I have the Jensen VM9312 7" Touchscreen DVD player. I attempted to hook up by Rockford Fosgate 2000 Watt Dual Chanel Punch Series Amp to push two 12: Audiobahns. The Amp has One Red One White RCA input same as most do. the headunit has one 1 red/white front,1 red/white rear, and a green subwoofer output. No natter how i connect the RCA's icannot get the subs to bump correctly. i converted the 2 rca From the amo into one male end and plugged it into the subwoofer input but i got nothing. i then decided to use a line cnverter and convert one left and one right speaker into the RCA but i can only get one sub at bump at a time. Soon as i put my pioneer headunit in...it works great i just cant get the Jensens setting correct!!!
-   I cant get my jensen to accept my subs with the rca either. The instructions show 5 inputs from the deck to the amp, i will have to try that. Have oyu figured it out?-   Guest
i hooked everything up just like the manual said and it worked fine before i mounted it in the dash...
(More)
i hooked everything up just like the manual said and it worked fine before i mounted it in the dash then i mounted it in and it wont power on but i can hit the eject button and it lights up for a sec and the display button and it lights up for a few more seconds.what do i do?
My unit Sony CDX-M800 unit (discontinued) is nearly eight years old so I am not surprised it is...
(More)
My unit Sony CDX-M800 unit (discontinued) is nearly eight years old so I am not surprised it is starting to go on me (as they are made to only last a handful of years), but here is the issue: the motorized screen's buttons and display do not work at all. The screen still moves down with the use of the main button on the face and the 'open' button on the remote, but once its open you must use the remote button to put it back. It would be nice to have use of the inside controls. Any easy fix idea to get the inside face working again?
My headunit is powering up but i get no display....jus lights....... The unit is an insignia NS -...
(More)
My headunit is powering up but i get no display....jus lights....... The unit is an insignia NS - C3111 I connected the blue to blue red to red black to ground but where does the yellow wire go. It also has a choke box.....where the yellow and black wires enter and leave........ Please help!!!!! :(
