Question about Cobra 148 GTL 120-Channels Base CB Radio
Signal meter please help i have fitted a new signal meter to my cobra 148gtl and now it will key up but wont output or recieve could someone help me with the wiring spec just in case i have wired it up wrong cheers col
  • 126 Answers
Also, make sure your jumper coax, the small piece of coax between the cb transmitter and the meter, is good, no broken center coax.
Rollin CBs
Posted on Jan 26, 2008
  • 1,139 Answers
The signal meter would go into the antenna path something like this:
Posted on Oct 07, 2007
  • Henry McKelvey
    Henry McKelvey Oct 07, 2007
    Now that being said I would check my setup by removing the meter and seeing if the radio works. If it does the meter might have a problem. If the meter is good check your connections and make sure nothing it shorting out to ground (use an ohmmeter to determine if something is shorted to ground).
Need Cobra 148GTL with Cobra HG M75 pin-out color code
1audio. 1red
2shield. 2shield
3receive. 3blue
4switching. 4white
5transmit. 5black
Hope this helps
Jul 03, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
How do u set up a cobra 148gtl 40 channel to here far away
hello there firstly you will need to raise your antenna has high as possible and buy a preamplifier this will raise the weak stations and give better signals hope this helps
Mar 20, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
My new Astatic Road Devil will not transmit audio on my Cobra 2000, it came with a 4pin plug and I put on a 5pin 1 white(audio) 2 shield 3 black(recieve) 4 blue(common) 5 red (transmit) yellow(n/a)
recheck that you have the wiring correct. you will need the wiring of the cobra 2000/148gtl/grantxl... can't remember the pin outs. what you have posted is not the correct one??? i think.
Dec 26, 2010 | Astatic Road Devil RD104E CB Radio
I have a Cobra 148GTL with a 5 pin side mount mic. My problem is that the radio powers up and all I get is a static type noise but no recieve and when I key the mic the meter shows I'm sending a signal but...
sounds like a bad mic....At the 5 pin end u will see a small screw take out that screw and slide the pin cover back and you will see the 5 wires going to the pins my bet 1 or more of those ends are broken all you ned is re sod. them and all will be good .....I buy alot of broken mics and all i need do is fix the wires easy fix .....
Nov 13, 2009 | Cobra Radio Communications
Cobra 132 recieves good poor send
i would take it in and get a new diamond thats what it sounds like to me..
Dec 02, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
No recieve on virgin cobra 142 gtl,
seems to me that the audio ic of the cobra 148gtl brokedue sudden change of voltage from power suplly or flactuation. ta7222p
Jun 07, 2008 | Radio Communications
Cobra 18 wx st cb problem
Sounds to me like your finals in the rig have blown stopping you using the CB mode, Either that or you have a loose connection on the power output inside the radio.
Mar 15, 2008 | Cobra 18 WX ST 40-Channels Base CB Radio
Cobra 148GTL
Hello k007,
It sounds like you may have damaged the RF power amplifier stage of the CB. Since you were adjusting the antenna characteristics. Did you have a SWR (Standing Wave Ratio) meter connected while you were tuning the unit? If you did you might have noticed the needle go past the 1.2 mark when you were adjusting the antenna or the unit itself. In any event I think that the RF power Amp is shot.
Thank you,
Nov 04, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
99 people viewed this question
Top Cobra Radio Communications Experts
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
