Question about Frigidaire FRT17G4B Top Freezer Refrigerator
MAGIC CHEF MCBR1000W
TOP FREEZER, 54 WEEKS OLD AND THE REFREGERATOR WANT COOL. REMOVED REAR PANEL IN FREEZER AND TOTAL ICE. ALLOWED TO MELT AND RESTARTED AND DID THE SAME THING. THE DEFROSTER IS NOT WORKING. WHAT WOULD AN EDUCATED GUESS BE?
  • 1 more comment
  • jdizzle1000 Feb 24, 2008
    Same problem here, defrosted the refrigerator twice with same results. I'll post if I find out exactly what the problem is.
  • jld80 Mar 03, 2008
    Freezer works, but lower part not cooling at all. Stopped working, then 2 months later miraculously started working again only to quit again 3 weeks later. Would like to fix it permanently but have no idea what to do. thanks.
  • pnaryanan Aug 30, 2008
    I have the exact same problem. The refrigerator works for 8 months and then stops working. I got a Sears Technician and he charged $175 and did nothing and then it started working again and it was fine for 7 months. Now, Again it is not working. Any ideas? email me if you have solution: [email protected]
  • 473 Answers
Had trouble finding a diagram with this model # but most common defrost problems are bad defrost thermostat, timer/control board, or a little more rare is the defrost heater.
Posted on Oct 06, 2007
SOURCE:
Water building up in bottom of fridge
more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. Over time it gradually builds and starts voer a larger area. Being you have a top mount refrigerator(freezer on top) there are air ways that connect the freezer to the fridege, which is how its cooled. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt
If thats not an option that you want to use the actual repair method would be to 1) unplug the machine 2) empty everything out of the freezer so you'll have room to work 3) take all the shelving and baskets out 4) locate the screws on the rear wall inside the freezer and remove them 5) take the back panel off exposing the evaporator coils ( the aluminum ) 6) directly below the coils is a trough of sorts and the drain is usually in the middle and runs out the bottom, remove the ice by carefully chipping it out or by using a hair dryer or hot water. 7) once all the ice is gone, the drain is visible and water can flow smnoothly down the drain dry the area and reassemble.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 04, 2012 | Magic Chef CTB1521 Top Freezer...
I have a Magic Chef MCBR1000W. The recent east coast earthquake shook the freezer door open while I was away on vacation. When I returned three days later, the freezer compartment (open) and refrigerator...
Quite often when the door gets open for a extended period of time the vents in the ceiling of refrig.compantment where the cold air from the freezer enters the ref.section...by looking up in the rear of the ref.ceiling you should be able to see these vents and see if they are frozen..if they are frozen a hair blow dryer will thaw them
Where here in the east coast are ya im 20 miles north of the epicenter in dumfries va
Aug 28, 2011 | Magic Chef CTN1521 Top Freezer...
Magic Chef refrigerator is only cooling to 52 degrees
Typically, the fridge gets its cool air from the freezer via a vent. There's something blocking that vent. If it's nothing obvious (e.g. plastic bag) on either side, then it's possible it could be ice build up inside the vent. Put your perishables in a cooler and unplug the fridge for 12-24 hours to allow it to melt. If there's still a blockage, the vent will have to be dismantled to see what's wrong.
Mar 06, 2011 | Magic Chef Refrigerators
Frosts up wont get cold MCBR1000S
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Magic Chef CTB1821AR Top Freezer...
Magic chef refrig model # MCBR1000W defrost thermostat
RepairClinic.com is a fantastic online site for ordering appliance parts.
Jul 29, 2009 | Magic Chef CTB1821AR Top Freezer...
MAGIC CHEF.. MOD MCBR1000W
we have the same fridge/freezer - a repairman came out to fix it and said the heater needed to be repositioned.. within a week the back was full of ice again, the repairman came back and said the defrost thermostat needed to be replaced.
Jul 25, 2008 | Frigidaire FRT17G4B Top Freezer...
Our Magic Chef fridge model # MCBR1000W does not seem to be keeping the fridge part cool enough, but still keeps the items in the freezer section frozen. The compressor is working, so not sure why this is...
yes the freezer door not closing properly will effect the refrigerator. also check in the freezer back wall and bottom for any frost buildup. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 16, 2008 | Magic Chef Refrigerators
MAGIC CHEF CTF1920ARA - Freezer works, Refrig. portion does not.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
Jul 04, 2008 | Magic Chef Refrigerators
Why did I buy it Magic Chef problem
of course replace the fan some times they go bad some times defective it happens seen them bad brand new out of the box
Feb 16, 2008 | Refrigerators
Frigidaire FRT17G4B Top Freezer Refrigerator Logo
1,327 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Thomas F. Schneider
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
