Question about Samsung PCN5425R 54" Rear Projection Television
Convergence (red) is out of alignment
I have the same problem. I've used the controls to get it close, but not right yet. If I push perfect picture button it goes out of wack: I have to start all over again. Have you found a solution? Please share. It wants to adjust, just not enough (red) control. [email protected]
  • 2 more comments
  • 1jvd Oct 06, 2007
    Where is the crt board?
    Where do I get freeze spray?
    Can I reset my remote to factory settings? Please advise
  • 1jvd Oct 07, 2007
    OK thanks for the info.above.
    The color seems ok, brightness is fine...Everything on the right side of the screen has a red shadow. Yesterday: first I got the center target right on. I spent a couple of hours moving the lower right target (left)closer and closer... Almost all the red shadow letters on screen were back where they belonged. At the very end I could not get them on perfectly. The left side of the screen looked a lot better, the right was still out. I hit the perfect focus button on the remote and lost it all. I do have the original remote. The remote made it worse. Can I simply reset the remote somehow? The set has received regular servicing under srvc.agree.(cared for). When I spray what do I look for? Please advise, and thanks for your help, I do appreciate it.
  • 1jvd Oct 07, 2007
    Should I have the set turned on? While spraying?
    Nothing will explode?
    After spraying (red only) I will attempt to adjust with remote.
    Is the any way to lock the remote so that it brings it back into specs each time?
    I'm ready to give it a try!
    Waiting for your advise.
  • 1jvd Oct 07, 2007
    What about the convergence service mode to do the alignments? Adjustable?
    Genius:
  • 1,153 Answers
In your red convergence you have vertical and horizontal, pin, lines and etc. It sounds like you have a bad resistor in one of the areas. You would need to know which area to narrow down. Are you could look and see the problem, just look on crt board. I would take a can of Freeze and spray the board resistors until it changes then you could narrow down quicker.
Posted on Oct 06, 2007
  • Lashawn Robinson Oct 06, 2007
    The CRT board is the board on the neck end of the tube, you have 3 for 3 tubes. The Green is always in the middle. You can get freeze spray from local Radio Shack or online at MCMelectonics, bluestar-online, tritronics, etc. Don't know why, but if batt. were out for atleast an hour it will probably reset to factory. If this is original remote.
  • Lashawn Robinson Oct 07, 2007
    the remote is not your problem, either it works or not. There is no magic fix with it. Now the spray should either mess things up more or sometimes it will fix the things that are done by heat. It will cool it down and work like it should on those problems. I would only spray in the red area where you are having problems.
SOURCE:
Flash Focus does not correct convergence problem and i cannot manually adjust the red convergence to proper alignment. Red does not move laterally only vertically. Picture is offset to the right with red...
No,any colors lines mis alignments.The tv convergence board parts are dead.The 2 STK convergence ICS and some or all it resistors are dead.These parts must be replace on the tv convergence board.To solveved convergence problems.The shop,will cost u $300-350 for parts and labors.
Aug 10, 2010 | Sony KP-51HW40 51" Rear Projection...
My Hitachi 43fdx01B went from a perfectly clear picture to one with red "ghosts" and very blurry. I my TV toast?
No,ur tv have a problems,known as a convergence problems,it dead.Very common problems on the DLP tvs design flaw.Most commom problems are R,G,B mis alignment,will not align,Colors shadows pictures,3D pictured and blurry?The tv convergence board require changing the 2 STK convergence ICS and some or all it resistors are dead,must changes to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 26, 2010 | Hitachi 43FDX01B TV
My big screen panasonic tv has a double fuzzy picture what am I supposse to doto fix it
Adjust the convergence or reset it to factory default. Use only the remote when adjusting convergence. The front controls have no effect.
  1. Press action button to enter MENU.
  2. Navigate to SETUP.
  3. Scroll down to CONVERGE.
  4. Press VOL > to select.
  5. Press CH buttons to navigate up or down.
  6. Choose CONVERGENCE ADJ or RESET TO DEFAULT.
  7. Press VOL > to select.
  8. If CONVERGENCE ADJ is selected the align Green to Center screen will be displayed.
  9. Use the navigation buttons on the remote control to align the horizontal and vertical green lines on screen, with the cabinet reference marks on top center and left
    center of cabinet.
  10. Press ACTION button to display red center correction screen.
  11. Use the navigation buttons on the remote control to align the red cross with the white cross pattern at the center of the screen. To prevent picture tube damage do not leave test pattern on for an extended period of time.
  12. Press “0” on the remote control keypad to display the BLUE center correction screen, repeat procedure for adjusting blue. If needed press “0” again to return to RED correction screen. An adjusted cross pattern appears white with a minimum of color protrusion.
NINE POINT CONVERGENCE CORRECTION
Remote Control must be in TV mode.
  1. Press ACTION button to display red correction screen.
  2. Press the 1 through 9 keypad buttons on the remote control to select the desired convergence position.
  3. Use the navigation buttons to align the RED cross with the white cross pattern.
  4. Press “0” on the remote control keypad to display the BLUE correction screen, then repeat procedure.
  5. To exit press ACTION button repeatedly, then press CH up.
Nov 07, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX49 convergence amplifiers
check R7059 and R7050
check for 2.2 ohm.
if not 2.2ohm replace them.
values are 2.2ohm at 2 watts
also look for bad soldier around all serounding resintors.
Jan 15, 2009 | Panasonic PT-47WX49 47" Rear Projection...
PCN5425R
Sounds like the digital convergence controls is possibly the item giving you the problem, if you have already changed the convergence board. You can get a used digital convergence board at the following link, just leave them a email and state your model number and what your needing.
http://servicemanuals.vstore.ca/
Jun 03, 2008 | Samsung PCN5425R 54" Rear Projection...
Replaced Convergence Board picture still bowed
Today may be your lucky day. Approach this procedure with extreme caution and take your time. Sometimes when you replace that board you have to do a full digital convergence alignment. With tv off, push mute,1,8,3,power. Tv will come on in service mode. Certain buttons can now screw up the set in a major way, do not guess. press 7 to adj. red, 8 for green, or 9 for blue. Then look for the highlighted "x" intersection. Use directional buttons to adj. while careful to watch screen. Vol+ and - or ch+ and - make moves, mute moves cursor. If alignments move up, down, left, and right continue until all intersections are aligned. Turn power off to start over. When done press add/del on remote to save settings. That should fixya.
May 30, 2008 | Akai PT5598HD 55" Rear Projection...
Red shadows on images
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Nov 18, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Red convergence out of range.
Replace STK393-570 convergence IC. located on center PCB.
re-check alignment........T.
Oct 24, 2007 | Mitsubishi WT-42311 42" Rear Projection...
RED
to do a proper convergence alignment always use your geen as refferance to work from bring the red and blue to the green also find the center of the screen and on the top and bottom to be sure your geen is centered then start/g
Mar 19, 2007 | Samsung PCN5425R 54" Rear Projection...
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
37 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
