Question about Nikon Speedlight SB-600 TTL Flash
Stuck in manual mode
I can't change the zoom. I press the zoom button and no change. The m above the zoom button will not go away. Does not work on the comera either
Check that the wide angle pull out filter is pushed in proberly until it clicks in place also in custom menu check that M ZOOM is set to OFF. (hold zoom and - buttons together for a couple of seconds to enter and exit custom menu)
Posted on Jun 16, 2009
What I did was put the flash on the camera, go to the menu on the camera and reselect TTL mode and press ok. The "M" disappeared.
Posted on Dec 27, 2009
How do I reset the time on my C-5000 Zoom?
Set the mode dial to P and turn the camera on. Press the OK button to bring up the menu. Press cursor-right to select the MODE MENU. Use cursor-up/down to select SETUP and press cursor-right. Use cursor-up/down to select the clock icon and press cursor-right. Use cursor-up/down to select the format and press cursor-right. Use cursor-left/right to move between the fields, cursor-up/down to change their values. Pres OK when done.
The above is from pages 29-30 of the reference manual. If you need manuals for the C-5000, you may download PDF versions and/or order printed manuals from here.
Jun 20, 2012 | Olympus Camedia C-5000 Zoom Digital Camera
I have a sony bravi xbr ;the picture is sooo big i can't read the subtitles . i tried ti fix it ( from the instruction manual ) but nothing work . thank you !
Hi: Check you screens format button to change screen sizes, this button may also be labeled Aspect. Seems you are in ZOOM Mode, these buttons can also be found on cable boxes remote as well try pushing them to see if screen size change. If this does'nt help then do this with the TV in off posistion. Press the Display key on your remote, Then the Five key, then the Vol up key, then press power key. This will turn set on in service mode, you will see service options do not do anything but press the number 8 on remote and hit enter. This will rest tv to factory settings. All video setups and parameters you have set in user menu will result back to factory and will need to be redone. TV should shut down on its own and come back on on channel 3.
Dec 10, 2011 | Sony BRAVIA KDL-52XBR3 Television
Cant change from shoot mode to playback mode.also zoom lens is not adjustable
The Fuji FinePix F470 camera is an excellent device. Most of the controls are computerised in such a way that makes picture taking and viewing less stressful. Changing from shoot mode to playback mode is by the press of the play button which looks like an arrow the zoom lens is not manually adjustable it adjusts by the press of the W and T buttons.
Here is a link to help you download the brochure, User guide and quick start guide for the camera:
http://www.fujifilmusa.com/support/ServiceSupportBrowse.do?prodcat=842410&sscucatid=664271&sscucatid=664272
Hope this soultion has been helpful?
Dec 19, 2010 | Fuji FinePix F470 Digital Camera
Minolta Compact AF 8 binocular continually focussing
My Binos are doing the same thing, I think it is some fixed mode it is stuck in. Anyone know how to get is back to normal working? Maybe the big AF button is stuck on?
Help please as I can't find my instruction manual.
Feb 07, 2010 | Minolta Compact Binocular
The zoom does not work on my hitachi hdc-1098 e camera and the menu does not come up as it should - manual says select 'camera' mode but there is no camera mode, only 'p' so when I press the menu button it...
the zoom does not work on my hitachi hdc-1098 e camera and the menu does not come up as it should - manual says select 'camera' mode but there is no camera mode, only 'p' so when I press the menu button it doesn't work. Any ideas
Dec 26, 2009 | Cameras
The zoom button isn't working and therefore when looking through the lens everything is blurry
Follow the instructions below to check and test the focusing of the camcorder.
Manual Focus
✤ In the following situations, you may obtain better
results by adjusting the focus manually.
a. A picture containing several objects, some close to the
Camcorder, others further away.
b. A person enveloped in fog or surrounded by snow.
c. Very shiny or glossy surfaces like a car.
d. People or objects moving constantly or quickly
like an athlete or a crowd.
1. Set the [Power] switch to [CAMERA].
2. Set the [Mode] switch to [TAPE] or [CARD].
(SC-D375(H)/D975 only)
3. Press the [Q.MENU] button.
 Quick menu list will appear.
4. Press the up/down arrow button to select <Focus>, then
press the [OK] button.
5. Press the up/down arrow button to select <Manual>, then
6. To exit, press the [Q.MENU] button.
 The [MF] icon and the [MF/AF] status bar will be
displayed on the LCD screen.
7. Press the up/down arrow button to adjust the focus.
[ Note ]
Manual Focus is not available in the EASY.Q mode.
Make sure the lens is clean--use a soft cloth and don't press hard when wiping--use a circular motion starting from the center of the lens and working to the outside--that way, you wont grind dirt into the glass. If the lens is dirty enough, the camera will actually try to focus on the smudge or finger prints on the lens! Look into the lens and use the zoom button--do the interior lenses move forward and backward? The zoom button could be damaged(liquid or impact), or the lens could be jammed due to impact or liquid( I just fixed my sister-in-law's unit--had cola in it and sugar acts like super glue when dry.)(Lenses jam due to excess heat, too) NEVER leave a camcorder in a hot car. The grease used to enable the parts to move freely and smoothly can flow to sensitive areas and stick like glue.
If the focusing is indeed stuck, the unit must be repaired at a reputable facility. Don't send it in through a retail store unless under warranty.--Hope I was of help.---Rick
Oct 02, 2009 | Samsung SC-D372 Camcorder
How to get manual focus on Olympus Camedia C-750 ultra zoom digital camera
TTTTTTTTTTTTTTTTTTTTTTTTITf correct focus cannot be obtained
When the subject to be focused is not on the AF target mark (not positioned
in the center of the composition), you can use the following steps to obtain the
correct focus on the subject. This operation is referred to as "focus lock".
Determine the position of the subject after focusing (Focus Lock)
1 Press the power switch.
• The camera turns on in the shooting
mode.
• The lens extends and the monitor turns
on.
• The orange lamp lights.
2 Turn the mode dial and select a
shooting mode.
"Shooting mode" (P.36)
3 Position the AF target mark on
the subject you want to focus on.
• When shooting a hard-to-focus
subject, point the camera at an object
about the same distance away as the
subject.
Press the shutter button halfway
until the green lamp lights.
• When the green lamp lights steadily,
the focus and the exposure are locked.
• When the green lamp blinks, the focus
and exposure are not locked. Release
your finger from the shutter button, reposition
your subject and press the
shutter button halfway again.
5 Keeping the shutter button
pressed halfway, recompose
your shot.
6 Press the shutter button fully.
Try the above, info from D-535, C-370 and X-450.
I can email you the complete manual if this works.
Regards
Phillip
Sep 12, 2009 | Cameras
TV stuck in SAP mode
The link above does not work.
Aug 13, 2008 | Sylvania 6427TE 27" TV
How do I change the date? I don't have a manual.
1. With power off, press the MODE button to select the DATE mode.
2. Press the zoom out (three trees) button for more than two seconds to enter the date/time set mode.
3. Press the zoom out (three trees) button to select year, month, day, hour, or minute (selected number will flash).
4. Use the zoom in (one tree) button to advance the number.
5. Repeat steps 3. and 4. to set each value.
6. Press the zoom out (three trees) button until the colon (in the hours:minutes) is flashing. When the colon stops flashing, date and time setting is completed.
7. Press the MODE button and the power will switch off.
Jan 13, 2008 | Canon Sure Shot Z180u 35mm Point and Shoot...
Need to set the date and can't find manual--
Try this:
Dec 22, 2007 | Canon Sure Shot 115u II Date 35mm Film...
Nikon Speedlight SB-600 TTL Flash Logo
346 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
