Question about Pentax ME Super 35mm SLR Camera
Film advance slipping?
When i advance the film and try to take a picture it doesn't work and have to do it again, so every second picture takes. i took it to be repaired once and they said the advance was slipping, it worked for a little while, and is now doing it again. could it be something else?
This has happened with my pentax super program. All that was wrong is the the spool/winder was dirty. It needed to be cleaned. You open up the back of the camera. Stick something such as a small screw driver, just something to stop the film winder from turning. Now turn the top of the winder off while keeping the bottom part in place. Be very careful not to close the back of the camera while you do this. Once you have it out give it a clean with a soft cloth and then put it back in. I found it tricky to align it and get it back through the whole. But, that's me. After that it worked perfectly. Until the next time in a year or so it needed to be cleaned again. Hope this helps.
Posted on Dec 25, 2007
SOURCE:
Just loaded film and cant take picture, its not advancing
You need to add a little more information about what you did exactly.
Did you pull enough leader film out? If I had to guess, I would say the film wasn't rolled far enough onto the "advancement reel" so you are not able to advance it because the camera doesn't think it has film in yet.
Nov 14, 2011 | Vivitar V3800N 35mm SLR Camera
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
Thhe camra will not advance the film or take a
I used minoltas for a number of years while going through college, though unfortunately this problem is fairly common- was a few years back but first time it happened to me i took the camera in for repair and if i recall theres a part that just breaks inside (number of years, cant remember the part).
It would have cost me round £60 to repair- bout 6 times the cost of the camera from ebay- I eventually just started buyin a new one from ebay every time the problem cropped up again.
I realise it may not be what you want to hear if your particularly fond of your camera, but the cost of replacing a part may very well be more than the camera is worth.
At the moment I have a minolta XG-M sittin on my shelf, hoping to track down some service manuals and see about taking it apart- I'll let you know if i find anything out, even with my fancy digital camera i still miss using the old 35mm.
Nov 04, 2009 | Minolta XG-A 35mm SLR Camera
When i took pictures at christmas i used fiji film in my camera and when i took to get processed they were all blank. could this have been the film but the kodak also did this can you help me
There are 2 things to check.
First: Put in a cheap film and just press the shutter while the back of the camera is open to see if the film is advancing.
Second: Try pressing the shutter while there is no film in the camera and the back is open to see if the shutters are working correctly.
Apr 29, 2009 | Minolta Photography
Pentax SF10 Camera -- double exposure
If you press the film release button like you are going to rewind exposed film you may be able to activate the film advance lever to cock the camera so you can take another picture, and the film should stay on the first exposure allowing you to re - expose it. I would underexpose each image 1 F stop because.you are exposing the same film twice. Double exposures are always an iffy proposition and anything can happen. After the second exposure cocking the film advance should allow the film to advance once again. You might test this on the final pictures on a roll in case the camera won't start advancing the film after you try it. This way you won't blow a whole roll worth of pictures testing it.
Apr 12, 2009 | Pentax PZ-70 QD 35mm SLR Camera
Blank Film Developing
It likely did not catch when it was first loaded, and as such never advanced through the camera. Open the back of the camera, with no film in it, then set the shutter speed to 1, advance the film advance lever and take a shot. You should see the shutter curtains open and then close a second later. Then advance the film lever again and watch to see that the sprockets are turning. If they are, then the camera is exposing and the mechanics are working properly to advance the film. Chances are it was just loaded incorrectly.
Dec 09, 2008 | Canon EOS-AE-1 35mm SLR Camera
Takes a picture when film advance lever is moved
The magnets that control the shutter are the likely suspect. Dirt and debris can cause them not to hold properly. Hence, it fires the shutter when you advance the film. It is something you can repair yourself. I can describe the procedure if you are interested.
Sep 09, 2008 | Canon EOS-AE-1 35mm SLR Camera
Like i said before i do not know how to advance the camera
Here is Canon's spec page for your camera. CanonUSA
The camera is a preloader. It rolls all of the film out of the canister and winds it back as you take pictures. Read the film transport section. You have installed a battery in the camera right?
Mar 15, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Canon T70 35 MM SLR Camera
It sounds like your camera is having problems advancing your film, which could mean it is jammed inside the camera. The other thing you should check is to see if the battery is weak & doesn't have enough power to advance the film (and thus the beeping). If it is not the battery, then go in a darkroom (completely dark) and take out the film (if you're unable to rewind it inside the camera). Look at the transport rollers (in the back for the camera) and make sure they're clean (sometimes film chips get jammed in there) Let me know if this helps you. Thanks.
Sep 11, 2007 | Canon T70 35mm SLR Camera
Pentax ME Super 35mm SLR Camera Logo
130 people viewed this question
Top Pentax Photography Experts
Bill Eager
Geoff Hone
Are you a Pentax Photography Expert? Answer questions, earn points and help others
