
Posted on Oct 17, 2007
GE XL 44 When preheating the temp only gets to halfway to selected temp then it starts to peep then F4 appears. after many attempts it will preheat. This happens every time I use it.
F4 Error
is an open or shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok
Oct 26, 2017 | GE Kitchen Ranges
What does error code F3 mean?
not sure but here is the tech service manual GE JB960 Technical Service Manual
Feb 19, 2015 | GE Kitchen Ranges
JSP26GP code f3 then f2
What is the complete model number of the unit?
Dec 08, 2012 | GE Kitchen Ranges
What does F3 mean when the oven is on. After preheating it starts beeping and then F3 pops up
F3
or
F4 Open or shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Sep 06, 2010 | GE Spectra JBP78 Electric Kitchen Range
Preheating Oven
Cold Stove, you may not be able to. The issue here is that oven manufactures put on their units a fast preheat. However it isn't possible to preheat an oven for 7 to 9 minutes and bake short time bake items properly. Also the oven sensor will respond faster than the absorbation rate of the sheet metal in the oven liner. To preheat an oven properly takes 15 to 20 minutes before putting in the food. I see this will a lot of current ovens. Sounds like a normal format of the control.
Feb 03, 2008 | GE JBP24 QuickClean Electric Kitchen Range
F4 error code on Jenn-Air W30400BC expressions built in oven
Slone, F4 is the code for a shorted temperature sensor. This is the temp probe in the oven. There are 2-quarter inch screws holding it on. It should pull out through the insulation until the quick connect comes through. If you want to make sure, the sensor should ohm out at 1143 ohms at 100 degrees. I think you can be pretty sure that this is the problem. The part number I have is 704657. Catriver.
Dec 04, 2007 | Jenn-Air JJW8527C Expressions Collection...
GE JBP80 Electric Kitchen Range Logo
267 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
