Question about Samsung 225BW LCD Monitor
225BW LCD Monitor problem with Blank Screen
Hi, I have had 2 LCD screens giving me this problem. The main problem is, that I have to have the monitor on before turning on the computer. So that my computer upgraded automatically and restarted while the monitor is turned off, well when i go and turn on the monitor, no image is displayed at all, not until i restart the PC before an image is shown on the LCD screen. Anyone have a fix for this? or know why it does this?
SOURCE:
yooperbud
  • 8637 Answers
SOURCE: Samsung GH19LS LCD Monitor wont display computer signals
You should have received two cables with the monitor. One is for VGA and plugs into you video card or computer board . The second one is for DVI digidal video and if you have that cable it plugs into the square connector. Then if you look into your monitor manual or quick setup sheet it will tell you how to connect and set the monitor to either VGA or Digital. I'm sure that is what has to be set. Don't hook up both cables to the monitor and computer. Only use the one. Digital gives you a better picture if your computer has that function. Hope this is helpful. Bud
Posted on Jan 09, 2009
GregL
  • 49 Answers
SOURCE: screen goes blank after 2 seconds
Do you have the video set to a range that this display cannot handle? Try rebooting into Safe Mode and set the resolution down to 800x600 or 1024x768 and see if it that will get you back. If so, then look up the specs of the display and set it no higher than it's max.
If it physicaly powers OFF, then you probably have a power issue.
Posted on Jan 20, 2009
  • 1684 Answers
SOURCE: My Hanns-G HC194D LCD Monitor Takes Forever to come on
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 17, 2009
  • 152 Answers
SOURCE: Screen flashes - samsung 215tw LCD monitor
walkstex, I will answer the last ? first. All LCD monitors WILL NEED to have their "cold-cathode-fluorescent-tubes" replaced!!! As long as your display had a Bright, Crisp image displayed on it before this "FLASHING" symptom occured, then you don't need new CCF tubes. Your problem seems to be occuring in the electronic ballast circuit called an INVERTER. It Takes 12-15v DC and turns it into 800-1200v ac to light up the CCF tubes. This is the same technology used in the new style curlieQ screw-in light bulbs called CFL's. Only difference is they use what is known as a CONVERTER circuit----AC to AC!!!! And the tubes hung horizontally on the rear of your LCD panel are thin and straight. So, to answer your first ? Yes, it is an issue of getting the CCF tubes to light up. (backlighting) Now, I should also mention that there could possibly be a problem with the main power supply in the monitor. It is called a "switch-mode-power-supply" (smps) that supplies DC for the digital signal processing board (typ +5v) and 12-15v for the inverter. Well, This typical type of symptom could be as simple as a thermally fractured solder joint on the power supply board or some bad Filter capacitors could also need replacing. I suggest that you search web to find out more about the things I have mentioned in the above text. Do search for things like "swollen capacitors", "Bulging Capacitors" and checkout www.badcaps.net for some pictures of typical failures. Get back to me if you want to carry this any further on your own. Bye for now. I'm louie12fix on fixya or lmistyrel @aol.com
Posted on Sep 23, 2009
  • 152 Answers
SOURCE: Have a Samsung SyncMaster 225bw.
Dyderich, Yes, You should read up on all the causes of LCD monitor failures!! Your symptom will be among the top three cause/complaint of failures. LCD units can be repaired. If you have never used a soldering pencil, digital volt meter, DMM or Oscilloscope, then you should keep yur gruby fingers on the outside of the monitor. Your monitor's "switch-mode-power-supply" and the "cold-cathode-fluorescent-tube's" and the "inveter" power supply that lights up the tubes will need to be evaluated(trouble shoot) by a TECHNICIAN who knows all there is to know about CCFT's and what it takes to get them to light up!!! Or you can trade up to a younger model, and repair/refurbish the old and keep as a spare. You could also see if SAMSUNG has some sort of swapout program for newly refurbished same model monitors? ? ? Check with a Samsung dealer and or their website. Bye for now. I'm louie12fix on fixya or lmistyrel @aol.com
Posted on Sep 25, 2009
Samsung 225bw
Here is a link to a repair guide that may help you get it going again.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-225bw-22-monitor/
May 13, 2012 | Samsung 225BW Monitor
Blank lcd screen when turned on . Wonder if backlight problem
A blank screen is usually caused by the power supply not giving the right voltages to the back light inverter, the bulbs last a lot longer than the power supply board. If you can do a little soldering then you should be able to do the repair yourself. Here is a link to a repair guide that shows how to dis-assemble the unit and get to the power supply board. There are 5 capacitors that will need to be changed and in most cases this will fix the type of issues you are having with this monitor.
BuddyMc
Dec 22, 2010 | Samsung 225BW LCD Monitor
My toshiba laptop turns on but screen is blank
1.Connect a external monitor
2.Press Fn Key and one of the key numbers(below the F1, F2... keys). One of them should have two small monitor on it or LCD/Screen
3.If you can see windows on the external monitor(EM) then you may need to replace your laptop's Screen or the LCD Inverter
Thanks
DiegoTech
Nov 13, 2010 | Computers & Internet
My 15" Powerbook G4 screen is half blank - it sometimes shows lines or has some blank spots but it's always gone away. This time it seems stuck. What to do?
Hi There,
If you can get your laptop connected to an external monitor it will do the main troubleshooting for you. With it connected and set to display on the monitor, the 2 options below are pretty solid;
1. If the monitor shows your nomal desktop display without any distortion or lines, etc, then you can be fairly certain your LCD screen panel on the laptop is just wearing out.
2. If the monitor shows exactly what the laptop does, i.e., same exact problems, then it means that the Video chip on the logic board is about to fail and you'll have todecide whether to repair or upgrade to a newer machine.
I wish you the best.
Sep 08, 2010 | Apple PowerBook G4 Mac Notebook
My Syncmaster 225bw suddenly developed a horizontal line about 1/4 of the way up from the bottom. It looks like a single line of bad pixels. Is this possibly the screen itself, is it an inverter problem?...
If the inverter is bad you will black screen, the lines can be caused by failed T-CON board which is part of the LCD panel assembly. You may try reseating the ribbon cable on the LCD panel.
Please see LCD panel in my albums here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
May 14, 2010 | Samsung 225BW LCD Monitor
I have no blue light at the power button for my Synchmaster 225BW
The power switch is a momentary tactile switch. If you want to fix it, you will have to turn it off and look at the size of the switch to try to find the replacement for it. Not much you can do but open it up to find the cause of the problem.
http://www.badcaps.net
Apr 17, 2010 | Samsung 225BW LCD Monitor
When turn on, get a picture for a fraction of a second then blank
you need your power supply repaired. you have bad capacitors.
Jan 01, 2010 | Samsung 225BW Monitor
Acer Aspire 5050 screen is blank
Hi, if it works with an external monitor it's more likely an LCD problem. When you push the power button, noting comes up on the main LCD screen? not even the Acer logo etc.?
Did you set your video card to use an external monitor and disabled the primary LCD? If so, you need to go to display settings, advanced and go to ATI Display and make sure that the notebook monitor is on.
Apr 02, 2009 | Acer Aspire 5050 5430 Laptop
X20G-Naga III screen goes blank after 1-2 secs
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 31, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
Samsung 225BW LCD Monitor Logo
123 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
