Question about DXG Technology DXG-305V Digital Camera
Wierd Camera shuts off after 2 seconds
Changed the battery recently and the camera keeps cutting off after about 2 seconds, no time to change any setting, have made sure the batteries are in the correct position, the batteries are rechargable NI-MH 1000mah AAA. The package said made for digital cameras and manual says to use alkaline, so am i using the wrong battery?
  • wk990 Nov 11, 2007
    shuts off after 2 seconds also
The DXG305's battery metering sys works by measuring voltage. You can have a set of 1.2V NI-AH @ infinite Ah (4x1.2V=4.8V) and the stupid thing will still shut down! It only draws approx 300mA max. The DXG requires more than 6V constant; I know this 'cause I hooked it up an external bench power supply and dialed in the voltages, the thing starts to crap out at anything less than 6V. Expensive alkaline e2 might hold up for a bit, but my solution was to build an external 7V battery pack using 6 Ni-MH AAs and a battery cartridge. The DXG30X is a half ass POS designed product, but it's was great way to waste time and exercise ones trouble shooting skills.
Posted on Feb 13, 2008
    Problem Solver:
  • 6 Answers
Battery is dead, change with fresh ones
Posted on Jan 22, 2008
SOURCE:
Camera sony s930 shuts down after taking 2 or 3 pictures
when you purchased the battery minimum charging is 48 hours.please charge fully battery and then use it.I hope your problem will be solved.sometimes we are not charged the full battery and then battery life is also effects.
Aug 22, 2009 | Cameras
Samsung bl103
Mine did the same thing. Just let it sit for a couple of days. Don't mess with it. It'll eventually stop doing that and work. That's what i did. It worked for mine.
Jul 15, 2009 | Samsung Digimax D53 Digital Camera
Batteries problem....
Try rechargable NiMH batteries. They are specifically designed for today's technology, and last much, much longer than traditional batteries. It doesn't matter about the brand -- Energizer, Rayovac, Duracell, generic -- I've found that they all tend to last about the same amount of time in my digital camera. But I only use rechargable ones anymore.
Nov 14, 2008 | Concord Camera Eye-Q 4060AF Digital Camera
Coolpix 775 shuts off all by itself
The auto shut off should be around 30 seconds to allow the built in memory to store everything and rest.If it keeps repeatedly turning off and then on again in a short space of time it will use alot more power from the batteries just Like a car engine uses more petrol stopping at traffic lights. The other factor, I am repeatedly typing on this site is Digital cameras need to run on rechargeable batteries, If you are already using rechargeables,have a look at tha mAh value which should be written on the side. Retailers recomend a value of at least 1800,personally i would go for 2100.
Oct 25, 2008 | Nikon Coolpix 775 Digital Camera
Camera shuts off after a few seconds
i had that problem with another camera i toggled with the lens it went in and works like a charm. Dont be to gentile it will go in
Oct 08, 2008 | Samsung S630 Digital Camera
Shuts off after pic
have you changed your batterys recentley as digital camras work better with rechargable batterys
Jun 18, 2008 | Nikon Coolpix 5600 Digital Camera
Battery Problem
These cameras have a internal battery that holds data for the camera to keep its settings. These batteries can be replaced but the camera has to be disassimboled to change it they should be able to be changed at a local camera shop pretty cheap.
Mar 21, 2008 | Nikon COOLPIX L12 Digital Camera
Change Batteries....?
Ok.. did you guys try a reset? Just remove the batteries, wait for 60 seconds then put them back in.. that should reset the camera..
Feb 22, 2008 | Canon PowerShot A95 Digital Camera
Camera Keeps shutting off
Have you changed the battery/batteries for another brand? I'm wondering if various brands react differently to extreme temperatures? Probably not the problem with your camera, just thought it might be worth a try!
Feb 13, 2007 | Nikon Coolpix 5700 Digital Camera
Camera cuts off when I take a picture
same here, i thought that the camera was going into sleep mode to save batteries, the light turning red dosent inspire confidence
Sep 02, 2006 | Fuji FinePix A205 Digital Camera
DXG Technology DXG-305V Digital Camera Logo
123 people viewed this question
Top DXG Technology Cameras Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Ekse
Are you a DXG Technology Camera Expert? Answer questions, earn points and help others
