Question about RCA P52929 52" Rear Projection Television
Blue ghosting There is a blue ghosting on the picture that I cant seem to adjust out
  • Anonymous Apr 03, 2008
    i have blue ghosting and yello colour ark at the bottom of the screen
    any idea's ?
  • 102 Answers
This could be a convergance problem, if there is such an adjustment described in the manual and it doesn't work, make sure the optics are clean.
Posted on Oct 06, 2007
SOURCE:
Ghosting or a 3D image. A yellow and blue ghosting or shadowing image. Looks much like the top picture in the "picture ghosting image" entry. Is this a convergence problem?
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 09, 2011 | Toshiba 50HX70 50" Rear Projection...
I think I lost a gun? Picture seems to be losing a color. lines are off and can't seem to get a good picture.
If you can find a channel or video with pure red, green, and blue you can check the quality of each individual color. If by "Lines are off" you mean the picture has a ghosting or 3-d look than that is the convergence. You can do some adjustment by entering the user menu and scrolling down to the second page and selecting the convergence option. Set the center crosshair then work your way through the positions. If you can't adjust one color in one direction it is probably your convergence IC's and related components.
Sep 21, 2009 | Toshiba 50H81 50" Rear Projection...
We have an Hiatchi UltraVision Model# 53SWX10B that the sounds comes on initially then 30 seconds later goes mute. The picture is still great but since it's 8 years old is it worth repairing. What could be...
Hi , audio output failure, possibly needs re-boot of cable/sat system, too many variables to troubleshoot on here, and thats generally a great tv so yes I would advise you to get a tech to fix it, video-tek
Jul 01, 2009 | Hitachi 61SWX10B 61" Rear Projection...
Hitachi 50" Ultravision too much yellow, not much blue
First of all sorry for delay.
can you provide a image of yello shadow.I believe it seems to be technically say "ghost image"
If it is ghost image we can try by entering SERVICE Menu and adjust RGB level of the light engine.
Good luck
Dals123
Oct 04, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Blue ghost
I have blue ghosts/shadowing at the top of the screen.
Sep 24, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Blue shadow
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 25, 2007 | Toshiba 53AX61 53" Rear Projection...
Blue Ghost
You need new convergence ICs . They cost about 10.00 each you will need two. They are located on a large aluminum heat sink with an STK number stamped on them. They will have to be soldered in. If you can solder you will be able to do this repair yourself. Let me know if you need ay additional Info.
Nov 14, 2007 | Sony KP-53S65 53" Rear Projection...
Blue, red and green ghosting, curves in picture
convergance amp ic bad
Oct 30, 2007 | Mitsubishi VS-45609 TV
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Hit 53UWX10BA
Check you cable box compared to another tv.  The pisture may need adjusting take off front panle and use the screws to adjust pic  it could get better of worst be carefull
Oct 21, 2007 | Hitachi 53UDX10B 53" Rear Projection...
RCA P52929 52" Rear Projection Television Logo
74 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
