Question about Philips 150S4FB 15" LCD Monitor
Monitor philips 150s4
Hello value off r3106 r3117 thank you silvere
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
R 3106 330k r 3117 47ohm
Posted on Oct 07, 2007
Has gone black
hello,its the IC that has gone bad so all you need to do is to buy another one to replace it.
If you are not electrically inclined,i would suggst you take it to an authorized electrician to fix it for you and it will start working as it was before.
Take care.
Apr 10, 2010 | Philips 170B6CS (Silver) 17" LCD Monitor
Will this work on vista os
Hi
Thank you for your query
Yes thsi monitor will work with vista and Windows 7
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again - shauqatm@yahoo.co.uk
Feb 24, 2010 | Philips DesXcape 150DM (Silver) 15" LCD...
Philips 150S4 does not switch on every time the PC is switched on - suspect it is powersupply problem. Thanks Louis
You check the cable that's used to connect the cpu and that monitor, and the cable that's connected to the power supply. You unplug and plug it. You may have a loose connection on plugs. It works for me. Hope this helps.
Nov 08, 2009 | Philips 150S4FG (White) 15" LCD Monitor
How to unlock main menu
I have just sorted this problem on my Philips 150s4 monitor by pressing OK button for about 15 seconds.
Bartek - Webmax
Oct 06, 2009 | Philips 190B6CB/27 19" LCD
Backlight out on Philips 200WB monitor
It sounds like the inverter is out on the power supply for the backlights. If you can open the monitor and take a few pictures of the boards and send them to tech@ccl-la.com I will try to cross reference the boards and give you a repair solution.
Buddy
Corporate Computer
www.ccl-la.com
Sep 05, 2009 | Philips 200WB7 (Silver) Monitor
Philips 170b5 monitor when connected to power, just has a flashing led, and no image
is the screen connected to computer to if so hold the power button for couple seconds and should turn on,further questions write back,if my info was at any help to you please leave a comment ,thank you
Sep 01, 2009 | Philips 170B5CS (Silver) 17" LCD Monitor
Philips 150S4 15" LCD Monitor Problem
If it just fails to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not likely be able to do the repair yourself.
Modern power supplies are designed to shut down if the current drawn exceeds the design level, which indicates that something the supply services or the supply itself has died.
If you are adventurous, you might pull the plug on the set, allow the set to sit overnight, gain access to the innards, and with good light, inspect any boards inside.
If you see one that has few ICs but many more larger discrete parts, this will be the power supply.
Again, before touching anything inside, especially on that board, allow at least several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
You are looking for components called electrolytic capacitors that are almost always cylindrical and mostly installed upright at 90 degrees to the board with leads passing through to the solder side.
This same type of component in smaller dimensions is still used in a horizontal package with leads bent down and passing though holes to the solder side.
The latter are becoming more rare since they don't lend themselves well to robot assembly.
Many failed caps (not all) will show signs of pregnancy when they fail, bulging unnaturally at the top when compared with others. Now and then, there may be traces of a crystalline deposit around the end where the seal failed from internal pressure.
These will have values listed on them in uFd & VDC and sometimes, a plus/minus number lying about the precision.
Some also have a date code (rarer) that will look like four digits:
2403 = 24th week of 2003
Most electronics suppliers have a stock of the various values but if they have a date code at all, try to get only those made before 2002 or after 2006.
The larger caps will probably be OK since the failure is likely related to functions other than brute-force filtering. A pretty good 'rule of thumb' is to replace any caps you see bulging of any value but especially those that are 100 uFd or less.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace it or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
If you choose to replace failed caps yourself, you will need a quality soldering iron with a small, preferably iron-plated tip, rosin core solder and a sponge which when wetted is used to frequently wipe oxidized solder from the tip this should be kept bright and clean and fresh tinning will keep it that way.
You should also buy some solder 'wick' with the iron; this is used to place on the solder you wish to remove and then heated with the iron. Properly used, the wick will absorb nearly all of the solder from the lands from which you wish to remove a component.
Oct 12, 2008 | Philips 150S4FB 15" LCD Monitor
150s4
all resistors & transistor are the parts of power supply connected to switching ckt. so there is a possibility of switching transistor or associated components failure. please check it. if you are in need of schematic it is available at www.serviceinfo.com.
Oct 02, 2007 | Philips 150S4FB 15" LCD Monitor
Philips 150S4FB 15" LCD Monitor Logo
248 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Steve Allison
Steve Allison
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
