Question about Sylvania 6427TE 27" TV
Not accepting video via RF connection
My sylvania is 3 years old and has worked without a days problem until this week. I use a separate tuner and connect to the TV via a RF connection. The video has just gone to snow. In addition I am unable to adjust the volume manually up or down. I've tried new cables and even tried plugging in a Video camera into the jacks on both the front and the back...but got nothing. Is my TV toast? Thanks for your help!
  • dudeman1228 Oct 06, 2007
    I have a tuner for my surround sound. I have tried using another source to plug into the TV with no success. Thoughts?
  • 102 Answers
Why use a seperate tuner? Have you tried removing the seperate tuner and plugging the antenna into the TV?
Posted on Oct 06, 2007
  • Lenaida Byford
    Lenaida Byford Oct 06, 2007
    You do understand that a video signal is not the same as an antenna signal, if the TV is capable of showing a video signal then you will need to plug it into a RCA or phono or scart socket on the back. The antenna input is only meant for radio signals either from an antenna or modulated UHF source like a video recorder.
I cant figure out how to change the channel to input/video on my broadband tv without a remote
This problem may be more complex than just the selection of a channel to receive video. The first problem is what channel to receive the video. Usually its received on channel 3 or 4. You select that on the video output and match it on the TV. That assumes your recorder is attached via the RF (antenna) connection. If its hooked up via the component connect then you must have a remote to select IN1 or IN2 on the TV to receive video. Remote controls are available on line. Do a search on your TV model and remote control.
May 03, 2014 | Sylvania 6420FB 20" TV
I'm trying to hookup my Toshiba DR430KU to an older tv that require an RF Modulator. I get a skewded sideways picture. Does This DVDR compatable with a RF Modulator?
Probably not. Better picture results are achieved with either S-Video, standard RCA AV cable (yellow-white-red), or YUV component cable (red-green-blue) (component output does not have audio - this requires extra cable to be connected). The video via either one of these 'AV' connections is stunning (based on a standard 16:9 LCD TV using a Panasonic DVD recorder).
RF tends to be lower quality - as opposed to AV/digital input. AV input/YUV component handles digital better. No one connects their DVD devices to their TV via RF (either directly to the antenna socket or with a modulator/attenuator) anyway. Because a VCR is mostly analogue, it will work fine with an RF connection, but DVD is digital, and so won't work as well, if at all.
RF also goes through the tuner in a TV, creating cross-interference, whereas AV is a direct input and is separate to the tuner.
I would say an RF modulator would not be designed to handle the output frequency that your DVD device generates. Throw the modulator out, or perhaps get another TV, or use RCA cables instead if the TV has AV inputs. Whichever is cheaper and easier, but don't use RF accessories except a standard antenna if/as required.
Apr 27, 2011 | Toshiba DR-430 DVD Recorder
I have a Magnavox ZV427MG9 DVD Recorder VCR Combo. Do I need a separate tuner? If so what kind? Thanks
Ofcourse you need an external tuner to receive any RF signals. Your Magnavox is not equipped with internal tuner with it. OK.
Apr 21, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
I don't see the cable connection on the TV. Is there an adapter for this?
This TV doesn't have a tuner and thus no RF (coax) input. It should be connected to a set top box by component, composite or S-video cables. Component video (with three RCA video plugs on each end) will provide the best signal (a separate cable with two plugs on each end carries the audio).
I wish that I could be of more help.
Sep 30, 2010 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Connecting magnavox dvd/vcr player DV220MW9 to a 40 year old TV
What type of Inputs do you have on your TV. (ANT IN, S-Videio, RCA Video,RCA Audio)
If you only have a ANT In or RF Coaxial hook up you will need a RF Modulator
Jan 03, 2009 | Philips Magnavox DVD/VCR Dual Player
Screen just went black
Think your set tuner is bogus. The other tuner that you used should work, but if it is not a cable tuner configured to your system it will not work either via the rf outputs or the audio video outputs. If that cable box works with another set then you have a real head scratcher on your hands.
Mar 24, 2017 | Sanyo AVM-2756 27" TV
I have a 30 year old tv w/cable. I want to install a dvd/vcr combo player. What kind do I need? I've tried one and it didn't have the right connection.
If the original TV doesn't have audio/video inputs, you'll need a DVD/VCR player that has a built-in RF modulator. A RF modulator takes the audio & video and modulates a RF carrier to one of the channels that your TV can receive. In the U.S., this is usually channel 3 or 4. If the DVD/VCR player has a built-in tuner, connect your cable to the RF input of the DVD/VCR player and the RF Output of the DVD/VCR player to the cable input of the TV. This way, you can receive your cable channels through the DVD/VCR player and watch movies as well. If your DVD/VCR player does not have a built-in tuner, you can put a RF switch inline that will allow your TV to either receive the cable signal or signal from the DVD/VCR player.
- Jim
Jul 03, 2008 | Televison & Video
TV Green
satellite box send out siginal in the same frequency, so the tv tuner doesnt have to work on it, but all siginal coming to the Tv goes through the turner.
Jun 25, 2008 | Televison & Video
Connevting to an LCD TV
Dear Customer,
try to do on av channel that provides special output like ps,live footage connected to spy cam,xbox & any other like tuner-capture card all are acceptable on av channels,
TRy & having funn with your new lcd,
May 17, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Sylvania 6427TE 27" TV Logo
48 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
