Question about Dryers
Amana dryer belt
I have an oder amana electric dryer (Model # ALE331RAW). The drum turns when empty but not when loaded. I'm assuming it is the belt slipping. What is the best way to replace it? Thanks!
  • 94 Answers
You will probably have to open it up from the top and/or back. If the belt looks alright (it probably won't, though), check the belt tensioner. Carefully observe how the belt goes on and around the tensioner before replacing.
Posted on Oct 07, 2007
How do you open the dryer to look at the belt
Posted on Aug 24, 2009
SOURCE:
My amana dryer model #NED7200TW turns on and the motor runs nicely but the drum wont turn on its own. It will turn easily if i turn it with my hand. only about 3 years old.
if your saying theres a motor running but the drum wont turn . then id say either the idler pulley has come off or drive belt has broken , these do go bad especially on heavy load machines
Sep 14, 2016 | Amana NED7200TW Electric Dryer
I have Amana Electric dryer model #ALE331RAW. IT HEATS AND TUMBLES BUT IT DOESN'T GET THE CLOTHES DRY, COULD IT BE THE BLOWER FAN AND HOW TO REPAIR?
first, make sure all your seals are in place, like door and drum. if they are ok then disconnect the vent pipe on back and try to dry a load. if it does then you have a blockage at the venting.
Feb 09, 2011 | Dryers
How do you adjust a slipping belt for an Amana # ale331raw? Thanks
The belt ribs go against the drum. This link shows various configurations BELT CONFIG.
Your dryer tech service manaual: AMANA DRYER
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 13, 2010 | Amana ALE331RAW Gas Dryer
Unexplained dryer noise
I have this same problem, how do I get to the belt to check it out?
Mar 21, 2010 | Amana NED7200TW Electric Dryer
My Amana dryer gets clothes stuck between the drum. how do i fix this
Sounds like the drum bearings are worn out. this leaves a gap for the clothers to stick into. You will need to replace them. Check the support rollers also when you have it apart.
Sep 01, 2009 | Amana ALE331RAW Gas Dryer
Amana dryer does not run but i can hear the motor faintly
Sounds like the belt is either broken or slipped off the pulley. Remove the back of the dryer and find the motor. Look to see if the belt is still attached to the pulley. If not, look to see if it has slipped form the pulley and is hanging from the drum, or if it is broken. More than likely, regardless of which it is, you will just need to replace the belt.
Jun 03, 2009 | Amana ALE331RAW Gas Dryer
How to install drum belt in Amana Model LED20AW.
HIya,
Cabinet Removal- Maytag & Amana Top Load Washing Machine
Remove the two (2) screws (item #21 on the attachment below) from the bottom of the front panel. Once the screws are removed, pull out on the bottom of the front panel until the spring clips release for the cabinet top.
Diagrams:
http://www.pcappliancerepair.com/model-display.php
Apr 07, 2009 | Amana DLE330RAW Electric Dryer
Thermal fuse keeps blowing
they will blow if the heat dont get out of the dryer and builds up inside / check and see if vent hose behind dryer is kinked or vent going outside is open / it will be one of those two.
Nov 25, 2008 | Amana ALE331RAW Gas Dryer
Drum turns but not when it is fully loaded
Do you hear a loud hum when fully loaded? Or does it go away when empty?
Sep 20, 2008 | Amana DLE330RAW Electric Dryer
Dryers Logo
232 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
