Question about Minolta Photography
Best 35mm film for outdoor photos
Need help with choosing the best film for outdoor photos of people protraits and should i use a flash to fill in the shadows.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Minolta Master
  • 102,366 Answers
The best film is the one YOU like the best.
Flash can be used to fill in the shadows in outdoor portraits, as you say. Do it by all means, if that's the effect you want. Sometimes you may not want it. Do it both ways and see how they come out.
Photography is all about YOUR creativity.
Posted on Jan 16, 2010
SOURCE:
Do I need to buy film to use this kind of camera?
Vivitar makes many cameras. Some use 35 mm film and some are electronic. I believe yours is an XM 1K type:
Product description Product Information The Vivitar XM1K is an APS point and shoot film camera, designed to capture photographs with dazzling colors and record the memorable moments of your life. You can click brilliant outdoor photos even in low-light condition aided by the f/4.5 aperture of this Vivitar film camera. Moreover, the Vivitar XM1K point and shoot film camera effectively removes the red pupils from the subject's eyes caused while using the flash, thanks to the red-eye reduction feature. Further more, this Vivitar film camera, supporting autofocus, lets you focus erratically moving objects with precision. What's more, with a four-mode electronic flash, this Vivitar camera lets you choose the flash mode to suit your requirement.
Jan 04, 2013 | Cameras
My pictures have a purple tint to them
You're either using old/expired film, or taking photos during dusk. Color film is balanced for daylight photography. Using it under conditions other than that will result in varying color casts on the resulting images.
Fluorescent lighting: Greenish
Indoor bulbs: Reddish/orange
Outdoor at night/dusk: Blueish/purpla
Ourdoor at dawn: Pink/blue
Or, you may have just gotten bad print work done. Try a different lab.
Jun 12, 2011 | Canon EOS-AE-1 35mm SLR Camera
I have a ricoh kr-30sp camera will not come on and what kind of film do I use
With the camera turned on, look in the viewfinder. Down on the bottom right side is an LCD display, if it's blank then your camera probably has dead batteries. It takes 2 x CR1/3N or 4 x SR44.
Your film accepts 35mm negative film or 35mm transparency (aka slide) film. It will accept any ISO from 12 to 3200, but in practice all you'll usually need are ISO 100, ISO 200 or ISO 400. You choose the film based upon lighting conditions and the lenses you'll be using, but in general you'll use ISO 100 if shooting mainly outdoors in daylight, ISO 400 if shooting in low light or with a telephoto lens, and ISO 200 is a general all-rounder good for most things. ISO is usually referred to as film speed as higher numbers need less exposure than lower numbers but the trade-off is a less detailed image.
To load film into your camera and to set the camera to match the film ISO setting refer to this link to the manual provided by Norman Butkus. The manual will also guide you through all other aspects of operating your camera.
I hope that I have fully answered your question, but if not please add a comment and I shall respond in due course. If your question has been answered, then please let me know by taking a moment to rate my answer.
Sep 15, 2010 | Ricoh KR-30SP 35mm SLR Camera
Choice of film speed
ISO400 is probably the film you want to go, as higher speed film costs more and have more grain...
Feb 11, 2009 | Nikon N60 35mm SLR Camera
My Cannon Rebel EOS 35mm film Camera is producing blank Film
If you are getting some photos where only part of the image is visible, then I suspect that they were photos where you used a flash.
Cameras have a specified maximum shutter speed for use with a flash, this is called its 'sync speed'. This is the fastest speed that the camera will need to open the lead shutter and close the trailing shutter in order to expose the entire surface area of the image and have it evenly lit by the flash unit. If you shoot too fast of a speed, then the shutter will only be partly completed its exposure and you'll get a photo with only part of the image showing. The faster the speed past the sync speed, the less the resulting area of the image. Most cameras will have a sync speed of 1/250 or less. I think a lot of the Rebel models are 1/90 - consult your manual.
Nov 23, 2008 | Canon EOS Rebel G 35mm SLR Camera
'Err' & 'E"
Is the film loaded correctly? Have you tried reloading it? Also is it flashing DX too? That would mean the film speed is not DX coded so you need to set the film speed manually.
Sep 23, 2008 | Nikon N80 35mm SLR Camera
Help setting shutter speed and adjusting a lense properly
Hey little22,
I would set this camera to auto mode to begin with. This cameras auto mode is actually an aperture priority mode which means you choose the aperture on the lens and the camera automatically chooses the correct shutter speed. For outside photography the morning hours and the evening hours will provide the best light because the light is softer and the subject will not be lit from above which usually cast unwanted shadows on your subject. If you do have to shoot during mid day I would put an external flash on your camera to fill in the shadow areas on the subject. Inside photography is often more challenging because even though the human eye can adjust to low light levels camera film is not so forgiving. You will either need to shoot with a very high ISO film, or you will need to use a flash. I would suggest using a flash since high ISO film is usually very grainy. If you can I would suggest bouncing the flash off of a white surface this should produce softer light and more pleasing portraits. I have included a link to a download of your camera manual incase you need it. If you have any other more specific questions just ask. I hope this helps!
http://ca.konicaminolta.com/support/manuals/film-cameras/film_mf_slr/index.html
Sincerely,
Allan
Go Ahead. Use Us.
Jun 21, 2008 | Minolta X-370S 35mm SLR Camera
I can't get the fill in flash off.
Hey stella27,
I am including a link to a PDF download of your manual, and instructions on how to turn the fill flash on and off is on page 26 of the user manual. I hope this helps!
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/index.html
Sincerely,
Allan
Go Ahead. Use Us.
Jun 12, 2008 | Minolta Maxxum STsi QD 35mm SLR Camera
SOMEBODY GAVE ME A NEW VIVITAR HC 2000 FOCUS FREE CAMERA, JUST GOT SOME FILM, KODAK 800 35mm,is any of this compatible?
Yes, the film and cameara compatible.
With point and shoot cameras you need to be a bit more careful about the type of film you choose. The Higher the number, the more sensitive it is to light.
If you are going to be shooting outdoors in bright sunshine, a 100 or 200 film is preferable. 400 and 800 films are better suited to indoors or low-light conditions. This doesn't mean that you can't use a 800 film outdoors, but if you do the pictures might be a bit over-exposed which will result in the colours looking a bit washed out when you get your pictures back.Likewise, if you use a 100 film indoors or at night, the pictures can look a bit dark.
Happy snapping!
Matt
Feb 29, 2008 | Cameras
Help!! 10-year old Accura Zoom 80 film camera is taking blurry photos all of a sudden
you should be able to place your hand in front of the auto focus window while looking in front of camera (be careful not to blind yourself with the flash) you should notice the lens moving sightly as if to focus. The best way though is to actually shoot a roll through it. Do not shoot a wedding or anything of real importance...the cost of a roll of film and develop is worth piece of mind.
Jul 04, 2007 | Olympus Accura Zoom 80 35mm Point and...
Photography Logo
274 people viewed this question
Top Minolta Photography Experts
Ekse
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
