Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Lamp life Have owned the unit since 7/05 have gone thru 3 lamps. In the shop now for another lamp 5.5 months old. Tech has stated 2077 hrs on the lamp. Unit not shuting off?? Mits no help and the tech replace the blast 1 year ago.
  • was1532 Oct 07, 2007
    I dont understand. The hour for the lamp are right on the meter for normal use. The problem is the unit is shut off every day and I dont watch that much tv. So the meter is still running or the lamp isnt shutting off. Tech stated the lamp is shutting off.
    In order to have 2077 hours on the lamp the unit would have to be on for 20 hours a day.
    Any help would be appreicated cant afford knew lamp every 4 to 6 months.
  • 363 Answers
This lamp life is about right if the TV is getting constant use. Please check that the cooling fan is running at the correct speed and the vents are unobstructed.
Posted on Oct 07, 2007
  • Martin B
    Martin B Oct 07, 2007
    There is a possibility that the power supply for the lamp is not adjusted properly making it run too bright.
  • Martin B
    Ok I have read the manual now, yes you should expect a lamp life of 4000hrs or more.
    I now understand what you meant by blast (ballast).
    Quote from the manual:-
    The actual life of the lamp in this television can vary, based on the lamp itself, the air temperature around the TV while it is operating, and your viewing patterns. Warmer air or poor ventilation shortens the lamp life, as does turning the television on and off frequently.
    Which you probably knew already.
    I would suggest checking the cooling fan and the dust filter which needs regular cleaning to maintain airflow over the lamp.
SOURCE:
Bought Samsung dlp h-l 5667w new in 2005. Replaced lamp, fan, and color wheel in 2008. Now lamp lights up and lamp indicator on front lights up, fans turn on, but tv picture will not show. After a few...
It time to replaced the tv projection lamp again,the tv projection lamp life span have ended.The tv projection lamp life span only last 2000 hrs.Average out like 1 1/2 or 2 years max for tv on watches 4 or 5 hrs of tv every days.
Jul 07, 2011 | Samsung HLR5667W 56" Rear Projection HDTV
T.v.says lamp not working
If the display indicates then it is possible that the lamp has failed or that the Power to the lamp is cut off. You will need to check the status of the lamp and also the lamp connectors, the supply from the power.
Check to see if the cooling fan is clogged and so has reset the processor with a error. If so clean the filter to reset.
Jun 30, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
The picture has suddenly gone dark. We can still see the picture, however it is really dark. We tried shutting it completely down and unplugging and restarting it. We tried to adjust the color via the...
The tv LED light on the tv front bazel frame face have the word "LAMP" light up or blinking?Yes.The tv projection lamp been inside this tv like 1 1/2 or 2 years already,tv used it everydays like 4 or 5 hrs daily?Yes.Than the tv projection lamp life are over,that why it dim picture tv now must have it tv projection lamp to be replaced.
Jun 12, 2011 | Samsung SP50L6HX 50" DLP HDTV
I have a 65" Mistubishi WD - 65734 and have no
Yes,"LAMP" LED light indication front of tv bazel frame is on or blinking,yes mean tv projection lamp life are over.The whole tv warrenty only for a year,tv projection lamp should last at leat 1 1/2 or 2 years,by tv been on and watches used it like 4 or 5 hours daily?U never done tv replacement parts,any kinds before?Yes,hire a tv Tech. to do it.Shop around for a Tv tech.should replaced the projection lamp for u shoud be around $250 to $300 that including part the projection lamp.
Jan 03, 2011 | Mitsubishi WD-65734 65" HDTV
Lamp bulb indicator is red and unit will not light up
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work
get a small fan and place it near the projector to provide
extra cooling. The projector is running border line on
high temperature and just needs a little extra cooling.
Also, check and clean the air filters.
Jul 17, 2010 | Optoma HD65 DLP Projector
Still getting "Projection lamp is nearing end of life"
KDF46E2000 - Change Lamp Warning - Reset
Bulb is most likely OK. Original bulb in Sony TV is Philips, label on bulb usually says Philips. Sony don't make bulbs. Sony Cost is usually 1.5 times other sources. Many shopping cart operations sell condemned, reject or poor quality electronic service items because cost of return and fooling with them is excessive. This is obvious and widespread with convergence ICs and other parts.
Lamp timer needs reset. This is usually an automatic function. TV detects Increased lamp current from previous failed bulb or weak bulb condition and resets automatically. TV must be unplugged for lamp replacement for this to work. Occasionally it must be reset manually, as below:
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a
second of each other:
DISPLAY Channel 5 Volume + POWER .1. Access Service Adjustment Mode and select the Service Menu that
contains the Category with the Adjustment Item you want to change.
2. To change the Category, press 2 or 5 on the Remote Commander.
Note: Pressing 2 or 5 only changes the categories within the
Service Menu displayed. To change a Category on one of the other
Service Menus, press the JUMP button until the correct Service
Menu is displayed.
3. To change the Adjustment Item, press 1 or 4 on the Remote
Commander.
4. To change the Data Value, press 3 or 6 on the Remote
Commander.
Note: To go back to the last saved Data Value, press 0 then ENT
on the Remote Commander to read the memory.
5. To save the changes, press MUTING then ENT to write into
memory.
6. To exit service mode, turn the power off by pressing POWER .
Wait 2 minutes before restarting the set to allow the fans to
completely shut down or the Service Menu will appear on the screen.
easyab
ConvergenceRepair.com
__________________
Feb 27, 2010 | Sony KDF46E2000 46" Projection HDTV
My 3.5 year old wd-57731 has gone thru 6 lamps since purchase. I vaccumm the rear of the tv every month and the last tech that came out changed a sensor. TV is still under warranty. Any suggestions on what...
Howdy;
It is your ballast that is causing your short life of your Lamp. The original Part Number for the 'PWB Power' is 934C228001.
I have had this problem at least 100 times and it will give your Lamp a life of about 2 years, 5,500 hours.
Good luck with your Warranty Company, Big Irish.
Dec 03, 2009 | Mitsubishi WD-57731 57" Projection HDTV
My Sharp XR-40X DLP Projector bulb will not start. The bulb is not near the end of it's projected life nor did I get the "Replace Bulb" warning indicator. It has power and the fan comes on.
Hi Just be aware that the stated lamp projector specs "2000 hour lamp" does not mean you will get 2000 hours. What it means is that the lamp is rated to deliver up to 2000 hours. So some might get 1000 hrs, others 1593 hours etc.
The lamp may have died of its own accord prematurely and obviously unexpected.
With the power and fan coming on my first throughts are either the lamp or the lamp ballast (powers the lamp).
If you need a lamp we are able to supply replacement lamp delivered next time you need one, as we ship internationally and also the same with our revolutionary ICE Digital Daytime projection screens. Cost $US337 with lamp housing or lamp only $270. includes freight. Excludes any import taxes. http://www.youtube.com/watch?v=HvZ2DlVJ790 http://www.youtube.com/watch?v=qL_44xfK9y8 Regards Kevin Andreassend ICE AV Technology Ltd New Zealand http://www.digitaldaytime.com [email protected] +64-9-414 2348
Jun 21, 2009 | Sharp XR-40X Projector
Same old problem Plus more
1532-DLP TVS' WITH LAMPS WILL NOT GIVE THE USUAL 5-6 THOUSAND LAMP HRS. IF THE SET IS ON AND OFF FREQUENTLY,AS EVERY POWER ON SEQUENCE ARCS THE LAMP WITH 10,000 VOLTS TO GET IT STARTED.TRY ALSO TO KEEP SET CLEAN ESPECIALLY IN THE BACK SET AREA. JOE TV
Oct 27, 2007 | Mitsubishi WD-52725 52". Rear Projection...
JVC AV56WP74
Replace the lamp, also the shut down time is correct the unit must allow plenty of time proper lamp cooling. otherwise the lamp life will be greatly shortend. normal lamp life is 3000 hrs.
lamp replacement may require an internal limp timer reset have a qualified tech replace the lamp.
Oct 06, 2007 | JVC HD-52G886 52" Rear Projection HDTV
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
67 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
