Question about Linksys 5-Port Ethernet Switch (SD205-UK)
LAN Switch Ports
I have been having trouble getting on simple LANs using available switch ports...i have a standard toshiba satellite laptop, with an ethernet port...set to dhcp...should be as simple as plugging into an available linksys or netgear switch port and i should be on the LAN...i can jack into an available router port but not into the available switch ports...this has happened at 3 - 4 locations over the last 4 weeks...with dlink routers; linksys routers;netgear and linksys switch combinations but the symptoms seem to be the same...if these were configured in a similar way it would appear they have locked those ports down by only allowing valid MAC addresses...but that would not explain why i was able to get onto the available router port?...also i have tried a different laptop same config as mine but different mac address..same problem
  • 432 Answers
Try this website to start. http://member.dnsstuff.com/pages/tools.php
Posted on Oct 06, 2007
  • Raymond Scott
    Raymond Scott Oct 06, 2007
    Click Start, click Run, type cmd, and then press ENTER. type 'nbtstat -n' at the command prompt, and then press ENTER.
    NetBIOS over TCP/IP (NetBT) resolves NetBIOS names to IP addresses. TCP/IP provides many options for NetBIOS name resolution, including local cache lookup, WINS server query, broadcast, DNS server query, and LMHOSTS and HOSTS lookup.
    Nbtstat.exe is a useful tool for troubleshooting NetBIOS name resolution problems. You can use the nbtstat.exe command to remove or correct preloaded entries. To use the nbtstat.exe command: ? To list the NetBIOS table of the local computer, type nbtstat -n at the command prompt, and then press ENTER. This command displays the names that were registered locally on the computer by programs such as the server and redirector.
    ? To list the contents of the NetBIOS name cache, type nbtstat -c at the command prompt, and then press ENTER. This command shows the NetBIOS name cache, which contains name-to-address mappings for other computers.
    ? To purge the name cache and reload it from the LMHOSTS file, type nbtstat -R at the command prompt, and then press ENTER.
    ? To perform a NetBIOS adapter status command against the computer that you specify by name, type nbtstat -a NetBIOS computer name at the command prompt, and then press ENTER. The adapter status command returns the local NetBIOS name table for that computer and the MAC address of the network adapter.
    ? To display a list of client and server connections, type nbtstat -s at the command prompt, and then press ENTER. This command lists the current NetBIOS sessions and their status, including statistics, as shown in the following example:
How to manage Ericsson T720G switch?
(1) Console cable if you have desktop
http://www.instructables.com/id/Simple-RJ45-DB9-Cisco-console-cable/
For laptop console to serial cable
http://d32plhejlomyli.cloudfront.net/catalog/product/cache/6/image/500x500/9df78eab33525d08d6e5fb8d27136e95/1/4/14184.jpg
(b) Reset the switch it will work as a normal switch
skype id johnwalker800969@gmail.com
Aug 18, 2016 | Computers & Internet
Configure
I'd start by resetting the switch to defaults with the command
  • erase startup-config
  • The restart the switch with reload
  • Once rebooted enter conf conf t
  • Then simply configure all the ports at once
  • int ra fa0/1 - 24 if they are gig ports then it would be int ra gi0/1 - 24
  • Then type no shut
  • That should be all you need.
May 22, 2013 | Cisco ME 3400-24TS - switch - 24 ports
Ports/Interfaces on Toshiba Satellite Pro C660-171
If you still have warranty, take it back asp, they will have to repair or replace since this was manufacture defect, if that is not an option! Do a complete recovery on your operational system to factory setting.
Mar 21, 2012 | Toshiba Satellite Pro 6000 Notebook
How can i hook my toshiba satellite pro to my tv
there are some options here.. however they are limited to what ports are available on your computer AND on your tv.. for instance..
1 s-video, this is a round like ps/2 port thatt he computer and your tv have to have for video.
2 you can use a vga port from the laptop onto the tv for video
3 you can get a switch box that will be VGA from the laptop to VGA on the switch box that will use AV cables to the tv like a dvd player, and you'll just hook your computers headphone jack intot he jack on the converter box for sound through the tv.
4 buy a brand new smart tv.
Aug 05, 2011 | Toshiba Satellite Pro L300 Notebook
Hallow there, my name is bernard james from Tanzania, I have my Laptop, Toshiba Satellite A135-S4656, but i do not have Ethernet Controller Drivers, where i get them. thanx in advance. and tat the first...
Go to Toshiba support pages (click here), select your operating system to see all the drivers available for you computer model and look for LAN Driver (Realtek LAN Driver) .
Sep 28, 2010 | Toshiba Computers & Internet
Toshiba A45-S1202 The rear USB port does work, but the side USB ports by the upper left corner by the LAN port don't work. I did a BIOS FLASH, still nothing! Is this a DUMMY USB? No power to the upper left...
There are no dummy ports on laptops....could be a cold solder point on the motherboard connections or a wire connection is loose. There is also the possibility that the usb controller for that port has failed. Below is the link to the service and repair manual for that laptop......
http://tim.id.au/laptops/toshiba/satellite%20a40.pdf
Jan 28, 2010 | Toshiba Satellite A45-S1202 Notebook
Using di-804 as a simple switch
If u want to use it as a switch, do not connect the WAN port, just connect to the LAN ports.
Feb 27, 2009 | D-Link DI 804 (DI-804) Router
Toshiba Satelite a135 s2386 USB problems...
this is the fault of your usb port, its a hardware problem, its better not to use that port, use a usb hub if you want more usb ports
Nov 11, 2008 | Toshiba Satellite A135-S2386 Notebook
Compatibility Issue with HDMI Switch?
anytime your talking about a switch your talking about a temporary connection. The issue with using a switch is that for HDMI you want best quality and you will not get that using a temporary connection. The unit may be recognizing a weaker signal and turning the port off. However since the output on that particular unit is 1080i you should be fine using composite, just get a nicer monster set.
Dec 26, 2007 | Samsung DVD-R135
ActionTech Wireless Gateway can't route Wireless to LAN
Disable firewall on all devices. All types of security sofwares should also be disabled in order to ping each devices.
Oct 07, 2007 | Actiontec GT704WG Wireless Router...
Linksys 5-Port Ethernet Switch (SD205-UK) Logo
232 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
