my 5 light chandelier is rated for five 100watt bulbs. recently one socket made a "POP" sound with a little smoke when I turned it on, now the dimmer only stays on at full brightness. I replaced the switch and all five bulbs and the same thing happened again the next day. Do I need to replace the entire fixture? Is this a fire hazard?
Whoa...You definitely may have a fire and/or shock hazard hanging from your ceiling. I've seen a lot of fixtures with old, brittle wire and bad insulation in them. Lamp wiring is subjected to a lot of heat, especially with higher-wattage fixtures. Long term exposure to heat near or above the insulation's rating is especially damaging to electrical insulation. I've also seen cases where metal parts of the bulb socket partially melted and/or broke loose.
If you're comfortable and confident of your abilities to make a safe electrical connection, you can replace the wire and bulb sockets in your fixture. If it's valuable or an attractive antique, it's worth fixing or having fixed, even if you sell it. Just make sure you use wire with insulation rated for use in an electrical fixture. It must be rated for a temperature no less than 105 degrees Celsius.
It it's a lower cost fixture, replace it or have it replaced. Regardless of what you do, you're probably going to be replacing that dimmer again...sorry.
If you live in an older home, it may be worth (in terms of safety) having a few qualified electricians evaluate your electrical system as a whole to make sure everything is still in safe condition.
when my dimmer switch is turned on, the light comes on at full strenght then about 5 seconds later...
(More)
when my dimmer switch is turned on, the light comes on at full strenght then about 5 seconds later it dims to half strength on its own. how do i fix this? i have replaced the switch and it is still doing the same thing.
I have a headboard with 2 westek 6043 touch dimmer lights. When I use the touch pad for one light,...
(More)
I have a headboard with 2 westek 6043 touch dimmer lights. When I use the touch pad for one light, it also turn on/off the second light. I have separated the 2 touch pads and I have each transformer plugged into a separate outlet. Any suggestions?
have got 12 dowlights in kitchen but 6 not working,recently had kitchen extended these are the 6...
(More)
have got 12 dowlights in kitchen but 6 not working,recently had kitchen extended these are the 6 lights that are not working.
