Was working fine but started overflowing around the coffee -filter holder. Tried without coffee using new filter, still overflows, water drips too slowly into decanter. Coffee holder is clean. Tried a different brand of filter, same issue.
The outlet of the cone filter holder is clogged. Normally its just a hole you can clean out but some units have a valve that is pushed up/open by your coffee pot. That valve may be clogged or if you changed the coffee pot it may not be opening due to the different pot. Clean valve or just remove it so the coffee will run into coffee pot.
