Question about Acer Aspire 3680 Laptop
Acer 3690 taken all original software programs off some how alt-f10 nothing? what can be done!
  • 3 Answers
Alt is defined in the software to jump to the ACER E Technology software suite. If you have wiped the hard drive clean without saving a backup of the application, you are out of luck. If you saved an applications backup, then re-install the Etechnology software suite.
Posted on Oct 09, 2007
How do i reboot my recovery partition from a aspire 3690
Hi
If you have the option to save anything like files and photo's stored on your hard drive you should do this before you attempt a recovery because you will loose all files it will format your hard drive
back to when you bought it
Normally when you hit the power key you also tap the ALT+ F10 key a few times until it gets you
into the acer recovery manager and when asked for a password try 000000 thats is ( 6 zero's ) and follow the on screen instructions
if the F10 option dont work
then restar laptop and tap the F2 key to get you into bios and go over to about the 3rd of 4th option
and make sure that the D2D is enabled if it is not then click on it and change to enable
then click F10 to save and exit
then go back and try the ALT+F10 keys again
Mar 22, 2011 | Acer Aspire 3690-2196 Notebook
My Acer Aspire One D250 is stuck on the Windows XP loading screen. I have tried unplugging it and plugging it back in again, and have even taken out the battery and just plugged the power cord into it....
Hi Mimi,
If you can live with losing all the data on the netbook, you can reset it to factory original by pressing and holding alt + f10 right after you power it on. This will trigger the Acer e-recovery management utility which will allow you to reset it. If you do this, you will lose all data on the pc. If this is a problem, you may have to take it to a service shop to have your data backed up first. Also, if you can't get the alt+f10 thing to work, you can take it to an Acer authorized service centre and they can send it to Acer for warranty repair as it is less than 1 year old. Acer normally does not cover software issues, but if alt+f10 doesn't work, it could be an issue they will cover under warranty.
Hope this helps!
Regards,
Joe
Jan 02, 2011 | Computers & Internet
Acer orbicam 3690-2710 stop working after install. Initially worked upon setup, but when I try to reopen after closing it a message appears saying: "A webcam was not found or is not working...
Access Camera Assistant Software:
a. On the taskbar double-click the Camera Assistant Software icon , or from the Windows® Start menu, point to All Programs, Camera Assistant Software, and then click Camera Assistant Software. The Camera Assistant Toolbar location briefly displays on the desktop.
b. On the Camera Assistant Toolbar, click the Start Camera button and click on the icons on the software.
If the the above steps are not working, then follow the below steps:
You can reinstall the WebCam drivers from the Acer recovery management, to do so:
Start Menu> All Programs> Acer erecovery management> Restore> Restore Application & Drivers> Contents> Select Acer Crystal Eye and install it
OR
Got to http://gd.panam.acer.com/home/
Select the computer model
Select Operating System
Click Drivers
Select Camera (Orbicam) and download it.
Once downloaded install it on your computer.
If still facing the issue, then you may need to perform full system recovery, to do so please follow the steps mentioned below
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key
& keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction.
NOTE: This will erase all the datas on the computer
Dec 06, 2010 | Acer Aspire 3690-2710 Notebook
My acers aspire 3690 laptop boots up to windows xp home perfectly but the usb ports do not work,it shows that it is working but when i plug in a usb device it does not try to reconigse it, i cannot find...
The partition D is actually a back up partition that has factory image for the original Operating system that was installed in the computer.
factory recovery ( DATA LOSS )
if the computer is booting to windows, then click start and open a folder named as 'acer' listed in ' all programs '.You will find the ' Acer e-recovery managent ' in that folder.You can open it and click allow for the user account controls.Please click 'restore ' for the next screen and the select the first option, 'completely restore to factory defaults '.Follow the on screen instruction to initiate the Recovery.
The Alternate method for starting the Recovery on startup is using the combination of ALT+F10 ( some models its ALTgr ) on startup.Press and Hold down the ALT( Left hand of space ) and at the same time keep on tapping the F10 key till you get the message " Windows is loading files".Just follow the On screen Instructions to start the Recovery.
Oct 22, 2010 | Acer Aspire 3690-2196 Notebook
How to reboot my acer aspire 3690 to factory condition
On startup you will see a message on the acer splash screen to get into "SETUP". This will either be the DEL key or the F2 key.
Go into your BIOS and make sure that D2D recovery is enabled. If you do not see this D2D option then you can exit and should not have to adjust anything else.
when you restart the PC again, hold down the ALT and tap on the F10 key, this will start the recovery partition and load your system to factory default.
This option will only work if you still have your original hard drive in the PC and you have not reformated or reinstalled windows from another media souce.
Feb 04, 2010 | Acer Aspire 3690-2196 Notebook
What function keys do i press on startup to re insatll the operating system on my acer aspire 3690
you can use the recovery disk which came along with the laptop to reinstall the OS. There is no function key to start the installation automatically, there is a backup / restore button in some laptops which can reset the OS. Check the manual for any such button on your laptop.
Jul 07, 2009 | Acer Aspire 3690-2196 Notebook
Accessing hidden drive for reinstallation.
try while you are seeing acer logo   ALT+f10
May 17, 2009 | Acer Aspire 3690-2196 Notebook
Reinstall original acer instalation
you can run recovery using the recovery discs which should have been created by you... or you have to go into the OS to access recovery manager...
Jan 31, 2008 | Acer Aspire 3690-2196 Notebook
Acer 3690
I thing you do not need alt you just press f10 and select the drive you want to boot from.
Acer Aspire 3680 Laptop Logo
111 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
