Question about Acer AL1914 19" LCD Monitor
No lights or monitor
My monitor shows no display or lights at all now as if it wasn't plugged in. Previously it had another problem whereby the menu would keep appearing on the screen on its own then sometimes disappear and appear again. Pressing the buttons sometimes took the menu off and sometimes the buttons didn't appear to respond at all. The button problem had been intermittent over a long time but getting very bad just before the screen died.
  • bluezebra Oct 08, 2007
    Where do I obtain new buttons from?
    I will try looking at them to see if something has slipped, but I'm thinking if its anything else like you suggest it may not be worth the effort fixing.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
First of all you will to replace those buttons as its useless after few years. as per your problem is concern you might see some change after replacement. still it does not work then there is a video problem 1 crt filament supply less 2 voltage on g2 is less . 3 check voltage on video ckt to be normal. 4 crt base loose. 5 there might be crt weak if it is old. hope this will help.
Posted on Oct 08, 2007
SOURCE:
Hcm 582 monitor not display show
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Apr 23, 2014 | Acer AC713 17" CRT Monitor
L no display
If it seems like it booted up, you hear fans running, hard drive spinning, lights, (except the display is black) then try the steps below.
For a laptop:
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
For a Desktop:
Try using another monitor on the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor shows the display then your original monitor is bad. If the Borrowed monitor does not show on the display then you Video Card is bad.
May 16, 2012 | Computers & Internet
E machine model T3626 turns on display doesnt work and doesnt power off???
Sounds like either the Monitor is bad or the Video Card is bad. Try plugging another monitor on the computer and if it can't show a display then more than likely the Video Card is bad. If it shows on the monitor you just plugged in, then the original monitor is bad.
May 01, 2012 | Computers & Internet
Dual monitors display same
When you set up a second monitor, you have the option of duplicating the output (showing the same image on both screens) or extending the screen (making both displays like one very wide screen).
If you need to change this again, the setting is in the control panel / display settings.
The actual settings vary a little depending on what version of windows you are using. But if you get stuck you can post back or comment on your computer's specifics.
Dec 27, 2011 | Dell ATI RADEON X300 SE, (128 MB) PCI...
I have a compaq monitor and it will not stay on it says VGA no signal then it'll say monitor going to sleep. It won't let me do anything else. Also saying recommended settings 1600x900 60 Hz. Can...
This may sound ridiculous, but I recently spent two weeks troubleshooting a monitor that wouldn't display properly. Turns out it wasn't plugged in all the way. Make sure that it is plugged in properly, and that your computer/device is displaying TO that monitor.
-bin
Aug 25, 2011 | Compaq Computers & Internet
Monitor's display is shifted up and right so that there is just black space to the left and all along the bottom whereby cutting off the display. cannot see bottom menu bar.
One of the buttons on the front of you monitor (bottom right hand corner of the bezel) is a menu button. Press that then using the the arrows up and down buttons go the the horizontal and vertical positioning option. Once chosen move the display as desired.
You could also press the Auto (config) button, that may do the same for you.
May 17, 2010 | Acer AL1912 19" LCD Monitor
I require a wiring diagram for Clarion radio/cassette PT8006B.
Dear FixYa, I accessed the internet and was led to your site in an attempt to resolve a wiring problem. I am not in a financial situation whereby I can afford to pay for this privilege. Thank you for your trouble.
Mar 23, 2009 | Clarion Car Audio & Video
Kds model 780 monitor no signal, power button does not work
My monitor does the same thing at times and sometimes shows "No Signal" and at other times the screen will maintain the images but the backgound color switches to mustard yellow. In each of these cases I have been able to solve the problem by unplugging the power cord from the electical outlet for about three seconds and plugging it back in. I have a KDS model 780 LCD.
GOOD LUCK
Dec 15, 2008 | KDS Radius RAD-5 15 in. Flat Panel LCD...
D70 no picture displays in monitor - all black
Check the 'monitor off' option... if you cant find it, open the manual in page 153... http://www.nikonusa.com/pdf/manuals/noprint/D70_en_noprint.pdf Good luck
Nov 25, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Acer AL1914 19" LCD Monitor Logo
93 people viewed this question
Ekse
Alun Cox
